I bought an AR0134 module in monochrome configuration. When using the sample application included in the SDK I see a checkerboard pattern in my images though.
The mode is set to “Mono” but the artefacts are still clearly visible.
Does anybody know what can cause this and how I could eliminate the pattern?
It’s a monochrome one so there should not be multiple channels that can be adjusted, right? Especially with a Mono setting I expect a camera to deliver images that do not show this effect.
This I don’t understand. How can a monochrome sensor have 4 channels (and even if true then why are they showing up when using a MONO profile)?
The bayer filter in front of a color camera still only causes the raw sensor values to be 12bit without any channel - any channel modifications like gain should be virtual and not have an effect on the actual sensor values.
I am a beginner with this type of cameras but this seems really strange to me.
How can the channels be adjusted with the sample application that comes with the Arducam kit?
