64MP Camarray QuadCamera - No cameras available
Arducam
  1. Model number of the product(s)?
SKU: B0402
64MP Autofocus Quad-Camera Kit for Raspberry Pi
Camarray HAT UC-512 Rev.D1
64 MP autofocus camera modules
  1. What hardware/platform were you working on?
Linux raspberrypi 6.1.0-rpi4-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (2023-10-05) aarch64 GNU/Linu
  1. Instructions you have followed. (link/manual/etc.)
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/
Section " * 64MP Multi-Camera Kit:"
  1. Problems you were having?
libcamera-still -t 0
root@raspberrypi:/home/rpi# dmesg |grep -i cam
[ 10.031134] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 10.166914] arducam_64mp: probe of 10-001a failed with error -5
I put a lot of time already on this, reading other threads and following the advises from the support. What I tried so far:
  • Different flexible cables
  • Using another RPi device
  • Older Rpi OS images, including 32bit
  1. What help do you need?
I need the device to be recognised by the system. Otherwise, an exchange. I’ll posting other output in separate messages due to forum character limits.
dmesg
[ 0.000000] Linux version 6.1.0-rpi4-rpi-v8 ([email protected]) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.1.54-1+rpt2 (2023-10-05)
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000dc00000, size 512 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s79144 r8192 d31448 u118784
[ 0.000000] pcpu-alloc: s79144 r8192 d31448 u118784 alloc=29*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 996912
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:B9:BC:82 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=0fc52c43-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=CA
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 3339004K/4050944K available (12352K kernel code, 2172K rwdata, 4164K rodata, 4224K init, 1082K bss, 187652K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 40047 entries in 157 pages
[ 0.000000] ftrace: allocated 157 pages with 5 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000354] Console: colour dummy device 80x25
[ 0.000417] printk: console [tty1] enabled
[ 0.000476] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000505] pid_max: default: 32768 minimum: 301
[ 0.000628] LSM: Security Framework initializing
[ 0.000855] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000926] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002264] cgroup: Disabling memory control group subsystem
[ 0.004508] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004524] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004703] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004715] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004887] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004900] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005357] rcu: Hierarchical SRCU implementation.
[ 0.005370] rcu: Max phase no-delay instances is 1000.
[ 0.007551] EFI services will not be available.
[ 0.008133] smp: Bringing up secondary CPUs …
[ 0.009205] Detected PIPT I-cache on CPU1
[ 0.009378] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010512] Detected PIPT I-cache on CPU2
[ 0.010628] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011719] Detected PIPT I-cache on CPU3
[ 0.011847] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011996] smp: Brought up 1 node, 4 CPUs
[ 0.012020] SMP: Total of 4 processors activated.
[ 0.012034] CPU features: detected: 32-bit EL0 Support
[ 0.012043] CPU features: detected: 32-bit EL1 Support
[ 0.012056] CPU features: detected: CRC32 instructions
[ 0.012200] CPU: All CPU(s) started at EL2
[ 0.012224] alternatives: applying system-wide alternatives
[ 0.014206] devtmpfs: initialized
[ 0.026732] Enabled cp15_barrier support
[ 0.026774] Enabled setend support
[ 0.027005] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.027045] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.042756] pinctrl core: initialized pinctrl subsystem
[ 0.043672] DMI not present or invalid.
[ 0.044413] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.047870] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.048203] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.049152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.049251] audit: initializing netlink subsys (disabled)
[ 0.049521] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.050193] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.050278] cpuidle: using governor menu
[ 0.050561] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.050758] ASID allocator initialised with 32768 entries
[ 0.051750] Serial: AMBA PL011 UART driver
[ 0.067331] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.088361] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-08-10T15:33:38, variant start
[ 0.092372] raspberrypi-firmware soc:firmware: Firmware hash is 03dc77429335caee083e22ddc8eec09c07f12a7a
[ 0.108616] KASLR enabled
[ 0.140425] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.146036] iommu: Default domain type: Translated
[ 0.146055] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.146509] SCSI subsystem initialized
[ 0.146767] usbcore: registered new interface driver usbfs
[ 0.146826] usbcore: registered new interface driver hub
[ 0.146891] usbcore: registered new device driver usb
[ 0.147311] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.147863] pps_core: LinuxPPS API ver. 1 registered
[ 0.147877] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.147901] PTP clock support registered
[ 0.149063] vgaarb: loaded
[ 0.149823] clocksource: Switched to clocksource arch_sys_counter
[ 0.150515] VFS: Disk quotas dquot_6.6.0
[ 0.150594] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.150784] FS-Cache: Loaded
[ 0.150958] CacheFiles: Loaded
[ 0.159987] NET: Registered PF_INET protocol family
[ 0.160930] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.166096] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.166171] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.166199] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.166446] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.167650] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.168197] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.168432] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.168509] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.168830] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.169729] RPC: Registered named UNIX socket transport module.
