Although I bought the 64mp camera pre-sale, I’ve only just tried to install it, and I’m unable to get it recognised.
I’ve followed the instructions from this forum and tried it on both a 3A+ and a Pi4. I get the same results.
In my dmsg - I think the relevant sections are:
.986679] imx519 10-001a: chip id mismatch: 519!=682
[ 9.015363] imx519: probe of 10-001a failed with error -5
[ 6.135175] i2c i2c-10: Failed to register i2c client dw9807-vcm at 0x0c (-16)
[ 6.135199] i2c i2c-10: of_i2c: Failure registering /soc/i2c0mux/[email protected]/[email protected]
[ 6.135251] i2c i2c-10: Failed to create I2C device for /soc/i2c0mux/[email protected]/[email protected]
[ 6.135332] i2c i2c-10: Failed to register i2c client 64mp at 0x1a (-16)
[ 6.135351] i2c i2c-10: of_i2c: Failure registering /soc/i2c0mux/[email protected]/[email protected]
[ 6.135397] i2c i2c-10: Failed to create I2C device for /soc/i2c0mux/[email protected]/[email protected]
config.txt - shortened
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
[pi4]
dtoverlay=arducam_64mp
dtoverlay=imx519
I’ve just tested the HQ on the Pi4 and that works OK.
Any suggestions?
Mike
Blockquote
