[ 0.000000] Linux version 6.1.21-v8+ ([email protected]) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: bypass linux,cma node, using cmdline CMA params instead
[ 0.000000] OF: reserved mem: node linux,cma compatible matching fail
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
[ 0.000000] cma: Reserved 400 MiB at 0x0000000015c00000
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 983808
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:E2:83:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=a73d333d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cma=400M
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000034000000-0x0000000038000000] (64MB)
[ 0.000000] Memory: 3420532K/3997696K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 167564K reserved, 409600K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000331] Console: colour dummy device 80x25
[ 0.000396] printk: console [tty1] enabled
[ 0.000458] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000485] pid_max: default: 32768 minimum: 301
[ 0.000609] LSM: Security Framework initializing
[ 0.000836] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000911] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002256] cgroup: Disabling memory control group subsystem
[ 0.004578] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004598] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004784] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004964] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005444] rcu: Hierarchical SRCU implementation.
[ 0.005457] rcu: Max phase no-delay instances is 1000.
[ 0.006801] EFI services will not be available.
[ 0.007343] smp: Bringing up secondary CPUs ...
[ 0.008547] Detected PIPT I-cache on CPU1
[ 0.008708] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009900] Detected PIPT I-cache on CPU2
[ 0.010024] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011165] Detected PIPT I-cache on CPU3
[ 0.011291] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011442] smp: Brought up 1 node, 4 CPUs
[ 0.011465] SMP: Total of 4 processors activated.
[ 0.011478] CPU features: detected: 32-bit EL0 Support
[ 0.011488] CPU features: detected: 32-bit EL1 Support
[ 0.011500] CPU features: detected: CRC32 instructions
[ 0.011641] CPU: All CPU(s) started at EL2
[ 0.011665] alternatives: applying system-wide alternatives
[ 0.013605] devtmpfs: initialized
[ 0.026055] Enabled cp15_barrier support
[ 0.026099] Enabled setend support
[ 0.026324] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.026361] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.037363] pinctrl core: initialized pinctrl subsystem
[ 0.038272] DMI not present or invalid.
[ 0.038969] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.042699] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.043005] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.043976] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.044072] audit: initializing netlink subsys (disabled)
[ 0.044346] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.044996] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045088] cpuidle: using governor menu
[ 0.045550] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.045754] ASID allocator initialised with 32768 entries
[ 0.045925] Serial: AMBA PL011 UART driver
[ 0.060970] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.076431] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/[email protected]/[email protected]
[ 0.084797] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.088812] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.105475] KASLR enabled
[ 0.142279] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.148336] SCSI subsystem initialized
[ 0.148595] usbcore: registered new interface driver usbfs
[ 0.148656] usbcore: registered new interface driver hub
[ 0.148725] usbcore: registered new device driver usb
[ 0.149141] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.149375] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.149745] pps_core: LinuxPPS API ver. 1 registered
[ 0.149759] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.149786] PTP clock support registered
[ 0.150953] vgaarb: loaded
[ 0.151797] clocksource: Switched to clocksource arch_sys_counter
[ 0.152468] VFS: Disk quotas dquot_6.6.0
[ 0.152552] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.152749] FS-Cache: Loaded
[ 0.152925] CacheFiles: Loaded
[ 0.164392] NET: Registered PF_INET protocol family
[ 0.165285] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.170278] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.170341] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.170370] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.170620] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.171611] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.171961] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.172065] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.172410] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.173321] RPC: Registered named UNIX socket transport module.
[ 0.173337] RPC: Registered udp transport module.
[ 0.173348] RPC: Registered tcp transport module.
