Hey everyone, hoping someone can point me in the right direction. I just picked up an Arducam 20MP IMX283 USB 3.0 camera and I can’t get any video out of it. The camera doesn’t even show up — nothing in Device Manager, no detection at all. I’m just using a standard USB-A to USB-C cable I had lying around, plugged into my laptop. Is there a specific type of cable I need for this thing? Feeling a bit stuck here.
A couple of quick questions to narrow things down:
- Are you using the stock USB cable that came bundled with the camera, or a third-party one?
- Which USB port are you connecting to — USB 2.0 or USB 3.0 (the ports with the blue insert)?
- What OS are you running?
The IMX283 is a pretty high-bandwidth module and these Arducam USB 3.0 cameras can be surprisingly sensitive to cable quality. Standard cables often don’t cut it.
I’m using a regular USB-A to USB-C cable — not the one that came in the box. It’s plugged into a USB 3.0 port (blue) on Windows 11. The camera just never shows up. Tried multiple ports, same result. Device Manager doesn’t even flicker when I plug it in. The cable I’m using works fine for my phone and other peripherals so I figured it’d be fine, but maybe not?
That’s almost certainly the issue. The IMX283 is pushing 20 megapixels over USB 3.0 — that’s a serious amount of data throughput, and it also draws a fair bit of power. Most everyday USB cables, even ones that work perfectly for charging phones or connecting basic peripherals, aren’t built to sustain that kind of bandwidth reliably. The shielding tends to be weaker and the power wires are often thinner gauge.
Try the stock cable that came with the camera. It’s specifically designed to handle both the power delivery and the signal integrity this module needs. And definitely keep it on a USB 3.0 port — a USB 2.0 port won’t provide enough bandwidth even with the right cable.
Alright, found the stock cable buried in the box and gave it a shot — and yeah, the camera fires right up now. Crystal clear. So that was definitely it. Thanks!
But now I’ve got a follow-up problem: the stock cable is really short. Like, maybe a foot or so? My camera needs to be mounted about 2-3 meters from the host machine. I need a longer cable. Can someone tell me the exact USB cable specification that matches what Arducam uses? I don’t want to just grab any random USB 3.0 cable off Amazon and end up right back where I started. USB 3.0 Type-A to Type-C obviously, but what about shielding type, wire gauge, any particular certification I should be looking for?
Glad the stock cable sorted the detection issue — that confirms the camera itself is fine and it really was just the cable.
As for a longer replacement, this gets a bit tricky with USB 3.0. Signal degradation over distance is a real problem at these data rates, and a lot of off-the-shelf longer USB 3.0 cables cut corners on shielding or use thinner power conductors to save cost. A few things worth knowing before you buy anything:
- The USB 3.0 spec technically tops out around 3 meters for passive cables. Beyond that you’d likely need an active cable or powered repeater.
- You’ll want something with proper foil + braid shielding. Skimpy shielding = dropped frames or the camera dropping out entirely.
- Power conductors should be at least 24 AWG. Anything thinner and the voltage drop over 2-3 meters could make the camera flaky.
- Connector pairing is USB-A (host side) to USB-C (camera side), which you already figured.
Let me dig into the exact specs Arducam uses for their stock cable — shielding type, conductor gauge, whether there’s any impedance matching going on — so you can match it as closely as possible when shopping for a longer one. I’ll update this thread once I’ve got the details.
