Aducam Multi Camera Adapter V2.2 Does Not Connect Via I2C
I have been trying for a day now to figure out how to get the Multi Camera Adapter to connect to my Pi 4B. I am using a V2.2 board. It is new as is the Pi 4b. All drivers are loaded from GitHub. Followed all instructions. Tried all trouble shooting I could find online. Board is connected properly and all ribbon cables have been checked installed properly and working (check cables with a single camera that was not connected to the adapter board). Any suggestions? I am rather new at this. Thanks in advance.
Test i2c1
Shows a 70 in spot 0 of row 70. That is all.
Adapter board V2.1 configure OK
v4l2 driver install OK
Can’t find video0 device, please check the hardware connection.
I am using the new Pi HQ 12MP cameras in slots A and C.
Daniel
Little bit of follow up:
When trying the sudo ./init_camera.sh command in the terminal, I get the following on the test i2c1:
Line 10: 1a in the a column
Line 60: 64 in the 4 column
Line 70: 70 in the 0 column.
Still fails to find video0 device.
Regards,
Daniel
Don’t worry. I will test it today and reply you as soon as possible.
I know the problem, For the new 12mp sensor, our firmware can’t support the new sensor id. So after detect each channel, it will open the fourth channel (D channel) default. So you should ensure you have connect a sensor to the camera D. You can connect the camera to A and D or C and D.