[ 0.169745] RPC: Registered udp transport module.
[ 0.169755] RPC: Registered tcp transport module.
[ 0.169764] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.169789] PCI: CLS 0 bytes, default 64
[ 0.170608] Trying to unpack rootfs image as initramfs…
[ 0.180248] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.180725] kvm [1]: IPA Size Limit: 44 bits
[ 0.182356] kvm [1]: vgic interrupt IRQ9
[ 0.182603] kvm [1]: Hyp mode initialized successfully
[ 1.103702] Freeing initrd memory: 16716K
[ 1.244449] Initialise system trusted keyrings
[ 1.245029] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.253082] zbud: loaded
[ 1.256165] NFS: Registering the id_resolver key type
[ 1.256224] Key type id_resolver registered
[ 1.256236] Key type id_legacy registered
[ 1.256351] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.256368] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.257798] Key type asymmetric registered
[ 1.257864] Asymmetric key parser ‘x509’ registered
[ 1.257961] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.258244] io scheduler mq-deadline registered
[ 1.258261] io scheduler kyber registered
[ 1.261318] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.272976] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.273021] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.273108] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.273202] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.273764] brcm-pcie fd500000.pcie: setting SCB_ACCESS_EN, READ_UR_MODE, MAX_BURST_SIZE
[ 1.274271] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.274291] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.274310] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.274394] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.274659] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.278898] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.279099] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.279203] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.387930] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.388097] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.388223] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.388702] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.397980] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.398007] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.398086] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.398110] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.398556] pcieport 0000:00:00.0: enabling device (0000 → 0002)
[ 1.398803] pcieport 0000:00:00.0: PME: Signaling with IRQ 31
[ 1.399338] pcieport 0000:00:00.0: AER: enabled with IRQ 31
[ 1.401195] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes
[ 1.401215] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.401848] Console: switching to colour frame buffer device 240x67
[ 1.410571] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 1.426018] iproc-rng200 fe104000.rng: hwrng registered
[ 1.426628] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.441089] brd: module loaded
[ 1.449927] loop: module loaded
[ 1.450915] Loading iSCSI transport class v2.0-870.
[ 1.457173] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.569982] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.571193] usbcore: registered new interface driver r8152
[ 1.571275] usbcore: registered new interface driver lan78xx
[ 1.571335] usbcore: registered new interface driver smsc95xx
[ 1.573058] xhci_hcd 0000:01:00.0: enabling device (0000 → 0002)
[ 1.573167] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.573200] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.574009] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0b00040000000890
[ 1.574747] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.574771] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.574793] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.575140] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.575160] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.575175] usb usb1: Product: xHCI Host Controller
[ 1.575188] usb usb1: Manufacturer: Linux 6.1.0-rpi4-rpi-v8 xhci-hcd
[ 1.575201] usb usb1: SerialNumber: 0000:01:00.0
[ 1.575958] hub 1-0:1.0: USB hub found
[ 1.576056] hub 1-0:1.0: 1 port detected
[ 1.577030] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.577050] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.577065] usb usb2: Product: xHCI Host Controller
[ 1.577078] usb usb2: Manufacturer: Linux 6.1.0-rpi4-rpi-v8 xhci-hcd
[ 1.577091] usb usb2: SerialNumber: 0000:01:00.0
[ 1.577758] hub 2-0:1.0: USB hub found
[ 1.577931] hub 2-0:1.0: 4 ports detected
[ 1.579729] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.580082] dwc_otg: FIQ enabled
[ 1.580093] dwc_otg: NAK holdoff enabled
[ 1.580102] dwc_otg: FIQ split-transaction FSM enabled
[ 1.580119] Module dwc_common_port init
[ 1.581500] usbcore: registered new interface driver uas
[ 1.581606] usbcore: registered new interface driver usb-storage
[ 1.582627] mousedev: PS/2 mouse device common for all mice
[ 1.590290] sdhci: Secure Digital Host Controller Interface driver
[ 1.590311] sdhci: Copyright(c) Pierre Ossman
[ 1.591041] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.595161] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.595508] hid: raw HID events driver (C) Jiri Kosina
[ 1.595738] usbcore: registered new interface driver usbhid
[ 1.595752] usbhid: USB HID core driver
[ 1.606325] NET: Registered PF_PACKET protocol family
[ 1.606446] Key type dns_resolver registered
[ 1.607746] registered taskstats version 1
[ 1.607838] Loading compiled-in X.509 certificates
[ 1.637171] Loaded X.509 cert ‘Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1’
