RPIshop.cz
https://rpishop.cz/kamery/2514-arducam-16mpx-imx298-mipi-color-camera-module.html
Raspberry pi 3
https://github.com/ArduCAM/MIPI_Camera/blob/master/RPI/README.md
it never worked
Ahoj, řeším problém s arducam 16mpx z automatické expozice, vyvážení bílé a autofokusu … Když zadám příkaz: ./arducamstill -t 5000 -m 1-ae 1 -awb 1 -e jpg -o test.jpg tak se nic nestane expozice a ostatní parametry se nemění Mohl by mi někdo pomoci?
I am having issues with IMX298 module ( purchased from local reseller:
https://kamami.pl/kamery/576988-arducam-b0174-imx298-mipi-16mpx-modul-kamery-dla-raspberry-pi.html )
Following the manuals I have successfully compiled the SDK from
for RPI3 B+ and RPI Zero. In case of both RPI models the gpu_mem is set to high value above 256MB but when selecting resolution mode 3 and 4 (width: 4656, height: 3496) for arducamstill I am getting memory allocation error:
Open camera...
Found sensor imx298 at address 1A
mode: 0, width: 1160, height: 800, pixelformat: pBAA, desc: 4x4 binning 60fps
mode: 1, width: 1920, height: 1080, pixelformat: pBAA, desc: 60fps
mode: 2, width: 2336, height: 1748, pixelformat: pBAA, desc: 2x2 binning 27fps
mode: 3, width: 4656, height: 3496, pixelformat: pBAA, desc: 8fps
mode: 4, width: 4656, height: 3496, pixelformat: pBAA, desc: 12fps
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 1
index: 1, CID: 0x00980915, desc: V4L2_CID_VFLIP, min: 0, max: 1, default: 0, current: 1
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1660, current: 1608
index: 3, CID: 0x009A090A, desc: V4L2_CID_FOCUS_ABSOLUTE, min: 0, max: 1023, default: 150, current: 0
usrvcsm: [vcsm_malloc_cache]: [1230] [mmal_vc_port buffer]: ioctl mem-alloc FAILED [-1] (hdl: 0)
usrvcsm: [vcsm_vc_hdl_from_hdl]: [1230]: invalid device or handle!
usrvcsm: [vcsm_lock]: [1230]: invalid device or invalid handle!
mmal: manually_port_pool_create: could not allocate 20407296 bytes of shared memory (handle 0)
mmal: Failed to create connection.
mmal: Failed to create pool
mmal: Failed to enable camera
set resolution status = 1
Selecting lower resolutions, gives me an image with green tint:
Any help would be appreciated.
Best Regards,
Mcgr3g0r
