I am new to this so please be patient. The camera is arducam ar1820hs with sku B0367. I am trying to use it with raspberry pi 4b with 8gb ram with bookworm os. I followed the instruction on the following link: Quick Start Guide - Arducam Wiki . When I run the rpi cam hello or anything from rpi cam i get error ‘no cameras available’ . Even after confirming the connections are right in terms of the pins. i have also confirmed that the driver in the link i gave is installed. i checked if the libcam libraries are installed. i have also done the overlay dtoverlay=arducam-pivariety…i still keep getting error that no camers available.
cat /boot/firmware/config.txt
# http://rptl.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
Thanks for getting back with pics and the output. You’ve provided the perfect clues to solve this.
It’s the FPC cable you’re using that keeps your Pi away from detecting the camera module. Could you please try the original FPC cable that comes with the camera?