[ 1.637310] Loaded X.509 cert ‘Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f’
[ 1.638374] Key type .fscrypt registered
[ 1.638390] Key type fscrypt-provisioning registered
[ 1.654315] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.655213] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.655387] fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.655646] serial serial0: tty port ttyAMA1 registered
[ 1.665325] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.665860] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.667444] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.667466] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.695593] of_cfs_init
[ 1.695735] of_cfs_init: OK
[ 1.729952] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.739433] Freeing unused kernel memory: 4224K
[ 1.739646] Run /init as init process
[ 1.739657] with arguments:
[ 1.739666] /init
[ 1.739675] splash
[ 1.739685] with environment:
[ 1.739694] HOME=/
[ 1.739703] TERM=linux
[ 1.779384] mmc1: new high speed SDIO card at address 0001
[ 1.829962] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.837984] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.839174] mmcblk0: mmc0:0001 SPCC 29.8 GiB
[ 1.842592] mmcblk0: p1 p2
[ 1.843250] mmcblk0: mmc0:0001 SPCC 29.8 GiB
[ 1.980468] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.980508] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.980525] usb 1-1: Product: USB2.0 Hub
[ 1.983138] hub 1-1:1.0: USB hub found
[ 1.983427] hub 1-1:1.0: 4 ports detected
[ 2.281880] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
[ 2.389602] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[ 2.389636] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.389652] usb 1-1.2: Product: USB Receiver
[ 2.389666] usb 1-1.2: Manufacturer: Logitech
[ 2.401762] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C52B.0001/input/input0
[ 2.463014] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.2/input0
[ 2.472775] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input1
[ 2.473427] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input2
[ 2.530310] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C52B.0002/input/input3
[ 2.530950] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.2/input1
[ 2.538756] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.2/input2
[ 2.617930] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
[ 2.717788] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 2.720686] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 2.739236] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 2.739277] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.739294] usb 1-1.3: Product: USB Receiver
[ 2.739308] usb 1-1.3: Manufacturer: Logitech
[ 2.816423] logitech-djreceiver 0003:046D:C534.0004: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input0
[ 2.855772] i2c i2c-22: Added multiplexed i2c bus 0
[ 2.857134] i2c 10-001a: Fixed dependency cycle(s) with /soc/csi@7e801000/port/endpoint
[ 2.857711] i2c i2c-22: Added multiplexed i2c bus 10
[ 2.901126] Console: switching to colour dummy device 80x25
[ 2.918089] logitech-djreceiver 0003:046D:C534.0005: hiddev98,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input1
[ 2.940865] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 2.953466] Registered IR keymap rc-cec
[ 2.953660] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 2.953960] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input5
[ 2.980548] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 2.986009] logitech-djreceiver 0003:046D:C534.0005: device of type eQUAD nano Lite (0x0a) connected on slot 2
dmesg (cont)
[ 2.988258] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C534.0005/0003:046D:4054.0006/input/input6
[ 3.052177] hid-generic 0003:046D:4054.0006: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-0000:01:00.0-1.3/input1:2
[ 3.055170] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 3.056915] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.2/input2
[ 3.058424] Registered IR keymap rc-cec
[ 3.058618] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 3.058825] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input10
[ 3.066435] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 3.067025] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 3.067472] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.067889] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.068305] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.068613] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.069035] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.072738] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 3.154609] Console: switching to colour frame buffer device 240x67
[ 3.179327] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 3.235807] input: Logitech Wireless Device PID:404d Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input11
[ 3.271175] input: Logitech Wireless Device PID:404d Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input12
[ 3.284642] hid-generic 0003:046D:404D.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:404d] on usb-0000:01:00.0-1.2/input2:1
[ 3.482406] input: Logitech Wireless Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C534.0005/0003:046D:4054.0006/input/input16
[ 3.483519] logitech-hidpp-device 0003:046D:4054.0006: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:01:00.0-1.3/input1:2
[ 3.654934] input: Logitech K400 Plus as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0007/input/input17
[ 3.657979] logitech-hidpp-device 0003:046D:404D.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-0000:01:00.0-1.2/input2:1
[ 4.592503] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 5.315692] systemd[1]: System time before build time, advancing clock.
