Amazon -
Arducam 16 MP Autofocus Camera, -
Raspberry Pi 4 Model B 8GB with Linux 11 ( Bullseye), Kernel 5.10.92-v7l+ -
Quick Start - Arducam Wiki -
libcamera-vid and libcamera-still are working with full resolution (4654x3496) in raw resolution (–mode 4656:3496). However, the autofocus is always failing. I have tried --autofocus-mode continuous (as well as auto) and given ‘f’ as keypress. When using --info-text to see %afstate, %lp and %focus, it shows that on pressing ‘f’, the camera scans starting from lens position 0 all the way to 10. However, it always fails the scan, no matter if I change the object under camera to far-distance (2 m) or very close (~11 cm). I have tried manually changing the focus length by using Pivariety FocuserExample.py and it does change the focus to a very sharp image. However, running it in autofocus mode from libcamera-still or libcamera-vid, it is never a sharp image and camera ‘failed’ to scan (as per %afstate). -
What is the camera failing to autofocus and what can be done to make it focus correctly?
Hi @hassaniqbal209 ,
Try this:
