Arducam 16MP B0522 outputs only 1920x1080, not expected 4656x3496
Hey everyone, I just picked up an Arducam 16MP camera (model B0522) and I’m running into a weird issue. The product specs clearly state it supports up to 4656x3496 still image resolution with AEB and AEC, but no matter what I try, I’m only getting 1920x1080 out of it. I’m just using the camera directly without any special configuration. Has anyone else run into this? Am I missing something obvious here?
Hi there, thanks for reaching out. That does sound frustrating. Just to confirm a few things before we dive deeper — you mentioned the B0522 model, correct? And can you tell me what operating system you’re using and how you’re trying to access the camera? Are you using the built-in Camera app, or some third-party software?
Yeah, it’s definitely the B0522. I’m on Windows 11. I’ve tried the default Windows Camera app and also checked it through the browser, but both only show 1920x1080 as the max resolution. I haven’t installed any special software yet — I just assumed plug-and-play would give me the full sensor resolution since it’s UVC.
That’s actually the root of the issue right there. The Arducam B0522 16MP UVC camera does not output 4656x3496 by default. The default capture resolution is indeed limited to 1920x1080 — so what you’re seeing is expected behavior, even though it’s confusing given the advertised specs.
To access the full 16MP (4656x3496) resolution, you need to explicitly switch the resolution mode using compatible software. The camera’s higher resolutions aren’t exposed through the standard UVC defaults that the Windows Camera app picks up.
On Windows, the recommended tool for this is Potplayer. It lets you manually switch the camera into its higher resolution modes. Arducam has documentation on exactly how to set this up — I’d suggest starting here:
https://docs.arducam.com/UVC-Camera/Appilcation-Note/Software-Instruction/Windows-Potplayer/#first-use
That guide walks through the first-time setup and shows how to switch to the full 4656x3496 resolution. Give that a try and let us know how it goes.
Ahh okay, that makes a lot more sense now. I had no idea the higher resolutions needed a software switch — I figured UVC would just enumerate all supported modes automatically. I’ll grab Potplayer and go through that documentation link you shared. Thanks for the clear explanation, I appreciate it! I’ll report back once I’ve had a chance to test it out.
