64mp: failed to read chip id 4136, with error -5
    pi-shop.ch
    64mp arducam
    RPI 4B Rev 1.4
    manual and troubleshooting
  5. Problems you were having?
    installed everything on another RPI 4B and worked fine for two weeks but after a kernel update i got errors and I was not able to open preview window anymore.
    Installed everthing on the new device but cant find the camera.
    dmesg shows an issue with the I2C and i get the error: failed to read chip id 4136, with error -5
    [ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
    [ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
    [ 0.000000] Normal empty
    [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [ 0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
    [ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
    [ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
    [ 0.000000] CPU features: detected: Spectre-v3a
    [ 0.000000] CPU features: detected: ARM erratum 1742098
    [ 0.000000] alternatives: applying boot alternatives
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 983808
    [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1200M@60 smsc95xx.macaddr=E4:5F:01:5C:EC:A8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=0e6d6e80-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [ 0.000000] software IO TLB: area num 4.
    [ 0.000000] software IO TLB: mapped [mem 0x0000000034000000-0x0000000038000000] (64MB)
    [ 0.000000] Memory: 3305848K/3997696K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 167560K reserved, 524288K cma-reserved)
    [ 0.000000] ftrace: allocating 39744 entries in 156 pages
    [ 0.000000] ftrace: allocated 156 pages with 4 groups
    [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [ 0.000353] Console: colour dummy device 80x25
    [ 0.000424] printk: console [tty1] enabled
    [ 0.000491] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
    [ 0.000522] pid_max: default: 32768 minimum: 301
    [ 0.000649] LSM: Security Framework initializing
    [ 0.000889] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [ 0.000974] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [ 0.002355] cgroup: Disabling memory control group subsystem
    [ 0.004754] cblist_init_generic: Setting adjustable number of callback queues.
    [ 0.004774] cblist_init_generic: Setting shift to 2 and lim to 1.
    [ 0.004959] cblist_init_generic: Setting shift to 2 and lim to 1.
    [ 0.005138] cblist_init_generic: Setting shift to 2 and lim to 1.
    [ 0.005627] rcu: Hierarchical SRCU implementation.
    [ 0.005641] rcu: Max phase no-delay instances is 1000.
    [ 0.007012] EFI services will not be available.
    [ 0.007572] smp: Bringing up secondary CPUs …
    [ 0.008794] Detected PIPT I-cache on CPU1
    [ 0.008969] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
    [ 0.010160] Detected PIPT I-cache on CPU2
    [ 0.010287] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
    [ 0.011431] Detected PIPT I-cache on CPU3
    [ 0.011561] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
    [ 0.011712] smp: Brought up 1 node, 4 CPUs
    [ 0.011735] SMP: Total of 4 processors activated.
    [ 0.011748] CPU features: detected: 32-bit EL0 Support
    [ 0.011757] CPU features: detected: 32-bit EL1 Support
    [ 0.011770] CPU features: detected: CRC32 instructions
    [ 0.011964] CPU: All CPU(s) started at EL2
    [ 0.011991] alternatives: applying system-wide alternatives
    [ 0.013992] devtmpfs: initialized
    [ 0.026808] Enabled cp15_barrier support
    [ 0.026854] Enabled setend support
    [ 0.027078] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.027113] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [ 0.042414] pinctrl core: initialized pinctrl subsystem
    [ 0.043399] DMI not present or invalid.
    [ 0.044190] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [ 0.047854] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [ 0.048196] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.049152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.049254] audit: initializing netlink subsys (disabled)
    [ 0.049542] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
    [ 0.050178] thermal_sys: Registered thermal governor ‘step_wise’
    [ 0.050271] cpuidle: using governor menu
    [ 0.050700] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.050903] ASID allocator initialised with 32768 entries
    [ 0.051072] Serial: AMBA PL011 UART driver
    [ 0.063740] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [ 0.072756] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_64mp@1a
    [ 0.080397] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:51:33, variant start_x
    [ 0.084411] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
    [ 0.100644] KASLR enabled
    [ 0.131972] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [ 0.137871] SCSI subsystem initialized
    [ 0.138164] usbcore: registered new interface driver usbfs
    [ 0.138226] usbcore: registered new interface driver hub
    [ 0.138295] usbcore: registered new device driver usb
    [ 0.138657] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [ 0.138884] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
    [ 0.139259] pps_core: LinuxPPS API ver. 1 registered
    [ 0.139273] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
    [ 0.139301] PTP clock support registered
    [ 0.140494] vgaarb: loaded
    [ 0.141450] clocksource: Switched to clocksource arch_sys_counter
    [ 0.142172] VFS: Disk quotas dquot_6.6.0
    [ 0.142259] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.142447] FS-Cache: Loaded
    [ 0.142622] CacheFiles: Loaded
    [ 0.152066] NET: Registered PF_INET protocol family
    [ 0.153029] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [ 0.157894] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [ 0.158063] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [ 0.158095] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [ 0.158355] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [ 0.159583] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.159888] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [ 0.159995] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [ 0.160366] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [ 0.161294] RPC: Registered named UNIX socket transport module.
    [ 0.161314] RPC: Registered udp transport module.
    [ 0.161324] RPC: Registered tcp transport module.
    [ 0.161335] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.161361] PCI: CLS 0 bytes, default 64
    [ 0.164090] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [ 0.164519] kvm [1]: IPA Size Limit: 44 bits
    [ 0.165974] kvm [1]: vgic interrupt IRQ9
    [ 0.166216] kvm [1]: Hyp mode initialized successfully
    [ 1.309092] Initialise system trusted keyrings
    [ 1.309666] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [ 1.317691] zbud: loaded
    [ 1.320807] NFS: Registering the id_resolver key type
    [ 1.320851] Key type id_resolver registered
    [ 1.320862] Key type id_legacy registered
    [ 1.320984] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
    [ 1.321001] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
    [ 1.322532] Key type asymmetric registered
    [ 1.322552] Asymmetric key parser ‘x509’ registered
    [ 1.322637] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [ 1.322946] io scheduler mq-deadline registered
    [ 1.322963] io scheduler kyber registered
    [ 1.332366] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [ 1.332417] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [ 1.332507] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
    [ 1.332592] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00ffffffff → 0x0400000000
    [ 1.333682] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [ 1.333702] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 1.333720] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [ 1.333803] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [ 1.334066] pci 0000:00:00.0: PME# supported from D0 D3hot
    [ 1.338304] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
    [ 1.338493] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
    [ 1.338621] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
    [ 1.403542] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [ 1.403714] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [ 1.403844] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [ 1.404328] pci 0000:01:00.0: PME# supported from D0 D3hot
    [ 1.405124] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [ 1.405152] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [ 1.405198] pci 0000:00:00.0: PCI bridge to [bus 01]
    [ 1.405220] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
    [ 1.406587] simple-framebuffer 3e330000.framebuffer: framebuffer at 0x3e330000, 0x8ca000 bytes
    [ 1.406607] simple-framebuffer 3e330000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [ 1.407265] Console: switching to colour frame buffer device 240x75
    [ 1.417775] simple-framebuffer 3e330000.framebuffer: fb0: simplefb registered!
