Hey everyone, I’m having a weird issue with my Arducam 4K 8MP IMX219 Autofocus USB Camera Module. The built-in microphone suddenly started producing this loud brushing/static noise in the background. It’s not ambient room noise — I covered the entire camera with my hand so no external sound could get in, and the static is still there just as loud. I recorded a quick test where I say “Testing 12345” and then blow into the camera area. You can hear my voice and the blowing, but there’s a ton of background static throughout the whole recording. Totally unusable. Anyone seen this before?
Quick update — I tried a few things on my own before posting here but no luck so far:
- Flashed the firmware — the burning program reported a successful burn, but the static noise problem remained exactly the same.
- Unplugged the USB camera and plugged it back in — no change.
- Closed the firmware burning program entirely, relaunched it, and re-flashed the firmware again — still says successful burn, but the audio static is still there.
So it doesn’t seem to be a simple flash hiccup. Not sure what else to try at this point.
Thanks for the detailed report and for already trying the firmware re-flash. Just so you know, firmware corruption on these modules can sometimes manifest specifically as an audio subsystem malfunction — the camera video can look fine while the mic sounds terrible, which matches what you’re describing. So you were on the right track with the re-flashing attempt.
That said, the exact procedure matters. I’ve sent you a private message with the official firmware burning guide for this module. Please follow it step by step and try the re-flash one more time using that procedure. Sometimes an incomplete or incorrect flash can report “successful” but still leave the audio subsystem in a bad state.
Give that a shot and let us know if the static persists.