[ 5.504409] NET: Registered PF_INET6 protocol family
[ 5.506368] Segment Routing with IPv6
[ 5.506419] In-situ OAM (IOAM) with IPv6
[ 5.586282] systemd[1]: systemd 252.17-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 5.586335] systemd[1]: Detected architecture arm64.
[ 5.597394] systemd[1]: Hostname set to .
[ 6.547981] systemd[1]: Queued start job for default target graphical.target.
[ 6.578927] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 6.581310] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 6.583217] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 6.584464] systemd[1]: Created slice user.slice - User and Session Slice.
[ 6.585114] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 6.586497] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 6.586892] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 6.587134] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[ 6.587326] systemd[1]: Reached target slices.target - Slice Units.
[ 6.587476] systemd[1]: Reached target swap.target - Swaps.
[ 6.587641] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 6.588731] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 6.589197] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 6.591474] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 6.592608] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 6.593751] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 6.601761] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 6.603016] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 6.604124] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 6.630491] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System…
[ 6.636864] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System…
[ 6.643274] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System…
[ 6.644157] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 6.653381] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock…
[ 6.660554] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout…
[ 6.667475] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes…
[ 6.674800] systemd[1]: Starting [email protected] - Load Kernel Module configfs…
[ 6.682503] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod…
[ 6.690546] systemd[1]: Starting [email protected] - Load Kernel Module drm…
[ 6.698340] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore…
[ 6.708950] systemd[1]: Starting [email protected] - Load Kernel Module fuse…
[ 6.722036] systemd[1]: Starting [email protected] - Load Kernel Module loop…
[ 6.723476] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 6.746955] systemd[1]: Starting systemd-journald.service - Journal Service…
[ 6.771394] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules…
[ 6.778876] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems…
[ 6.790688] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices…
[ 6.792329] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: [email protected]
[ 6.812968] fuse: init (API version 7.37)
[ 6.832260] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 6.834656] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 6.836481] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 6.839891] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[ 6.861927] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 6.865352] systemd[1]: [email protected]: Deactivated successfully.
[ 6.867118] systemd[1]: Finished [email protected] - Load Kernel Module configfs.
[ 6.870088] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 6.874156] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 6.874763] i2c_dev: i2c /dev entries driver
[ 6.877299] systemd[1]: [email protected]: Deactivated successfully.
[ 6.878949] systemd[1]: Finished [email protected] - Load Kernel Module drm.
[ 6.884489] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 6.886057] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 6.889621] systemd[1]: [email protected]: Deactivated successfully.
[ 6.891115] systemd[1]: Finished [email protected] - Load Kernel Module fuse.
[ 6.898487] systemd[1]: [email protected]: Deactivated successfully.
[ 6.899954] systemd[1]: Finished [email protected] - Load Kernel Module loop.
[ 6.903217] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 6.920200] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 6.927364] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System…
[ 6.934744] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System…
[ 6.935652] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[ 6.949348] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables…
[ 6.982094] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[ 6.984787] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 6.986552] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 6.988213] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 6.988555] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 7.019951] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed…
[ 7.029661] systemd[1]: Starting systemd-sysusers.service - Create System Users…
[ 7.104067] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[ 7.125331] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
[ 7.127171] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 7.186375] systemd[1]: Finished systemd-sysusers.service - Create System Users.