    [ 1.429739] iproc-rng200 fe104000.rng: hwrng registered
    [ 1.430260] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [ 1.431742] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [ 1.445586] brd: module loaded
    [ 1.454802] loop: module loaded
    [ 1.455669] Loading iSCSI transport class v2.0-870.
    [ 1.461277] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [ 1.521613] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [ 1.522835] usbcore: registered new interface driver r8152
    [ 1.522928] usbcore: registered new interface driver lan78xx
    [ 1.522992] usbcore: registered new interface driver smsc95xx
    [ 1.571160] pci 0000:00:00.0: enabling device (0000 → 0002)
    [ 1.571361] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [ 1.571398] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [ 1.572220] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
    [ 1.573333] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [ 1.573355] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [ 1.573378] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [ 1.573838] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
    [ 1.573859] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 1.573874] usb usb1: Product: xHCI Host Controller
    [ 1.573887] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
    [ 1.573900] usb usb1: SerialNumber: 0000:01:00.0
    [ 1.574677] hub 1-0:1.0: USB hub found
    [ 1.574750] hub 1-0:1.0: 1 port detected
    [ 1.575709] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
    [ 1.575730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 1.575745] usb usb2: Product: xHCI Host Controller
    [ 1.575758] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
    [ 1.575770] usb usb2: SerialNumber: 0000:01:00.0
    [ 1.576466] hub 2-0:1.0: USB hub found
    [ 1.576561] hub 2-0:1.0: 4 ports detected
    [ 1.578392] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [ 1.578690] dwc_otg: FIQ enabled
    [ 1.578701] dwc_otg: NAK holdoff enabled
    [ 1.578711] dwc_otg: FIQ split-transaction FSM enabled
    [ 1.578733] Module dwc_common_port init
    [ 1.579340] usbcore: registered new interface driver uas
    [ 1.579451] usbcore: registered new interface driver usb-storage
    [ 1.579697] mousedev: PS/2 mouse device common for all mice
    [ 1.586346] sdhci: Secure Digital Host Controller Interface driver
    [ 1.586367] sdhci: Copyright(c) Pierre Ossman
    [ 1.586971] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 1.590553] ledtrig-cpu: registered to indicate activity on CPUs
    [ 1.590924] hid: raw HID events driver (C) Jiri Kosina
    [ 1.591174] usbcore: registered new interface driver usbhid
    [ 1.591188] usbhid: USB HID core driver
    [ 1.600588] NET: Registered PF_PACKET protocol family
    [ 1.600726] Key type dns_resolver registered
    [ 1.602259] registered taskstats version 1
    [ 1.602358] Loading compiled-in X.509 certificates
    [ 1.603288] Key type .fscrypt registered
    [ 1.603303] Key type fscrypt-provisioning registered
    [ 1.619449] uart-pl011 fe201000.serial: there is not valid maps for state default
    [ 1.620233] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [ 1.620417] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 35, base_baud = 0) is a PL011 rev2
    [ 1.629913] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [ 1.630413] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [ 1.631765] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [ 1.631785] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [ 1.662782] of_cfs_init
    [ 1.662925] of_cfs_init: OK
    [ 1.696897] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
    [ 1.697497] Waiting for root device PARTUUID=0e6d6e80-02…
    [ 1.749406] mmc1: new high speed SDIO card at address 0001
    [ 1.796799] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
    [ 1.797958] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
    [ 1.802562] mmcblk0: p1 p2
    [ 1.803187] mmcblk0: mmc0:aaaa SC16G 14.8 GiB (quirks 0x00004000)
    [ 1.823264] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [ 1.823366] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [ 1.824122] devtmpfs: mounted
    [ 1.829533] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [ 1.834359] Freeing unused kernel memory: 4160K
    [ 1.834581] Run /sbin/init as init process
    [ 1.834592] with arguments:
    [ 1.834602] /sbin/init
    [ 1.834612] splash
    [ 1.834621] with environment:
    [ 1.834630] HOME=/
    [ 1.834639] TERM=linux
    [ 1.980116] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [ 1.980157] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [ 1.980173] usb 1-1: Product: USB2.0 Hub
    [ 1.982667] hub 1-1:1.0: USB hub found
    [ 1.982910] hub 1-1:1.0: 4 ports detected
    [ 2.195589] systemd[1]: System time before build time, advancing clock.
    [ 2.277512] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd
    [ 2.376228] NET: Registered PF_INET6 protocol family
    [ 2.378374] Segment Routing with IPv6
    [ 2.378430] In-situ OAM (IOAM) with IPv6
    [ 2.386125] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
    [ 2.386162] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 2.386178] usb 1-1.2: Product: Lenovo USB Optical Mouse
    [ 2.386193] usb 1-1.2: Manufacturer: PixArt
    [ 2.396703] input: PixArt Lenovo USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input0
    [ 2.397299] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-0000:01:00.0-1.2/input0
    [ 2.460400] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [ 2.461519] systemd[1]: Detected architecture arm64.
    [ 2.471145] systemd[1]: Set hostname to .
    [ 2.477491] usb 1-1.3: new high-speed USB device number 4 using xhci_hcd
    [ 2.687923] usb 1-1.3: New USB device found, idVendor=24a9, idProduct=1302, bcdDevice= 2.00
    [ 2.687966] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 2.687983] usb 1-1.3: Product: USB Flash Disk
    [ 2.687999] usb 1-1.3: Manufacturer: UPen
    [ 2.688012] usb 1-1.3: SerialNumber: 3HAC038143-0000000000582
    [ 2.691195] usb-storage 1-1.3:1.0: USB Mass Storage device detected
    [ 2.692033] scsi host0: usb-storage 1-1.3:1.0
    [ 2.773505] usb 1-1.4: new low-speed USB device number 5 using xhci_hcd
    [ 2.887461] usb 1-1.4: New USB device found, idVendor=17ef, idProduct=608c, bcdDevice= 1.14
    [ 2.887502] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [ 2.887519] usb 1-1.4: Product: Lenovo Calliope USB Keyboard
    [ 2.887533] usb 1-1.4: Manufacturer: LiteOn
    [ 2.899692] input: LiteOn Lenovo Calliope USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:17EF:608C.0002/input/input1
    [ 2.958431] hid-generic 0003:17EF:608C.0002: input,hidraw1: USB HID v1.11 Keyboard [LiteOn Lenovo Calliope USB Keyboard] on usb-0000:01:00.0-1.4/input0
    [ 2.967332] input: LiteOn Lenovo Calliope USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:17EF:608C.0003/input/input2
    [ 3.025976] input: LiteOn Lenovo Calliope USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:17EF:608C.0003/input/input3
    [ 3.026385] hid-generic 0003:17EF:608C.0003: input,hidraw2: USB HID v1.11 Device [LiteOn Lenovo Calliope USB Keyboard] on usb-0000:01:00.0-1.4/input1
    [ 3.085794] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
    [ 3.227912] systemd[1]: Queued start job for default target Graphical Interface.
