HI guys!!
I bought the Arducam 16MP Autofocus in Amazon
B0371C
Raspberry Pi 4
I have been following this guide: libcamera and libcamera-apps - Arducam Wiki
5. Problems you were having?
I want to take photos at different focus values as fast as possible but i can not do it. is quite a slow process.
For instance i want to perform this simple routine:
go to lens position 4 → take a photo → go to lens position 50 → take a photo → go to lens position 600 -->take photo … etc etc
I made the following working script but its kinda slow and i can visually see that the mechanical lens goes back to baseline in between every change of focus, which i think is not efficient for time.
import subprocess
import time
def capture_image(output_file, lens_position):
command = ['libcamera-still', '-o', output_file, '-t', '100', '--autofocus-mode', 'manual', '--lens-position', str(lens_position)]
subprocess.run(command)
# Capture images with different lens positions
lens_positions = [4, 50, 600]
output_files = ['yei4.jpg', 'yei5.jpg', 'yei6.jpg']
for i in range(len(lens_positions)):
lens_position = lens_positions[i]
output_file = output_files[i]
- What help do you need?
Do you have any example, guide, or information that helps me to take faster/optimal pictures while changing the lens distance? is there maybe a function os instruction im not leveraging?
best regards