[ 7.219099] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev…
[ 7.236753] systemd[1]: Started systemd-journald.service - Journal Service.
[ 7.327812] systemd-journald[282]: Received client request to flush runtime journal.
[ 7.343341] systemd-journald[282]: File /var/log/journal/4f8b22e96a62405f9f80c331db6ae140/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 8.857500] mc: Linux media interface: v0.10
[ 8.934357] rpi-gpiomem fe200000.gpiomem: window base 0xfe200000 size 0x00001000
[ 8.954924] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.956700] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.970835] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.970880] [vc_sm_connected_init]: start
[ 8.997714] [vc_sm_connected_init]: installed successfully
[ 9.010831] rpi-gpiomem fe200000.gpiomem: initialised 1 regions as /dev/gpiomem
[ 9.027225] videodev: Linux video capture interface: v2.00
[ 9.070304] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 9.367999] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.370110] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.397352] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.403269] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.490598] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.498230] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.501477] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 9.503069] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 9.520620] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 9.544617] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 9.544675] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 9.544701] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 9.544720] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 9.544741] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 9.566877] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 9.566951] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 9.572276] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 9.587860] rpivid feb10000.codec: Device registered as /dev/video19
[ 9.589525] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 9.589587] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 9.590366] Bluetooth: Core ver 2.22
[ 9.594206] NET: Registered PF_BLUETOOTH protocol family
[ 9.594233] Bluetooth: HCI device and connection manager initialized
[ 9.594270] Bluetooth: HCI socket layer initialized
[ 9.594291] Bluetooth: L2CAP socket layer initialized
[ 9.594759] Bluetooth: SCO socket layer initialized
[ 9.594929] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 9.601268] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 9.601336] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.612020] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 9.613021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 9.613062] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 9.613087] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 9.613107] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 9.613124] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 9.616185] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 9.616279] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 9.630497] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 9.679501] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 9.679605] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 9.694306] Bluetooth: HCI UART driver ver 2.3
[ 9.694347] Bluetooth: HCI UART protocol H4 registered
[ 9.699472] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 9.752060] Bluetooth: HCI UART protocol Broadcom registered
[ 9.759787] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 9.760262] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 9.791236] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.792627] cfg80211: Loaded X.509 cert ‘[email protected]: 577e021cb980e0e820821ba7b54b4961b8b4fadf’
[ 9.793662] cfg80211: Loaded X.509 cert ‘ro[email protected]: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328’
[ 9.797089] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 9.806625] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[ 9.807872] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[ 9.878333] uart-pl011 fe201000.serial: no DMA platform data
[ 9.961897] dw9807 10-000c: I2C write CTL fail ret = -5
[ 10.042862] dw9807 10-000c: I2C write STATUS address fail ret = -5
[ 10.042903] dw9807 10-000c: dw9807_ramp I2C failure: -5
[ 10.044362] dw9807 10-000c: I2C write STATUS address fail ret = -5
[ 10.044404] dw9807 10-000c: dw9807_ramp I2C failure: -5
[ 10.044771] dw9807 10-000c: I2C write CTL fail ret = -5
[ 10.170818] Bluetooth: hci0: BCM: chip id 107
[ 10.171993] Bluetooth: hci0: BCM: features 0x2f
[ 10.173566] Bluetooth: hci0: BCM4345C0
[ 10.173596] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 10.175484] bluetooth hci0: firmware: failed to load brcm/BCM4345C0.raspberrypi,4-model-b.hcd (-2)
[ 10.175526] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 10.184325] bluetooth hci0: firmware: direct-loading firmware brcm/BCM4345C0.hcd
[ 10.184368] Bluetooth: hci0: BCM4345C0 ‘brcm/BCM4345C0.hcd’ Patch
[ 10.678416] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 10.726388] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 10.727819] usbcore: registered new interface driver brcmfmac
[ 10.752957] brcmfmac mmc1:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin
[ 10.754222] brcmfmac mmc1:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt
[ 10.755593] brcmfmac mmc1:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.clm_blob
[ 10.959308] Bluetooth: hci0: BCM: features 0x2f
[ 10.960853] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3±0190
[ 10.960896] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[ 11.011042] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 12.560784] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 13.443636] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.443676] Bluetooth: BNEP filters: protocol multicast
[ 13.443710] Bluetooth: BNEP socket layer initialized
[ 13.460759] Bluetooth: MGMT ver 1.22
[ 13.514765] NET: Registered PF_ALG protocol family
[ 14.250643] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 14.251426] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.274819] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 17.921262] Bluetooth: RFCOMM TTY layer initialized
[ 17.921303] Bluetooth: RFCOMM socket layer initialized
[ 17.921353] Bluetooth: RFCOMM ver 1.11
[ 19.575018] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 45.728646] logitech-hidpp-device 0003:046D:4054.0006: HID++ 4.5 device connected.
