Hi, I want to record 64mp full resolution image using arducam_64mp_camera. When i tried with libcamera-vid then the output video is only 1280x720. How can i Record 64mp video.
There are parameter settings
“–width”
“–height”
such like
libcamera-vid --width 9152 --height 6944
You can check more parameters, there are many interesting settings
libcamera-vid --help
When I used this setting. This following error occurred.
ERROR V4L2 v4l2_videodevice.cpp:1248 /dev/video21[15:cap]: Not enough buffers provided by V4L2VideoDevice
I’m using RPi 4 8GB
yes I tried, As you can see here
And I got this error.
please let me know, how to solve this problem to capture 64mp Video.
Can you lower your monitor resolution?
Reduce screen resolution to 600x800
another attempt:
“Adding “alloc_in_cma_threshold=16” in /boot/cmdline.txt”
then reboot
Thanks for your response @Edward . The cmdline.txt file already have this line and I’m using Raspberry pi in CLI mode so resolution will not effect I guess. If you want access to SSH then I’m happy to do so.