    [ 3.251284] systemd[1]: Created slice system-getty.slice.
    [ 3.252697] systemd[1]: Created slice system-modprobe.slice.
    [ 3.253772] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [ 3.254673] systemd[1]: Created slice User and Session Slice.
    [ 3.255213] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 3.256355] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [ 3.256817] systemd[1]: Reached target Slices.
    [ 3.256955] systemd[1]: Reached target Swap.
    [ 3.258091] systemd[1]: Listening on Syslog Socket.
    [ 3.258844] systemd[1]: Listening on fsck to fsckd communication Socket.
    [ 3.259244] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ 3.260492] systemd[1]: Listening on Journal Audit Socket.
    [ 3.261280] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 3.262330] systemd[1]: Listening on Journal Socket.
    [ 3.269684] systemd[1]: Listening on udev Control Socket.
    [ 3.270540] systemd[1]: Listening on udev Kernel Socket.
    [ 3.271540] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [ 3.290059] systemd[1]: Mounting POSIX Message Queue File System…
    [ 3.295304] systemd[1]: Mounting RPC Pipe File System…
    [ 3.301626] systemd[1]: Mounting Kernel Debug File System…
    [ 3.307930] systemd[1]: Mounting Kernel Trace File System…
    [ 3.308521] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [ 3.318883] systemd[1]: Starting Restore / save the current clock…
    [ 3.328001] systemd[1]: Starting Set the console keyboard layout…
    [ 3.334737] systemd[1]: Starting Create list of static device nodes for the current kernel…
    [ 3.341400] systemd[1]: Starting Load Kernel Module configfs…
    [ 3.348221] systemd[1]: Starting Load Kernel Module drm…
    [ 3.355294] systemd[1]: Starting Load Kernel Module fuse…
    [ 3.361808] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [ 3.373006] systemd[1]: Starting File System Check on Root Device…
    [ 3.398478] systemd[1]: Starting Journal Service…
    [ 3.414571] systemd[1]: Starting Load Kernel Modules…
    [ 3.424228] fuse: init (API version 7.37)
    [ 3.428601] systemd[1]: Starting Coldplug All udev Devices…
    [ 3.457786] systemd[1]: Mounted POSIX Message Queue File System.
    [ 3.458901] systemd[1]: Mounted RPC Pipe File System.
    [ 3.459851] systemd[1]: Mounted Kernel Debug File System.
    [ 3.460800] systemd[1]: Mounted Kernel Trace File System.
    [ 3.463321] systemd[1]: Finished Restore / save the current clock.
    [ 3.468748] systemd[1]: Finished Create list of static device nodes for the current kernel.
    [ 3.479514] systemd[1]: [email protected]: Succeeded.
    [ 3.481875] systemd[1]: Finished Load Kernel Module configfs.
    [ 3.484475] systemd[1]: [email protected]: Succeeded.
    [ 3.486340] systemd[1]: Finished Load Kernel Module fuse.
    [ 3.519373] i2c_dev: i2c /dev entries driver
    [ 3.530325] systemd[1]: Mounting FUSE Control File System…
    [ 3.538253] systemd[1]: Mounting Kernel Configuration File System…
    [ 3.546900] systemd[1]: Started File System Check Daemon to report status.
    [ 3.582484] systemd[1]: [email protected]: Succeeded.
    [ 3.584140] systemd[1]: Finished Load Kernel Module drm.
    [ 3.602301] systemd[1]: Finished Load Kernel Modules.
    [ 3.603516] systemd[1]: Mounted FUSE Control File System.
    [ 3.604192] systemd[1]: Mounted Kernel Configuration File System.
    [ 3.630907] systemd[1]: Starting Apply Kernel Variables…
    [ 3.634684] systemd[1]: Finished File System Check on Root Device.
    [ 3.646498] systemd[1]: Starting Remount Root and Kernel File Systems…
    [ 3.702642] systemd[1]: Finished Apply Kernel Variables.
    [ 3.711834] scsi 0:0:0:0: Direct-Access UPen USB Flash Disk 0000 PQ: 0 ANSI: 4
    [ 3.715053] sd 0:0:0:0: [sda] 31641664 512-byte logical blocks: (16.2 GB/15.1 GiB)
    [ 3.717205] sd 0:0:0:0: [sda] Write Protect is off
    [ 3.717242] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
    [ 3.725889] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
    [ 3.736410] sda: sda1
    [ 3.737053] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [ 3.831346] systemd[1]: Started Journal Service.
    [ 4.325266] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [ 4.396460] systemd-journald[150]: Received client request to flush runtime journal.
    [ 4.412706] systemd-journald[150]: File /var/log/journal/855e69e2056d4b5abcec2655b89b3401/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [ 5.557008] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [ 5.697676] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [ 5.722447] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [ 5.722492] [vc_sm_connected_init]: start
    [ 5.737779] [vc_sm_connected_init]: installed successfully
    [ 5.738991] mc: Linux media interface: v0.10
    [ 5.857076] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [ 5.909747] videodev: Linux video capture interface: v2.00
    [ 5.990766] bcm2835_audio bcm2835_audio: card created with 4 channels
    [ 5.994503] i2c i2c-22: Added multiplexed i2c bus 0
    [ 6.029853] i2c i2c-22: Added multiplexed i2c bus 10
    [ 6.094059] bcm2835_audio bcm2835_audio: card created with 4 channels
    [ 6.149048] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [ 6.151203] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [ 6.163944] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [ 6.172640] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [ 6.218110] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [ 6.267339] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [ 6.267424] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [ 6.280362] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [ 6.280438] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [ 6.318777] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [ 6.327078] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [ 6.327182] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [ 6.359315] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    [ 6.359436] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    [ 6.405628] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [ 6.406597] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [ 6.407253] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [ 6.407766] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [ 6.407804] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [ 6.407842] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [ 6.407860] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [ 6.407877] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [ 6.428537] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
    [ 6.448037] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
    [ 6.454680] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
    [ 6.454779] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
    [ 6.458778] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
    [ 6.500175] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
    [ 6.500235] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [ 6.500262] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [ 6.500282] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [ 6.500300] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [ 6.512758] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [ 6.770485] Console: switching to colour dummy device 80x25
    [ 6.785196] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [ 7.013719] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [ 7.205736] Console: switching to colour frame buffer device 240x75
    [ 7.205819] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
    [ 7.522575] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
    [ 7.540708] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [ 7.541901] rpivid feb10000.codec: Device registered as /dev/video19
    [ 7.575190] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
    [ 7.601353] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    -Changed several things in config.txt
    -Freshly installed all the drivers
  8. What help do you need?
    Does someone know how to fix this?
