AR1820HS : difficulty to make it working
UCtronics
UC-549 Rev C - AR1820HS
Raspberry Pi 4B with 4 Gibts of RAM and last RaspiOS
https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI
Never Worked yet
Hi ArduCAM Team,
Β
I bought 5 AR1820HS camera on UCtronics for a current project.
I followed in detail all the instruction of this page :
Β
everything is fine, until this error message :
β€˜β€™β€™
mmal: Failed to start sensor.
mmal: Failed to enable camera
β€˜β€™β€™
I have already increased the memory for the GPU at 360 M, it doesn’t help.
thank you so much in advance for your help.
Β
see here under all the tests :
Β
pi@raspberrypi:~/MIPI_Camera/RPI $ ./capture
Open camera…
Hardware platform: c03112
Found sensor ar1820 at address 37
mode: 0, width: 1232, height: 920, pixelformat: pRAA, desc: 2lan 40fps
mode: 1, width: 1920, height: 1080, pixelformat: pRAA, desc: 2lan 27fps
mode: 2, width: 2464, height: 1080, pixelformat: pRAA, desc: 2lan 27fps
mode: 3, width: 2464, height: 1842, pixelformat: pRAA, desc: 2lan 24fps
mode: 4, width: 4912, height: 3684, pixelformat: pRAA, desc: 2lan 7fps
mode: 5, width: 4912, height: 3684, pixelformat: pRCC, desc: 2lan 5fps
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 1
Get ctrl V4L2_CID_VFLIP fail.
index: 1, CID: 0x00980915, desc: V4L2_CID_VFLIP, min: 0, max: 1, default: 0, current: 0
Get ctrl V4L2_CID_EXPOSURE fail.
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 16449
index: 3, CID: 0x00980913, desc: V4L2_CID_GAIN, min: 1, max: 16, default: 16, current: 2
Get ctrl V4L2_CID_RED_BALANCE fail.
index: 4, CID: 0x0098090E, desc: V4L2_CID_RED_BALANCE, min: 0, max: 511, default: 64, current: 0
Get ctrl V4L2_CID_BLUE_BALANCE fail.
index: 5, CID: 0x0098090F, desc: V4L2_CID_BLUE_BALANCE, min: 0, max: 511, default: 64, current: 0
Please choose sensor mode: 3
Setting the mode…
choose the mode 3
set resolution status = 3
Β
Β
$ :~/MIPI_Camera/RPI $ ./opencvGui
Β
Β
$:~/MIPI_Camera/RPI $ ./arducamstill -t 5000 -m 1 -e jpg -o test.jpg
Open camera…
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 3857
index: 4, CID: 0x0098090E, desc: V4L2_CID_RED_BALANCE, min: 0, max: 511, default: 64, current: 64
index: 5, CID: 0x0098090F, desc: V4L2_CID_BLUE_BALANCE, min: 0, max: 511, default: 64, current: 64
Β
:~/MIPI_Camera/RPI $ ./list_format
index: 0, CID: 0x00980914, desc: V4L2_CID_HFLIP, min: 0, max: 1, default: 0, current: 0
index: 2, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 1000
close camera status = 0
Β
:~/MIPI_Camera/RPI $ ./utils/camera_i2c
setting GPIO for board revsion: c03112
Raspberry Pi3B / Pi3B+ / 3A / 4B(1G/2G/4G)
./utils/camera_i2c: 137: ./utils/camera_i2c: ./rpi3-gpiovirtbuf: not found
00: – – – – – – – – – – – – –
30: – – – – – – – 37 – – – – – – – –
60: – – – – – – – – – – – – 6c – – –
70: – – – – – – – –
pi@ISOMAscope:~/MIPI_Camera/RPI $
increase of GPU Mem
provide me simple instructions that are working, indications what else to try, which tests to make to have more infos etc…
Β
I’m always stuck, exactly at the same point,
Is there any support yet on this forum ? tanks in advance for your help, suggestions.
Β
Best Regards
Guess it’s a bit late… but I just got mine working!
I have the one that comes with a UC-667 board in between the camera module and RP (link here Arducam 18MP AR1820HS camera module for Raspberry Pi Pivariety), and I had to follow these instructions (link here How to install and build Raspberry Pi Kernel Driver for Arducam Pivariety Camera) for Pivariety, NOT MIPI_Camera. There’s a link at the bottom of that page for a DOC that I followed after installing Pivariety etc.
I kept trying to get MIPI_Camera to work to no avail before contacting support for their instructions… it was a mess. I know you may have already solved this, but at least this may help someone in the future!