[ 0.173359] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.173385] PCI: CLS 0 bytes, default 64
[ 0.176692] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.177104] kvm [1]: IPA Size Limit: 44 bits
[ 0.178457] kvm [1]: vgic interrupt IRQ9
[ 0.178689] kvm [1]: Hyp mode initialized successfully
[ 1.333468] Initialise system trusted keyrings
[ 1.333976] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.341680] zbud: loaded
[ 1.344762] NFS: Registering the id_resolver key type
[ 1.344801] Key type id_resolver registered
[ 1.344812] Key type id_legacy registered
[ 1.344926] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.344944] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.346403] Key type asymmetric registered
[ 1.346422] Asymmetric key parser 'x509' registered
[ 1.346507] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.346791] io scheduler mq-deadline registered
[ 1.346808] io scheduler kyber registered
[ 1.349076] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 27)
[ 1.358194] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.358241] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.358332] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.358420] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00ffffffff -> 0x0400000000
[ 1.359469] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.359490] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.359508] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.359586] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.359940] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.363970] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.364235] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.364417] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.364533] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.429894] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.430065] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.430194] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.430682] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.431413] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.431460] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.431485] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.431530] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.431553] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.445546] iproc-rng200 fe104000.rng: hwrng registered
[ 1.446171] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.447769] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.461373] brd: module loaded
[ 1.470426] loop: module loaded
[ 1.471341] Loading iSCSI transport class v2.0-870.
[ 1.476971] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.535967] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.537143] usbcore: registered new interface driver r8152
[ 1.537234] usbcore: registered new interface driver lan78xx
[ 1.537295] usbcore: registered new interface driver smsc95xx
[ 1.584827] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.585020] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.585053] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.585817] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.586918] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.586941] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.586964] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.587378] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.587399] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.587415] usb usb1: Product: xHCI Host Controller
[ 1.587429] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.587442] usb usb1: SerialNumber: 0000:01:00.0
[ 1.588208] hub 1-0:1.0: USB hub found
[ 1.588279] hub 1-0:1.0: 1 port detected
[ 1.589253] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.589273] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.589288] usb usb2: Product: xHCI Host Controller
[ 1.589301] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.589315] usb usb2: SerialNumber: 0000:01:00.0
[ 1.590017] hub 2-0:1.0: USB hub found
[ 1.590115] hub 2-0:1.0: 4 ports detected
[ 1.592061] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.592427] dwc_otg: FIQ enabled
[ 1.592438] dwc_otg: NAK holdoff enabled
[ 1.592448] dwc_otg: FIQ split-transaction FSM enabled
[ 1.592469] Module dwc_common_port init
[ 1.593054] usbcore: registered new interface driver uas
[ 1.593158] usbcore: registered new interface driver usb-storage
[ 1.593410] mousedev: PS/2 mouse device common for all mice
[ 1.600392] sdhci: Secure Digital Host Controller Interface driver
[ 1.600411] sdhci: Copyright(c) Pierre Ossman
[ 1.601153] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.604935] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.605381] hid: raw HID events driver (C) Jiri Kosina
[ 1.605578] usbcore: registered new interface driver usbhid
[ 1.605592] usbhid: USB HID core driver
[ 1.614898] NET: Registered PF_PACKET protocol family
[ 1.615042] Key type dns_resolver registered
[ 1.616534] registered taskstats version 1
[ 1.616626] Loading compiled-in X.509 certificates
[ 1.617525] Key type .fscrypt registered
[ 1.617539] Key type fscrypt-provisioning registered
[ 1.634029] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.634786] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.634963] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.644430] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.644910] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.646253] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.646272] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.677204] of_cfs_init
[ 1.677332] of_cfs_init: OK
[ 1.710789] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.711160] Waiting for root device PARTUUID=a73d333d-02...
[ 1.763481] mmc1: new high speed SDIO card at address 0001
[ 1.812350] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.813421] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 1.817591] mmcblk0: p1 p2
[ 1.818171] mmcblk0: mmc0:aaaa SD64G 59.5 GiB (quirks 0x00004000)
[ 1.834246] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.834345] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.835296] devtmpfs: mounted
[ 1.843857] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.844660] Freeing unused kernel memory: 4160K
[ 1.844850] Run /sbin/init as init process
[ 1.844861] with arguments:
[ 1.844871] /sbin/init
[ 1.844881] splash
[ 1.844891] with environment:
[ 1.844900] HOME=/
[ 1.844910] TERM=linux
[ 1.998440] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.998484] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.998500] usb 1-1: Product: USB2.0 Hub
[ 2.001733] hub 1-1:1.0: USB hub found
[ 2.002064] hub 1-1:1.0: 4 ports detected
[ 2.188814] systemd[1]: System time before build time, advancing clock.