    Rest of dmesg and config.txt follows after that post.
[ 8.051159] 8021q: 802.1Q VLAN Support v1.8
[ 8.110095] uart-pl011 fe201000.serial: no DMA platform data
[ 8.279918] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.300144] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.304170] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.682993] dw9807 10-000c: I2C write CTL fail ret = -121
[ 8.756645] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.792435] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.895057] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 8.966330] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 8.966382] dw9807 10-000c: dw9807_ramp I2C failure: -121
[ 8.984222] dw9807 10-000c: I2C write STATUS address fail ret = -121
[ 8.984275] dw9807 10-000c: dw9807_ramp I2C failure: -121
[ 8.984628] dw9807 10-000c: I2C write CTL fail ret = -121
[ 9.084893] arducam_64mp: probe of 10-001a failed with error -5
[ 9.183313] usbcore: registered new interface driver brcmfmac
[ 9.189387] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 9.809403] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.381632] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 12.381685] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.984893] Bluetooth: Core ver 2.22
[ 15.985324] NET: Registered PF_BLUETOOTH protocol family
[ 15.985340] Bluetooth: HCI device and connection manager initialized
[ 15.985362] Bluetooth: HCI socket layer initialized
[ 15.985370] Bluetooth: L2CAP socket layer initialized
[ 15.985388] Bluetooth: SCO socket layer initialized
[ 15.998054] Bluetooth: HCI UART driver ver 2.3
[ 15.998079] Bluetooth: HCI UART protocol H4 registered
[ 15.998159] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.998358] Bluetooth: HCI UART protocol Broadcom registered
[ 16.275259] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.275280] Bluetooth: BNEP filters: protocol multicast
[ 16.275296] Bluetooth: BNEP socket layer initialized
[ 16.280635] Bluetooth: MGMT ver 1.22
[ 16.293456] NET: Registered PF_ALG protocol family
[ 16.441758] Bluetooth: RFCOMM TTY layer initialized
[ 16.441802] Bluetooth: RFCOMM socket layer initialized
[ 16.441839] Bluetooth: RFCOMM ver 1.11
[ 18.034046] exFAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Config file:
Raspberry Pi Documentation - Configuration
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
DMT (computer monitor) modes
#hdmi_drive=2
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
dtoverlay=arducam-64mp
[pi4]
arm_boost=1
dtoverlay=vc4-fkms-v3d,cma-512
gpu_mem=128
@Chris3785
Before, I need some information
Please reboot your device and execute the following command:
This will output an arducam-bug-report.txt in the current directory.
Please send this file to me via google cloud disk or similar platform or email ([email protected])
And if possible, please send me the hardware connection diagram.
Thank you for your cooperation.
What was the resolution for this problem? I seem to have exactly the same problem.
$ dmesg | grep -i arducam
[    5.120985] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[    5.138911] arducam_64mp 4-001a: failed to read chip id 4136, with error -5
[    5.147482] arducam_64mp: probe of 4-001a failed with error -5
Many thanks for any suggestions.
Long time ago. Didn’t found a proper solution so in the end I ordered a new 16mp AF camera…
Im getting the same error, with the same hardware provider…
@Cchiang
Currently, the 64mp driver has been incorporated into the Raspberry Pi system.
Please refer to our official documentation. If there are any problems during the process, please provide detailed error information.
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Quick-Start-Guide/#arducam-pi-hawk-eye-64mp-cameras
Hei Edward
Sadly is not working
cat arducam-bug-report.txt
libcamera-apps Bug Report
Date: 06-02-2024 (09:38:43)
Command: ./arducam-camera-bug-report
Hardware information
** hostname **
raspberryb01
** uname -r **
6.1.0-rpi7-rpi-v8
** cat /proc/cpuinfo | tail -n 4 **
Revision        : c04170
Serial          : 6320bb675d14272b
Model           : Raspberry Pi 5 Model B Rev 1.0
libcamera verison
** sudo dpkg -l | grep libcamera **
ii  libcamera-dev:arm64                  0.1.0+rpt20231206-1              arm64        complex camera support library (development files)
ii  libcamera-ipa:arm64                  0.1.0+rpt20231206-1              arm64        complex camera support library (IPA modules)
ii  libcamera0.1:arm64                   0.1.0+rpt20231206-1              arm64        complex camera support library
ii  python3-libcamera                    0.1.0+rpt20231122-1              arm64        complex camera support library (Python bindings)
Camera detect
** ls /dev/video* **
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video24
/dev/video25
/dev/video26
/dev/video27
/dev/video28
/dev/video29
/dev/video30
/dev/video31
/dev/video32
/dev/video33
/dev/video34
/dev/video35
/dev/video36
/dev/video37
Configuration
** cat /boot/config.txt **
# http://rptl.io/configtxt
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
dtparam=i2c_vc
# This last one activate i2C-0 bus (where you connect the camera and RTC for example)
dtparam=audio=on
camera_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
kernel=kernel8.img
dtparam=i2c_arm=on
dtparam=pciex1
dtparam=pciex1_gen=3
** ls /boot/overlays/* | grep arducam **
/boot/overlays/arducam-64mp.dtbo
/boot/overlays/arducam-pivariety.dtbo
** ls /boot/overlays/* | grep imx **
/boot/overlays/imx219.dtbo
/boot/overlays/imx258.dtbo
/boot/overlays/imx290.dtbo
/boot/overlays/imx296.dtbo
/boot/overlays/imx327.dtbo
/boot/overlays/imx378.dtbo
/boot/overlays/imx462.dtbo
/boot/overlays/imx477.dtbo
/boot/overlays/imx519.dtbo
/boot/overlays/imx708.dtbo
** ls /lib/modules/$(uname -r)/kernel/drivers/media/i2c **
ad5398_vcm.ko.xz
adv7180.ko.xz
ak7375.ko.xz
arducam_64mp.ko.xz
arducam-pivariety.ko.xz
cs53l32a.ko.xz
cx25840
dw9807-vcm.ko.xz
imx219.ko.xz
imx258.ko.xz
imx290.ko.xz
imx296.ko.xz
imx477.ko.xz
imx519.ko.xz
imx708.ko.xz
ir-kbd-i2c.ko.xz
irs1125.ko.xz
msp3400.ko.xz
mt9v011.ko.xz
ov2311.ko.xz
ov5647.ko.xz
ov7251.ko.xz
ov7640.ko.xz
ov9281.ko.xz
saa7115.ko.xz
sony-btf-mpx.ko.xz
tc358743.ko.xz
tvp5150.ko.xz
tw2804.ko.xz
tw9903.ko.xz
tw9906.ko.xz
uda1342.ko.xz
video-i2c.ko.xz
wm8775.ko.xz
** i2cdetect -y -r 10 **
Error: Could not open file `/dev/i2c-10' or `/dev/i2c/10': No such file or directory
Memory
** cat /proc/meminfo | grep Cma **
CmaTotal:         327680 kB
CmaFree:          311248 kB
Cameras
** libcamera-still --list-cameras **
No cameras available!
