64MP OwlSight OV64A40 streams 30fps but not 15fps video
    Arducam Store on Amazon
  2. Model number of the product(s).
    OwlSight OV64A40
    Raspberry Pi 4B 4GB with 32-bit lite OS
    64MP OwlSight Arducam wiki
  5. Problems you were having.
I am trying to initiate an rtsp stream with the OwlSight OV64A40 using a combination of libcamera-vid and ffmpeg using the following command:
nohup libcamera-vid -t 0 --inline --width 1920 --height 1080 --framerate 15 -o - | ffmpeg -i - -c copy -f rtsp rtsp://localhost:8554/stream > stream.log 2>&1 &
but the above only generates a still frame when viewing in VLC. However, when using 30fps with the same command:
nohup libcamera-vid -t 0 --inline --width 1920 --height 1080 --framerate 30 -o - | ffmpeg -i - -c copy -f rtsp rtsp://localhost:8554/stream > stream.log 2>&1 &
It works just fine? The reason I am aiming for lower fps is the increased exposure, as I find that this camera’s video stream doesn’t really do that well in low light.
  1. The dmesg log from your hardware.
    N/A
  2. Troubleshooting attempts you’ve made.
    Increasing ffmpeg probe size to 10 seconds, adjusting libcamera-vid shutter directly
  3. What help do you need?
    A way to reliably stream the OwlSight at 15fps, or at least somehow increase the exposure so that a 1080p stream isn’t so bad under low light conditions.