[ 51.259132] logitech-hidpp-device 0003:046D:404D.0007: HID++ 4.1 device connected.
[ 77.642508] vc4-drm gpu: swiotlb buffer is full (sz: 1318912 bytes), total 32768 (slots), used 104 (slots)
[ 77.671047] vc4-drm gpu: swiotlb buffer is full (sz: 2105344 bytes), total 32768 (slots), used 92 (slots)
[ 77.699267] vc4-drm gpu: swiotlb buffer is full (sz: 5521408 bytes), total 32768 (slots), used 60 (slots)
[ 77.855031] vc4-drm gpu: swiotlb buffer is full (sz: 1318912 bytes), total 32768 (slots), used 102 (slots)
[ 78.155944] vc4-drm gpu: swiotlb buffer is full (sz: 2105344 bytes), total 32768 (slots), used 108 (slots)
[ 78.293738] vc4-drm gpu: swiotlb buffer is full (sz: 5521408 bytes), total 32768 (slots), used 24 (slots)
[ 79.343308] vc4-drm gpu: swiotlb buffer is full (sz: 3239936 bytes), total 32768 (slots), used 122 (slots)
[ 79.357257] vc4-drm gpu: swiotlb buffer is full (sz: 3883008 bytes), total 32768 (slots), used 114 (slots)
[ 79.370648] vc4-drm gpu: swiotlb buffer is full (sz: 532480 bytes), total 32768 (slots), used 2 (slots)
[ 79.384184] vc4-drm gpu: swiotlb buffer is full (sz: 3239936 bytes), total 32768 (slots), used 122 (slots)
[ 1970.290516] swiotlb_tbl_map_single: 2 callbacks suppressed
[ 1970.290533] vc4-drm gpu: swiotlb buffer is full (sz: 401408 bytes), total 32768 (slots), used 1304 (slots)
[ 1970.318031] vc4-drm gpu: swiotlb buffer is full (sz: 401408 bytes), total 32768 (slots), used 1304 (slots)
[ 2180.508360] v3d fec00000.v3d: MMU error from client CLE (4) at 0x144e1000, pte invalid
rpi@raspberrypi:~ $ ls /dev/video*
/dev/video10 /dev/video13 /dev/video16 /dev/video20 /dev/video23
/dev/video11 /dev/video14 /dev/video18 /dev/video21 /dev/video31
/dev/video12 /dev/video15 /dev/video19 /dev/video22
rpi@raspberrypi:~ $ cat /boot/config.txt
Raspberry Pi Documentation - The config.txt file
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
camera_auto_detect=1
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
dtoverlay=arducam-64mp
root@raspberrypi:/home/rpi# dpkg -l | grep libcamera
ii libcamera-apps 1.2.1-1+bookworm+1 arm64 libcamera-apps
ii libcamera-ipa:arm64 0.1.0+pi5~0-1 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.1.0+pi5~0-1 arm64 complex camera support library (tools)
ii libcamera0.1:arm64 0.1.0+pi5~0-1 arm64 complex camera support library
ii pipewire-libcamera:arm64 0.3.65-3+rpt2 arm64 PipeWire libcamera plugin
ii python3-libcamera 0.1.0+pi5~0-1 arm64 complex camera support library (Python bindings)
root@raspberrypi:/home/rpi# cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/
SUPPORT_URL=“Debian -- User Support
BUG_REPORT_URL=“https://bugs.debian.org/
root@raspberrypi:/home/rpi# cat /proc/cpuinfo
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03112
Serial : 100000008b8c0a07
Model : Raspberry Pi 4 Model B Rev 1.2
root@raspberrypi:/home/rpi# cat /proc/meminfo
MemTotal: 3884232 kB
MemFree: 887480 kB
MemAvailable: 1826872 kB
Buffers: 50756 kB
Cached: 1253968 kB
SwapCached: 0 kB
Active: 2136884 kB
Inactive: 431636 kB
Active(anon): 1510044 kB
Inactive(anon): 62628 kB
Active(file): 626840 kB
Inactive(file): 369008 kB
Unevictable: 228828 kB
Mlocked: 0 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Zswap: 0 kB