Versions
** uname -a **
Linux raspberryb01 6.1.0-rpi7-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
** cat /etc/os-release **
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
libcamera-still -n -t 1000 -o arducam-test.jpg --width 1920 --height 1080
[0:21:52.345603587] [1100]  INFO Camera camera_manager.cpp:284 libcamera v0.1.0+147-057299d0-dirty (2024-01-24T08:51:15+00:00)
Logs
** ls -lh arducam-test.jpg **
ls: cannot access 'arducam-test.jpg': No such file or directory
** dmesg | grep arducam **
[    5.899273] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[    6.493169] arducam_64mp 4-001a: failed to read chip id 4136, with error -5
[    6.494877] arducam_64mp: probe of 4-001a failed with error -5
** dmesg | grep imx **
** dmesg | grep ov9281 **
What I have learn so far (please confirm)
  • You should definetly not upgrade bookworm as your latest kernel support is 6.1.63
  • Rpi5 do not use i2c 10 but rather 4 . Could be that a problem?
  • Raspberry 5 do not use video0 anymore. Could be that a problem?
  • Your install_driver.sh have a typo if im not wrong. it should be -v8-16k and not v8_16k (not important in my case as im using kernel8 )
The missing part of the report (part 1/2)
** dmesg **
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.1.0-rpi7-rpi-v8 ([email protected]) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24)
[    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001a400000, size 320 MiB
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000] On node 0, zone DMA: 1024 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 29 pages/cpu s79144 r8192 d31448 u118784
[    0.000000] pcpu-alloc: s79144 r8192 d31448 u118784 alloc=29*4096
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1031168
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BC:E1:BC vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=56e2cdf5-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=CH
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] Memory: 3746188K/4190208K available (12352K kernel code, 2172K rwdata, 4076K rodata, 4288K init, 1082K bss, 116340K reserved, 327680K cma-reserved)
[    0.000000] ftrace: allocating 40060 entries in 157 pages
[    0.000000] ftrace: allocated 157 pages with 5 groups
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000157] Console: colour dummy device 80x25
[    0.000304] printk: console [tty1] enabled
[    0.000323] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000333] pid_max: default: 32768 minimum: 301
[    0.000366] LSM: Security Framework initializing
[    0.000428] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000443] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000848] cgroup: Disabling memory control group subsystem
[    0.001374] cblist_init_generic: Setting adjustable number of callback queues.
[    0.001386] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.001427] cblist_init_generic: Setting adjustable number of callback queues.
[    0.001433] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.001469] cblist_init_generic: Setting adjustable number of callback queues.
[    0.001474] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.001573] rcu: Hierarchical SRCU implementation.
[    0.001578] rcu:     Max phase no-delay instances is 1000.
[    0.002220] EFI services will not be available.
[    0.002350] smp: Bringing up secondary CPUs ...
[    0.002612] Detected PIPT I-cache on CPU1
[    0.002663] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.002934] Detected PIPT I-cache on CPU2
[    0.002972] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.003222] Detected PIPT I-cache on CPU3
[    0.003257] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.003294] smp: Brought up 1 node, 4 CPUs
[    0.003314] SMP: Total of 4 processors activated.
[    0.003319] CPU features: detected: 32-bit EL0 Support
[    0.003324] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.003330] CPU features: detected: Common not Private translations
[    0.003335] CPU features: detected: CRC32 instructions
[    0.003340] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.003344] CPU features: detected: LSE atomic instructions
[    0.003348] CPU features: detected: Privileged Access Never
[    0.003353] CPU features: detected: RAS Extension Support
[    0.003358] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.003400] CPU: All CPU(s) started at EL2
[    0.003405] alternatives: applying system-wide alternatives
[    0.005366] devtmpfs: initialized
[    0.008414] Enabled cp15_barrier support
[    0.008425] Enabled setend support
[    0.008483] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.008495] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.011948] pinctrl core: initialized pinctrl subsystem
[    0.012150] DMI not present or invalid.
[    0.012322] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.013029] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.013115] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.013305] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.013329] audit: initializing netlink subsys (disabled)
[    0.013390] audit: type=2000 audit(0.012:1): state=initialized audit_enabled=0 res=1
[    0.013529] thermal_sys: Registered thermal governor 'step_wise'
[    0.013548] cpuidle: using governor menu
[    0.013610] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.013653] ASID allocator initialised with 32768 entries
[    0.013943] Serial: AMBA PL011 UART driver
[    0.015727] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.016447] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[    0.720616] printk: console [ttyAMA10] enabled
[    0.733090] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-01-05T15:57:40, variant start_cd
[    0.747150] raspberrypi-firmware soc:firmware: Firmware hash is 30cc5f3700000000000000000000000000000000
[    0.765683] KASLR enabled
[    0.776019] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.784205] iommu: Default domain type: Translated
[    0.789106] iommu: DMA domain TLB invalidation policy: strict mode
[    0.795508] SCSI subsystem initialized
[    0.799318] usbcore: registered new interface driver usbfs
[    0.804835] usbcore: registered new interface driver hub
[    0.810176] usbcore: registered new device driver usb
[    0.815350] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.822513] pps_core: LinuxPPS API ver. 1 registered
[    0.827497] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.836676] PTP clock support registered
[    0.840840] vgaarb: loaded
[    0.843672] clocksource: Switched to clocksource arch_sys_counter
[    0.849911] VFS: Disk quotas dquot_6.6.0
[    0.853863] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.860800] FS-Cache: Loaded
[    0.863718] CacheFiles: Loaded
[    0.868545] NET: Registered PF_INET protocol family
[    0.873596] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.882341] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.890935] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.898716] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.906804] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.914978] TCP: Hash tables configured (established 32768 bind 32768)
[    0.921662] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.929137] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.935918] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.943186] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.949029] RPC: Registered named UNIX socket transport module.