[ 2.384770] NET: Registered PF_INET6 protocol family
[ 2.386700] Segment Routing with IPv6
[ 2.386742] In-situ OAM (IOAM) with IPv6
[ 2.460888] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.461942] systemd[1]: Detected architecture arm64.
[ 2.463867] systemd[1]: Set hostname to <datarhei>.
[ 3.242594] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.431885] systemd[1]: /etc/systemd/system/core.service:9: Unknown key name 'ExecPre' in section 'Service', ignoring.
[ 3.471637] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.541026] systemd[1]: Created slice system-getty.slice.
[ 3.543450] systemd[1]: Created slice system-modprobe.slice.
[ 3.545468] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.547415] systemd[1]: Created slice system-wg\x2dquick.slice.
[ 3.549143] systemd[1]: Created slice User and Session Slice.
[ 3.549807] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.551145] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.551924] systemd[1]: Reached target Host and Network Name Lookups.
[ 3.552158] systemd[1]: Reached target Slices.
[ 3.552372] systemd[1]: Reached target Swap.
[ 3.553693] systemd[1]: Listening on Syslog Socket.
[ 3.554588] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.555090] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.556580] systemd[1]: Listening on Journal Audit Socket.
[ 3.557555] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.558688] systemd[1]: Listening on Journal Socket.
[ 3.563648] systemd[1]: Listening on udev Control Socket.
[ 3.564759] systemd[1]: Listening on udev Kernel Socket.
[ 3.565928] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.571718] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.577564] systemd[1]: Mounting RPC Pipe File System...
[ 3.584269] systemd[1]: Mounting Kernel Debug File System...
[ 3.590681] systemd[1]: Mounting Kernel Trace File System...
[ 3.591416] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.601751] systemd[1]: Starting Restore / save the current clock...
[ 3.608579] systemd[1]: Starting Set the console keyboard layout...
[ 3.615379] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.621834] systemd[1]: Starting Load Kernel Module configfs...
[ 3.628257] systemd[1]: Starting Load Kernel Module drm...
[ 3.634495] systemd[1]: Starting Load Kernel Module fuse...
[ 3.638172] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.645520] systemd[1]: Starting File System Check on Root Device...
[ 3.657724] systemd[1]: Starting Journal Service...
[ 3.671065] systemd[1]: Starting Load Kernel Modules...
[ 3.680200] systemd[1]: Starting Coldplug All udev Devices...
[ 3.697748] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.698686] systemd[1]: Mounted RPC Pipe File System.
[ 3.699530] systemd[1]: Mounted Kernel Debug File System.
[ 3.702858] systemd[1]: Mounted Kernel Trace File System.
[ 3.706552] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.709652] systemd[1]: [email protected]: Succeeded.
[ 3.712705] systemd[1]: Finished Load Kernel Module configfs.
[ 3.724368] systemd[1]: Mounting Kernel Configuration File System...
[ 3.729672] fuse: init (API version 7.37)
[ 3.731559] systemd[1]: Started File System Check Daemon to report status.
[ 3.735507] systemd[1]: [email protected]: Succeeded.
[ 3.741550] systemd[1]: Finished Load Kernel Module fuse.
[ 3.747362] systemd[1]: Mounted Kernel Configuration File System.
[ 3.756177] systemd[1]: Mounting FUSE Control File System...
[ 3.777106] systemd[1]: Mounted FUSE Control File System.
[ 3.785032] systemd[1]: Finished Restore / save the current clock.
[ 3.794657] i2c_dev: i2c /dev entries driver
[ 3.801699] systemd[1]: Finished Load Kernel Modules.
[ 3.853251] systemd[1]: Starting Apply Kernel Variables...
[ 3.913591] systemd[1]: [email protected]: Succeeded.
[ 3.915279] systemd[1]: Finished Load Kernel Module drm.
[ 3.935294] systemd[1]: Finished Apply Kernel Variables.
[ 3.996293] systemd[1]: Finished File System Check on Root Device.
[ 4.003418] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.045858] systemd[1]: Started Journal Service.
[ 4.160173] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.281657] systemd-journald[145]: Received client request to flush runtime journal.
