Having a hard time getting the Arducam 1MP Stereo Camera for Raspberry Pi / NVIDIA Jetson Nano / Xavier NX (dual OV9281 monochrome global shutter) working on a Raspberry Pi 5. The exact same camera works on my Pi 4 with Bookworm, but on the Pi 5 libcamera-hello never produces a stream — it just times out.
The cable that ships with the camera is 15-pin on one side and 22-pin on the other. The 15-pin end plugs into the Pi 4 connector fine, but it won’t fit the 22-pin connector on the Pi 5. So I swapped in a 22-pin-to-22-pin cable from the Arducam 1MP quad camera array kit. The camera appears to be detected, but then it errors out with a timeout.
Thanks. The good news is the camera is being detected and registered:
INFO RPI pisp.cpp:1122 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/arducam_pivariety@c to CFE device /dev/media3 and ISP device /dev/media0 using PiSP variant BCM2712_C0
It even selects a sensor format (1280x400-Y10_1X10). The failure comes later, when the frontend stops getting frames:
WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video4[16:cap]: Dequeue timer of 1000000.00us has expired!
ERROR RPI pipeline_base.cpp:1424 Camera frontend has timed out!
There’s also a missing IPA config warning specific to the Pi 5 ISP path:
ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam-pivariety_mono.json’ not found for IPA module ‘rpi/pisp’
but the actual crash is the frontend timeout. How long is the 22-to-22 cable you pulled from the quad kit? That can matter more than people expect.
It’s one of the longer cables from the quad array kit — roughly 150mm. The cable that came with the stereo camera is 15-to-22, so I couldn’t use it on the Pi 5’s 22-pin connector.
That’s very likely your problem. The longer a CSI camera cable is, the worse the signal integrity gets, and that can produce exactly this ‘Camera frontend has timed out’ error — the sensor gets configured but the frames never come back reliably. The Pi 5’s RP1/CFE path is particularly sensitive to marginal cables.
The key part of the failure is:
[0:13:02.651622201] [2084] WARN CameraSensorProperties camera_sensor_properties.cpp:274 No static properties available for ‘arducam-pivariety’
[0:13:02.661409107] [2084] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam-pivariety_mono.json’ not found for IPA module ‘rpi/pisp’
[0:13:02.848191295] [2084] INFO RPI pisp.cpp:1122 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/arducam_pivariety@c to CFE device /dev/media3 and ISP device /dev/media0 using PiSP variant BCM2712_C0
[0:13:04.142622622] [2084] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video4[16:cap]: Dequeue timer of 1000000.00us has expired!
[0:13:04.142650752] [2084] ERROR RPI pipeline_base.cpp:1424 Camera frontend has timed out!
[0:13:04.142655770] [2084] ERROR RPI pipeline_base.cpp:1425 Please check that your camera sensor connector is attached securely.
[0:13:04.142660807] [2084] ERROR RPI pipeline_base.cpp:1426 Alternatively, try another cable and/or sensor.
The fix is to swap in a shorter 22-pin-to-22-pin cable. For this camera an 80mm cable is the usual recommendation. I’ve sent you the details for a compatible 80mm 22-22 cable in a private message — check your inbox and give that a try.
The camera is detected on the Pi 5 (it shows in libcamera --list-cameras and registers to CFE /dev/media3 + ISP /dev/media0).
The failure is specifically the frontend timeout — frames are requested but never arrive.
The Pi 4 and Pi 5 setups differ in more than cable length: Pi 4 uses the 15-pin path and a different pipeline, while Pi 5 goes through RP1 with the rpi/pisp ISP stack.
The shorter 80mm cable is still the first thing I’d try, because the Pi 5 CSI path can be picky even at 150mm. But you’re right that it’s not the only difference, and the missing ‘arducam-pivariety_mono.json’ IPA config for ‘rpi/pisp’ is worth chasing — that’s Pi 5-specific and could point to incomplete driver/sensor tuning for this module on the Pi 5 stack. The OV5647 workaround you tried isn’t relevant here, so it’s expected that it didn’t help.
Current take: it’s not a simple detection failure, and cable/signal integrity is still the prime suspect, but the driver/IPA config angle on the Pi 5 isn’t ruled out. If the 80mm cable doesn’t change anything, the missing IPA config and rpi/pisp sensor support would be the next thing to dig into.
