Just made a fresh install of rasbian desktop x64 on brand new raspberry pi 5.
I have an arducam 64mp sensor.
i’ve tried both sockets on the board
I’ve gotten it to the point of a positive dmesg saying it detects the camera
i used the standard arducam quickstart guide
i tried setting the autodetect to 0
Current config:
only change is dtoverlay=arducam-64mp
Some logs below:
Please help me I have tried absolutely everything I can find online.
pi@ethan:~ $ sudo nano /boot/firmware/config.txt
pi@ethan:~ $ dmesg | grep arducam
[ 0.563569] platform 1f00128000.csi: Fixed dependency cycle(s) with /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 2.393337] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 2.654596] arducam_64mp 4-001a: Device found Arducam 64MP.
[ 2.657721] rp1-cfe 1f00128000.csi: Using sensor arducam_64mp 4-001a for capture
pi@ethan:~ $ libcamera-still -o test.jpeg
[0:01:01.013294888] [1550] INFO Camera camera_manager.cpp:327 libcamera v0.4.0+78-818d45eb-dirty (2025-02-14T02:03:07GMT)
[0:01:01.021924777] [1555] INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
Segmentation fault
pi@ethan:~ $ libcamera-still -t 0
[0:01:10.864190309] [1660] INFO Camera camera_manager.cpp:327 libcamera v0.4.0+78-818d45eb-dirty (2025-02-14T02:03:07GMT)
[0:01:10.872160536] [1910] INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
Segmentation fault
pi@ethan:~ $ libcamera-vid
[0:01:32.233983719] [1943] INFO Camera camera_manager.cpp:327 libcamera v0.4.0+78-818d45eb-dirty (2025-02-14T02:03:07GMT)
[0:01:32.241682249] [1946] INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
Segmentation fault
pi@ethan:~ $ libcamera-hello --list-cameras
No cameras available!
Hi @Dion Thank you for your quick response. Here is the output:
pi@ethan:~ $ cat /boot/firmware/config.txt
# http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
LIBCAMERA_LOG_LEVELS=*:DEBUG
dtparam=audio=on
camera_auto_detect=0
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
pi@ethan:~ $ uname -a
Linux ethan 6.6.51+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08) aarch64 GNU/Linux
pi@ethan:~ $
pi@ethan:~ $ ls /dev/video0
/dev/video0
pi@ethan:~ $
pi@ethan:~ $ dpkg -l | grep libcamera
ii libcamera-dev:arm64 0.5.0+rpt20250429-1 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.5.0+rpt20250429-1 arm64 complex camera support library (IPA modules)
ii libcamera0.4:arm64 0.4.0+rpt20250214-1 arm64 complex camera support library
ii libcamera0.5:arm64 0.5.0+rpt20250429-1 arm64 complex camera support library
ii python3-libcamera:arm64 0.5.0+rpt20250429-1 arm64 complex camera support library (Python bindings)
pi@ethan:~ $
