Hi, I’m stuck with an AR1335 driver that just won’t work on my Raspberry Pi (Arducam OBISP MIPI camera module). I already tried the method support suggested but it’s still not working, so I’m hoping someone here has other suggestions on how to proceed.
My setup:
Raspberry Pi (I understand support tested on a Pi 4)
OS: tried Bullseye, and also Buster
OS images used: raspios_full_armhf-2022-04-07 and raspios_full_armhf-2021-05-28
Hi, thanks for the detailed write-up. I owe you an answer on this — I couldn’t get back to you in time earlier. Here’s what I found on my side.
First important thing: the unit we tested previously was the pre-launched version of the camera, which is NOT the same product as yours. That means our earlier test results don’t apply to your module, so please disregard them.
Key point for your camera: it can only be used on the Buster system at present. So the correct test platform is a Raspberry Pi running Buster before we do any further diagnosis.
Thanks for the reply. So I moved over to Buster as you suggested and it’s still not working. Same story as before — I used the method support provided and no luck.
Just to recap the current state:
Raspberry Pi 4, Buster system (also tried Bullseye earlier)
pi@raspberrypi:~ $ arducamstill -t 0
Hardare version: c03114
No match to hardware version!
Device /dev/video0) opened.
Video format set: UYVY (59565955) 1920x1080
[Framerate]: 30 fps.^C
And capturing to file:
pi@raspberrypi:~ $ arducamstill -t 5000 -o test.jpg
Saving image data to test.jpg successfully.
So on Buster the capture actually completes. Can you try the same commands on your end and compare?
Interesting, thanks. I’ll match your setup and run arducamstill -t 0 and arducamstill -t 5000 -o test.jpg on my Buster Pi 4.
One thing though — I keep seeing No match to hardware version! (Hardware version: c03114) in the output. Is that the actual problem I should be worried about, or is that harmless? It shows up even in your log, so I’m not sure if that’s what’s breaking things for me.
Good eye. Based on the Buster test here’s where we stand.
Root cause / observation: the camera reports No match to hardware version! (Hardware version: c03114). That message is the only remaining anomaly we can see — despite it, the capture pipeline itself works: UYVY 1920x1080 at 30 fps, and saving to file succeeds (Saving image data to test.jpg successfully.).
So the takeaway is:
The correct test environment is Raspbian GNU/Linux 10 (buster), armv7l, kernel 5.4.79-v7l+ (Pi 4B). Make sure you’re on that, not Bullseye.
Ignore the old results from the pre-launched camera — they don’t apply.
RGB3 is not supported by your camera, so use RGB888 instead of RGB3 for the pixel format.
I’ve also sent the matching driver package to you via private message — please grab it from there and reinstall before re-testing. If capture still fails on your end after that, post the exact output of arducamstill -t 5000 -o test.jpg and we’ll dig into it further.