[    0.954977] RPC: Registered udp transport module.
[    0.959700] RPC: Registered tcp transport module.
[    0.964420] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.970890] PCI: CLS 0 bytes, default 64
[    0.974950] Trying to unpack rootfs image as initramfs...
[    0.984210] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[    0.992675] kvm [1]: IPA Size Limit: 40 bits
[    0.997059] kvm [1]: vgic interrupt IRQ9
[    1.001060] kvm [1]: VHE mode initialized successfully
[    1.076475] Initialise system trusted keyrings
[    1.081089] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.089439] zbud: loaded
[    1.092683] NFS: Registering the id_resolver key type
[    1.097787] Key type id_resolver registered
[    1.101989] Key type id_legacy registered
[    1.106052] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.112784] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.120672] Key type asymmetric registered
[    1.124826] Asymmetric key parser 'x509' registered
[    1.129755] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.137268] io scheduler mq-deadline registered
[    1.141833] io scheduler kyber registered
[    1.146527] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 31)
[    1.156035] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 32)
[    1.161530] Freeing initrd memory: 10848K
[    1.163906] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 33)
[    1.175599] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 34)
[    1.183408] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 35)
[    1.192609] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 36)
[    1.202059] gpio-461 (RP1 RUN pin): hogged as output/high
[    1.241636] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    1.248492] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 38, base_baud = 6000000) is a 16550A
[    1.257808] serial serial0: tty port ttyS0 registered
[    1.263455] iproc-rng200 107d208000.rng: hwrng registered
[    1.269011] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    1.278020] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    1.287414] brd: module loaded
[    1.292131] loop: module loaded
[    1.295501] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.302940] Loading iSCSI transport class v2.0-870.
[    1.308948] usbcore: registered new interface driver r8152
[    1.314476] usbcore: registered new interface driver lan78xx
[    1.320168] usbcore: registered new interface driver smsc95xx
[    1.326075] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.331919] dwc_otg: FIQ enabled
[    1.331921] dwc_otg: NAK holdoff enabled
[    1.331924] dwc_otg: FIQ split-transaction FSM enabled
[    1.331927] Module dwc_common_port init
[    1.332188] usbcore: registered new interface driver uas
[    1.337536] usbcore: registered new interface driver usb-storage
[    1.343769] mousedev: PS/2 mouse device common for all mice
[    1.357236] rpi-rtc soc:rpi_rtc: registered as rtc0
[    1.363602] rpi-rtc soc:rpi_rtc: setting system clock to 2024-02-06T09:16:53 UTC (1707211013)
[    1.372836] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    1.379394] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.388407] sdhci: Secure Digital Host Controller Interface driver
[    1.394618] sdhci: Copyright(c) Pierre Ossman
[    1.399139] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.405240] ledtrig-cpu: registered to indicate activity on CPUs
[    1.411310] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.417791] hid: raw HID events driver (C) Jiri Kosina
[    1.422977] usbcore: registered new interface driver usbhid
[    1.428572] usbhid: USB HID core driver
[    1.432618] NET: Registered PF_PACKET protocol family
[    1.437721] Key type dns_resolver registered
[    1.442259] registered taskstats version 1
[    1.446397] Loading compiled-in X.509 certificates
[    1.458281] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    1.467054] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
[    1.477457] Key type .fscrypt registered
[    1.481399] Key type fscrypt-provisioning registered
[    1.488369] brcm-pcie 1000110000.pcie: host bridge /axi/pcie@110000 ranges:
[    1.495377] brcm-pcie 1000110000.pcie:   No bus range found for /axi/pcie@110000, using [bus 00-ff]
[    1.504486] brcm-pcie 1000110000.pcie:      MEM 0x1b00000000..0x1bfffffffb -> 0x0000000000
[    1.512797] brcm-pcie 1000110000.pcie:      MEM 0x1800000000..0x1affffffff -> 0x0400000000
[    1.521112] brcm-pcie 1000110000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    1.530606] brcm-pcie 1000110000.pcie: setting SCB_ACCESS_EN, READ_UR_MODE, MAX_BURST_SIZE
[    1.538916] brcm-pcie 1000110000.pcie: Forcing gen 3
[    1.543940] brcm-pcie 1000110000.pcie: PCI host bridge to bus 0000:00
[    1.550409] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.555917] pci_bus 0000:00: root bus resource [mem 0x1b00000000-0x1bfffffffb] (bus address [0x00000000-0xfffffffb])
[    1.566489] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1affffffff pref] (bus address [0x400000000-0x6ffffffff])
[    1.577685] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[    1.583772] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.590252] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.023675] brcm-pcie 1000110000.pcie: link down
[    2.028342] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.034993] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.039985] pci 0000:00:00.0: Max Payload Size set to  512/ 512 (was  128), Max Read Rq  512
[    2.048605] pcieport 0000:00:00.0: PME: Signaling with IRQ 39
[    2.054471] pcieport 0000:00:00.0: AER: enabled with IRQ 39
[    2.060200] pci_bus 0000:01: busn_res: [bus 01] is released
[    2.065848] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[    2.071945] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[    2.078941] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[    2.088047] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    2.096357] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    2.104679] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    2.112990] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    2.122471] brcm-pcie 1000120000.pcie: setting SCB_ACCESS_EN, READ_UR_MODE, MAX_BURST_SIZE
[    2.130793] brcm-pcie 1000120000.pcie: Forcing gen 2
[    2.135812] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0001:00
[    2.142280] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.147791] pci_bus 0001:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[    2.158362] pci_bus 0001:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[    2.169555] pci 0001:00:00.0: [14e4:2712] type 01 class 0x060400
[    2.175638] pci 0001:00:00.0: PME# supported from D0 D3hot
[    2.182010] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.295681] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    2.302346] pci 0001:01:00.0: [1de4:0001] type 00 class 0x020000
[    2.308394] pci 0001:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[    2.314694] pci 0001:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[    2.320993] pci 0001:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[    2.327373] pci 0001:01:00.0: supports D1
[    2.331397] pci 0001:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    2.347688] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    2.354338] pci 0001:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[    2.361507] pci 0001:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[    2.368676] pci 0001:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[    2.375845] pci 0001:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[    2.383014] pci 0001:00:00.0: PCI bridge to [bus 01]
[    2.388000] pci 0001:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[    2.395171] pci 0001:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    2.403654] pci 0001:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    2.412238] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
[    2.418397] pcieport 0001:00:00.0: PME: Signaling with IRQ 40
[    2.424252] pcieport 0001:00:00.0: AER: enabled with IRQ 40
[    2.430003] rp1 0001:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[    2.439093] rp1 0001:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[    2.448363] rp1 0001:01:00.0: enabling device (0000 -> 0002)
[    2.455254] rp1 0001:01:00.0: chip_id 0x20001927
[    2.483837] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 108 (d8:3a:dd:bc:e1:bc)
[    2.495209] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    2.563787] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    2.568871] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[    2.576578] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000000000010810
