AR0234 camera outputs monochrome video instead of color on Jetson Orin Nano
Hey everyone, I’m really stuck here and hoping someone can help. I recently got an AR0234 camera for my Jetson Orin Nano Developer Kit. I’m running JetPack 6.2 with JetVariety already installed. The camera is detected and I’m getting video — but it’s completely gray. No color at all. Just grayscale. I’ve been trying for so long to get a proper color feed and nothing works.
Can you share a bit more about your setup? What are you using to capture the video stream — are you going through GStreamer, v4l2, or something else? Also, can you confirm the output of v4l2-ctl --list-formats-ext for the camera device? That’ll help us see what pixel formats are being advertised.
Sure, here’s what I’m seeing. I’ve tried both GStreamer with nvarguscamerasrc and directly reading from /dev/video0 with v4l2. Regardless of what I do, the output is always monochrome. The pixel format shows up as GREY or sometimes a raw Bayer format depending on how I query it. The camera was literally advertised as “For Nvidia Jetson” and “Color Global shutter” on the product page. I paid around 100€ plus another 30€ in import fees. I have a project deadline coming up and this is really frustrating. What am I missing here?
I understand the frustration — let me explain what’s happening here. The gray image you’re seeing is actually the camera’s raw sensor output. Think of it like a digital negative from a DSLR: all the color information is there, but it hasn’t been “developed” yet. The AR0234 uses a Bayer-pattern color filter array, which means every pixel only captures one color channel (red, green, or blue). To get a proper color image, you need an ISP (Image Signal Processor) to perform demosaicing, white balance, color correction, and all the other processing steps. The Jetson Orin Nano doesn’t have a native ISP that supports this particular sensor out of the box, so what you’re seeing is the unprocessed raw data — which looks gray. This camera model is really aimed at technical users who want to build their own ISP pipeline for maximum control.
Okay, that makes sense technically, but I have to be honest — I bought this specifically because the product page said “For Nvidia Jetson” and “Color Global shutter.” It didn’t say anywhere that I’d need to build my own ISP pipeline from scratch just to see a color image. I’m on a tight deadline and I’ve already sunk money into this. Is there really no way to get a color video stream without writing a whole image processing stack myself?
I hear you, and I appreciate you sharing the screenshot of the product page — that’s useful feedback. Let me give you the practical options. The standard AR0234 module you have will always output raw Bayer data over MIPI. There’s no firmware toggle or driver setting that will suddenly give you processed color frames. You’ve essentially got two paths forward: Option 1 is implementing a software ISP pipeline on the Jetson yourself — you’d capture the raw Bayer frames and run them through something like libcamera with a custom tuning file, or use OpenCV’s cvtColor with Bayer demosaicing as a basic starting point (though that won’t give you proper color balance, it’s just demosaicing). This is non-trivial and takes significant tuning. Option 2 is the Arducam X-ISP Swift variant of the AR0234 — it’s the same sensor but with a built-in hardware ISP that’s pre-tuned for the Jetson platform. It does all the processing on the camera itself and sends a ready-to-use color stream directly over the MIPI port. You can find it here: Arducam xISP - Swift, Pre-tuned ISP, Global shutter 2.3MP MIPI Camera for NVIDIA® Jetson™ ORIN™ NX / Orin™ Nano / Renesas RZ/V2H
Thanks for the detailed explanation. So just to be absolutely clear — there’s no software-only fix for the camera I already have? No driver update, no config change, nothing? I really can’t afford to buy another camera right now after what I’ve already spent.
Correct — there’s no software-only fix for the standard AR0234 module you have. The hardware itself outputs raw sensor data and that’s all it can do. To summarize where things stand: the standard AR0234 camera module gives you raw Bayer-pattern frames, which inherently look grayscale without ISP processing. The Jetson Orin Nano lacks a native ISP for this sensor, so no out-of-the-box color pipeline exists. Your options are either to build a custom software ISP pipeline on the Jetson (complex, but doable if you have the time and expertise), or switch to the X-ISP variant which handles it in hardware. If you want to try the software route as a stopgap for your deadline, I can point you toward some resources for basic Bayer demosaicing with OpenCV on Jetson — just know it won’t be production-quality color without serious tuning. Let me know which direction you want to explore.