[ 4.292963] systemd-journald[145]: File /var/log/journal/9d2f73758ac940058e8b0c867f5b2ca4/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.793679] mc: Linux media interface: v0.10
[ 5.848123] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.850198] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.850232] [vc_sm_connected_init]: start
[ 5.861945] [vc_sm_connected_init]: installed successfully
[ 6.009748] videodev: Linux video capture interface: v2.00
[ 6.296412] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.318720] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.358034] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.359417] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.361263] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.382335] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.388529] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.497486] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.503181] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.515911] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.527175] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.565825] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.566569] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.567192] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.567720] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.567757] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.567849] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.567872] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.567900] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.588876] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.588949] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.608940] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.633468] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.633533] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.638943] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.640295] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.641482] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.657746] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.657807] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.663833] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.663893] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.667702] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.667757] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.667852] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.667875] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.667893] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.690228] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.701501] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.701570] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.753347] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 7.087323] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.122070] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.134237] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.445524] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.456090] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.565296] usbcore: registered new interface driver brcmfmac
[ 7.715456] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 8.059409] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 8.214347] Registered IR keymap rc-cec
[ 8.255380] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 8.377462] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 8.584747] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 8.594920] Registered IR keymap rc-cec
[ 8.595159] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 8.595456] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 8.690123] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 8.690800] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 8.691340] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.724990] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.749930] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.750461] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.767052] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 8.803936] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 8.804824] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 9.028587] dw9807 10-000c: I2C write CTL fail ret = -121
[ 9.059522] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 9.061093] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 9.512299] 8021q: 802.1Q VLAN Support v1.8
[ 9.629097] uart-pl011 fe201000.serial: no DMA platform data
[ 9.818058] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 10.279418] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.612002] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 10.612020] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <[email protected]>. All Rights Reserved.
[ 10.752103] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.752886] bcmgenet fd580000.ethernet eth0: Link is Down
[ 15.004511] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 15.008895] Bridge firewalling registered
[ 15.312843] Initializing XFRM netlink socket
[ 15.841338] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 18.467605] Bluetooth: Core ver 2.22
[ 18.467699] NET: Registered PF_BLUETOOTH protocol family
[ 18.467704] Bluetooth: HCI device and connection manager initialized
[ 18.467721] Bluetooth: HCI socket layer initialized
[ 18.467728] Bluetooth: L2CAP socket layer initialized
[ 18.467742] Bluetooth: SCO socket layer initialized
[ 18.563677] Bluetooth: HCI UART driver ver 2.3
[ 18.563701] Bluetooth: HCI UART protocol H4 registered
[ 18.563850] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.564055] Bluetooth: HCI UART protocol Broadcom registered
[ 19.382374] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.382394] Bluetooth: BNEP filters: protocol multicast
[ 19.382409] Bluetooth: BNEP socket layer initialized
[ 19.387273] Bluetooth: MGMT ver 1.22
[ 19.402508] NET: Registered PF_ALG protocol family
[ 19.571826] Bluetooth: RFCOMM TTY layer initialized
[ 19.571860] Bluetooth: RFCOMM socket layer initialized
[ 19.571883] Bluetooth: RFCOMM ver 1.11
[ 20.219919] docker0: port 1(veth7ccb6a4) entered blocking state
[ 20.219943] docker0: port 1(veth7ccb6a4) entered disabled state
[ 20.220139] device veth7ccb6a4 entered promiscuous mode
[ 20.298376] IPv6: ADDRCONF(NETDEV_CHANGE): vethebf57d7: link becomes ready
[ 20.298491] IPv6: ADDRCONF(NETDEV_CHANGE): veth7ccb6a4: link becomes ready
[ 20.298532] docker0: port 1(veth7ccb6a4) entered blocking state
[ 20.298541] docker0: port 1(veth7ccb6a4) entered forwarding state
[ 20.298613] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
[ 22.548378] docker0: port 1(veth7ccb6a4) entered disabled state
[ 22.549530] eth0: renamed from vethebf57d7
[ 22.573610] docker0: port 1(veth7ccb6a4) entered blocking state
[ 22.573633] docker0: port 1(veth7ccb6a4) entered forwarding state