[    2.585592] xhci-hcd xhci-hcd.0: irq 133, io mem 0x1f00200000
[    2.591439] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    2.596512] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[    2.603767] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[    2.609962] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    2.618284] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.625539] usb usb1: Product: xHCI Host Controller
[    2.630435] usb usb1: Manufacturer: Linux 6.1.0-rpi7-rpi-v8 xhci-hcd
[    2.636815] usb usb1: SerialNumber: xhci-hcd.0
[    2.641436] hub 1-0:1.0: USB hub found
[    2.645218] hub 1-0:1.0: 2 ports detected
[    2.649452] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    2.657757] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.665011] usb usb2: Product: xHCI Host Controller
[    2.669907] usb usb2: Manufacturer: Linux 6.1.0-rpi7-rpi-v8 xhci-hcd
[    2.676387] usb usb2: SerialNumber: xhci-hcd.0
[    2.680968] hub 2-0:1.0: USB hub found
part (2/2)
[    2.684747] hub 2-0:1.0: 1 port detected
[    2.747777] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    2.752855] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[    2.760703] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000000000010810
[    2.769717] xhci-hcd xhci-hcd.1: irq 138, io mem 0x1f00300000
[    2.775559] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    2.780770] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[    2.788026] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[    2.794254] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    2.802693] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.809964] usb usb3: Product: xHCI Host Controller
[    2.814860] usb usb3: Manufacturer: Linux 6.1.0-rpi7-rpi-v8 xhci-hcd
[    2.821376] usb usb3: SerialNumber: xhci-hcd.1
[    2.825955] hub 3-0:1.0: USB hub found
[    2.829737] hub 3-0:1.0: 2 ports detected
[    2.834009] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    2.842496] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.849751] usb usb4: Product: xHCI Host Controller
[    2.854647] usb usb4: Manufacturer: Linux 6.1.0-rpi7-rpi-v8 xhci-hcd
[    2.861250] usb usb4: SerialNumber: xhci-hcd.1
[    2.865835] hub 4-0:1.0: USB hub found
[    2.869614] hub 4-0:1.0: 1 port detected
[    2.874971] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    2.883688] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    2.891788] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    2.900089] platform 1000800000.codec: Adding to iommu group 0
[    2.905980] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    2.914211] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    2.922691] platform 1000880000.pisp_be: Adding to iommu group 0
[    2.928797] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    2.936921] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    2.945023] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    2.952794] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    2.961194] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    2.968708] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    2.976024] platform axi:gpu: Adding to iommu group 1
[    2.981168] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    2.988557] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    2.996198] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    3.004888] platform 1f00128000.csi: bcm2712_iommu_probe_device: MMU 1000005280.iommu
[    3.012754] platform 1f00128000.csi: bcm2712_iommu_device_group: MMU 1000005280.iommu
[    3.020931] platform 1f00128000.csi: Adding to iommu group 2
[    3.026622] platform 1f00128000.csi: bcm2712_iommu_attach_dev: MMU 1000005280.iommu
[    3.034374] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    3.041582] sdhci-brcmstb 1000fff000.mmc: there is not valid maps for state default
[    3.042040] mmc1: CQHCI version 5.10
[    3.042612] of_cfs_init
[    3.042652] of_cfs_init: OK
[    3.063946] mmc0: CQHCI version 5.10
[    3.103382] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    3.206185] mmc0: new ultra high speed SDR104 SDHC card at address 5048
[    3.213095] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[    3.219243]  mmcblk0: p1 p2
[    3.222154] mmcblk0: mmc0:5048 SD32G 29.7 GiB (quirks 0x00004000)
[    3.246243] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    3.258363] Freeing unused kernel memory: 4288K
[    3.262993] Run /init as init process
[    3.266669]   with arguments:
[    3.266671]     /init
[    3.266674]   with environment:
[    3.266676]     HOME=/
[    3.266678]     TERM=linux
[    3.284645] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    3.703087] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    4.007518] NET: Registered PF_INET6 protocol family
[    4.012948] Segment Routing with IPv6
[    4.016642] In-situ OAM (IOAM) with IPv6
[    4.047422] systemd[1]: systemd 252.19-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    4.080307] systemd[1]: Detected architecture arm64.
[    4.091229] systemd[1]: Hostname set to <raspberryb01>.
[    4.151626] uart-pl011 107d001000.serial: no DMA platform data
[    4.330310] systemd[1]: Queued start job for default target multi-user.target.
[    4.356504] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    4.364358] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    4.372691] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    4.381922] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    4.391026] systemd[1]: Created slice user.slice - User and Session Slice.
[    4.398117] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    4.409368] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    4.420154] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    4.432857] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[    4.440635] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    4.449651] systemd[1]: Reached target paths.target - Path Units.
[    4.455869] systemd[1]: Reached target slices.target - Slice Units.
[    4.462246] systemd[1]: Reached target swap.target - Swaps.
[    4.467923] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    4.476554] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    4.485448] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    4.494641] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    4.503213] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    4.512404] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    4.524398] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    4.532793] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    4.541032] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    4.575795] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    4.585036] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    4.594208] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    4.602526] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    4.620631] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    4.632169] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    4.642040] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    4.652503] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
[    4.662503] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    4.672091] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[    4.681140] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    4.691484] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
[    4.700674] systemd[1]: Starting [email protected] - Load Kernel Module loop...
[    4.708661] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    4.727436] systemd[1]: Starting systemd-journald.service - Journal Service...
[    4.728200] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: [email protected]
[    4.746748] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    4.755239] fuse: init (API version 7.37)
[    4.756251] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    4.769956] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    4.781157] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    4.795593] i2c_dev: i2c /dev entries driver
[    4.804256] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    4.812841] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    4.821311] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[    4.830225] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    4.839555] systemd[1]: [email protected]: Deactivated successfully.
[    4.846721] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    4.852902] systemd[1]: Finished [email protected] - Load Kernel Module configfs.
[    4.863043] systemd[1]: Started systemd-journald.service - Journal Service.
[    4.916641] systemd-journald[277]: Received client request to flush runtime journal.
