Hello to all,
I want to streaming a video from raspberry pi to Jetson nano.
I am using a libcamera-vid library for that which is in this website for streaming:
I am using a UDP to streaming and I am running this command to raspberry pi:
“libcamera-vid -t 0 --codec h264 --inline -o udp://192.168.1.205:8554”
so it run well but at the client side(Jetson nano) t run this command to recieve data:
“vlc --codec h264 udp://@:8554 :demux=h264”
but i got error:
VLC media player 3.0.8 Vetinari (revision 3.0.8-0-gf350b6b5a7)
[000000557653d580] main libvlc: Running vlc with the default interface. Use ‘cvlc’ to use vlc without interface.
[0000007f400015b0] udp stream error: 2629 bytes packet truncated (MTU was 1316)
[0000007f40011500] h26x demux error: this doesn’t look like a h264 ES stream, continuing anyway
[0000007f40002ec0] main stream error: unknown query 0x30e in demux_vaControlHelper
QXcbConnection: XCB error: 148 (Unknown), sequence: 173, resource id: 0, major code: 140 (Unknown), minor code: 20
[0000007f400015b0] udp stream error: 2665 bytes packet truncated (MTU was 2629)
[0000007f400015b0] udp stream error: 2666 bytes packet truncated (MTU was 2665)
[0000007f400015b0] udp stream error: 4004 bytes packet truncated (MTU was 2666)
Bus error (core dumped)
anyone face this problem already so please help me to solve this problem.
Thanks in advance…