[    5.742816] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    5.742906] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    5.743002] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    5.743048] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    5.743131] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    5.743173] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    5.743249] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    5.743290] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    5.743539] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[    5.743580] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[    5.754466] mc: Linux media interface: v0.10
[    5.777300] input: pwr_button as /devices/platform/pwr_button/input/input0
[    5.835929] brcmstb-i2c 107d508200.i2c:  @200000hz registered in interrupt mode
[    5.842914] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
[    5.844104] brcmstb-i2c 107d508280.i2c:  @200000hz registered in interrupt mode
[    5.850436] videodev: Linux video capture interface: v2.00
[    5.885008] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    5.894443] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    5.894700] pispbe 1000880000.pisp_be: pispbe_probe: HW version:  0x02252700
[    5.894707] pispbe 1000880000.pisp_be: pispbe_probe: BatchStatus: 0x00000000
[    5.894710] pispbe 1000880000.pisp_be: pispbe_probe: Status:      0x00000000
[    5.894713] pispbe 1000880000.pisp_be: Register nodes for group 0
[    5.895667] pispbe 1000880000.pisp_be: input device node registered as /dev/video20
[    5.896357] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    5.896584] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video21
[    5.898007] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video22
[    5.898240] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video23
[    5.898723] rp1-cfe 1f00128000.csi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[    5.899155] rp1-cfe 1f00128000.csi: DW dphy Host HW v1.20
[    5.899173] rp1-cfe 1f00128000.csi: PiSP FE HW v0.1
[    5.899408] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video24
[    5.899835] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video25
[    5.901625] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video26
[    5.901768] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video27
[    5.901899] pispbe 1000880000.pisp_be: config device node registered as /dev/video28
[    5.902312] pispbe 1000880000.pisp_be: Register nodes for group 1
[    5.902478] pispbe 1000880000.pisp_be: input device node registered as /dev/video29
[    5.903487] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video30
[    5.903611] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video31
[    5.903788] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video32
[    5.903963] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video33
[    5.904081] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video34
[    5.904201] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video35
[    5.904313] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video36
[    5.904427] pispbe 1000880000.pisp_be: config device node registered as /dev/video37
[    5.912232] rpivid 1000800000.codec: Device registered as /dev/video19
[    5.936166] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.936526] cfg80211: Loaded X.509 cert '[email protected]: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    5.936848] cfg80211: Loaded X.509 cert '[email protected]: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    5.937164] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.990620] Bluetooth: Core ver 2.22
[    5.991367] NET: Registered PF_BLUETOOTH protocol family
[    5.991373] Bluetooth: HCI device and connection manager initialized
[    5.991382] Bluetooth: HCI socket layer initialized
[    5.991387] Bluetooth: L2CAP socket layer initialized
[    5.991399] Bluetooth: SCO socket layer initialized
[    6.020436] Bluetooth: HCI UART driver ver 2.3
[    6.020447] Bluetooth: HCI UART protocol H4 registered
[    6.020478] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    6.020603] Bluetooth: HCI UART protocol Broadcom registered
[    6.020693] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    6.020758] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    6.034227] brcmfmac: F1 signature read @0x18000000=0x15264345
[    6.040029] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    6.040528] usbcore: registered new interface driver brcmfmac
[    6.207245] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    6.380226] Bluetooth: hci0: BCM: chip id 107
[    6.380478] Bluetooth: hci0: BCM: features 0x2f
[    6.381639] Bluetooth: hci0: BCM4345C0
[    6.381649] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    6.386874] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    6.386935] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    6.394520] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    6.406234] Registered IR keymap rc-cec
[    6.406303] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[    6.406361] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[    6.415594] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    6.416846] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    6.426192] Registered IR keymap rc-cec
[    6.426254] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[    6.426310] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input2
[    6.427252] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    6.427412] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    6.427513] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    6.427610] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    6.427750] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    6.431524] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
[    6.436583] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    6.440711] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    6.444642] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    6.482727] dw9807 4-000c: I2C write CTL fail ret = -121
[    6.493376] dw9807 4-000c: I2C write STATUS address fail ret = -121
[    6.493382] dw9807 4-000c: dw9807_ramp I2C failure: -121
[    6.494535] dw9807 4-000c: I2C write STATUS address fail ret = -121
[    6.494540] dw9807 4-000c: dw9807_ramp I2C failure: -121
[    6.494670] dw9807 4-000c: I2C write CTL fail ret = -121
[    7.030186] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[    7.030198] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[    7.032673] pps pps0: new PPS source ptp0
[    7.032868] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[    7.043172] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[    7.104343] Bluetooth: hci0: BCM: features 0x2f
[    7.105735] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    7.105739] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    7.106070] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    7.234288] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.234296] Bluetooth: BNEP filters: protocol multicast
[    7.234306] Bluetooth: BNEP socket layer initialized
[    7.237334] Bluetooth: MGMT ver 1.22
[    7.243098] NET: Registered PF_ALG protocol family
[   17.786807] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  897.312343] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[  897.315720] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[  897.319258] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Can you change dtoverlay=arducam-64mp to dtoverlay=arducam-64mp,cam0 in the config file?
You are connecting the camera to the csi0 port on your Pi 5’s board.
Hei Dion.
As recomended, I change dtoverlay=arducam-64mp to dtoverlay=arducam-64mp,cam0 (without spaces) and reboot. Same error than before…
@raspberryb01:~ $ dmesg | grep arducam
[    5.333336] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@120000/rp1/i2c@88000/arducam_64mp@1a
[    5.853121] arducam_64mp 6-001a: failed to read chip id 4136, with error -5
[    5.889595] arducam_64mp: probe of 6-001a failed with error -5
The comma must be a comma in the English input method, can you confirm?
Ok. so after changing the camera to csi1 and dtoverlay=arducam-64mp to dtoverlay=arducam-64mp,cam1 and rebooting the camera is up and running
I also tried witthout cam1 and is also working.
my conclusion:
  • Either my csi0 port is damage (the RPI5 is new)
  • Your drivers are specifically made for only one port…
I just order other 5 RPI5. will test and come back to you
Actually, if you add the entry dtoverlay=arducam-64mp, the Raspberry Pi will choose to detect the device on the cam1 port by default.
No, our camera driver is compatible with two csi ports.
Hi, I was having problems with my new Hawkeye, and follow this page to fix the problem. Everything is working now, I want say thank you for everyone that share their knowledge here.
This is super-odd. It seems that I have change the ports from time to time from cam0 to cam1 and back to get/keep it working?? At least now, it stopped working on cam0, possibly because of some package installs.
But I do not know exactly. Just as another observation. Maybe others saw similar behavior.
What happened to your cam0?