Zswapped: 0 kB
Dirty: 4 kB
Writeback: 40 kB
AnonPages: 1492640 kB
Mapped: 399416 kB
Shmem: 308876 kB
KReclaimable: 57484 kB
Slab: 101964 kB
SReclaimable: 57484 kB
SUnreclaim: 44480 kB
KernelStack: 8352 kB
PageTables: 24604 kB
SecPageTables: 0 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 2044512 kB
Committed_AS: 5933252 kB
VmallocTotal: 259653632 kB
VmallocUsed: 16860 kB
VmallocChunk: 0 kB
Percpu: 704 kB
CmaTotal: 524288 kB
CmaFree: 487188 kB
Hi
Have you ever tried the old OS(such like Bullseye OS, kernel version: 6.1.21)>? We do not release the camera driver on Bookworm now.
Hi, yes, I did. I tried Bullseye and even older with kernel 5.x.x.x. Thanks for looking at it.
Have you connected all four cameras to the hat board?
Hi, yes, I’ve tried with the four cameras. But anyway it used to work even with a single camera in the past.
Also, I’ve came back to bullseye 32-bit, which is exactly the version it used to work. And I’m having these output lines:
root@raspberrypi:/home/rpi# dmesg |grep cam
[    0.081367] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_64mp@1a
[    9.965625] arducam_64mp 10-001a: Device found Arducam 64MP.
[    9.980726] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
root@raspberrypi:/home/rpi# libcamera-still
error: XDG_RUNTIME_DIR not set in the environment.
Made X/EGL preview window
[0:01:36.581718942] [1282]  INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[0:01:36.621273264] [1283]  WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam_64mp'
[0:01:36.621364119] [1283]  WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:01:36.660205905] [1283] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam_64mp.json' not found for IPA module 'rpi/vc4'
[0:01:36.660606211] [1283] ERROR IPARPI ipa_base.cpp:117 Could not create camera helper for arducam_64mp
[0:01:36.660682213] [1283] ERROR RPI pipeline_base.cpp:818 Failed to load a suitable IPA library
[0:01:36.660795068] [1283] ERROR RPI vc4.cpp:219 Failed to register camera arducam_64mp 10-001a: -22
root@raspberrypi:/home/rpi# libcamera-still --version
libcamera-apps build: 7e4d3d71867f 17-07-2023 (07:34:42)
libcamera build: v0.0.5+83-bde9b04f
root@raspberrypi:/home/rpi# i2cdetect -l
i2c-20	i2c       	fef04500.i2c                    	I2C adapter
i2c-10	i2c       	i2c-22-mux (chan_id 1)          	I2C adapter
i2c-21	i2c       	fef09500.i2c                    	I2C adapter
i2c-0	i2c       	i2c-22-mux (chan_id 0)          	I2C adapter
i2c-22	i2c       	bcm2835 (i2c@7e205000)          	I2C adapter
root@raspberrypi:/home/rpi# i2cdetect -y 10
00:                         -- -- -- -- UU -- -- --
10: -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- --
20: -- -- -- -- 24 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Now with newest libcam apps:
root@raspberrypi:/home/rpi# libcamera-still -t 5000
[0:22:39.184497436] [2387]  INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[0:22:39.212471638] [2389]  WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam_64mp'
[0:22:39.212631155] [2389]  WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:22:39.251793882] [2389]  INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media0
[0:22:39.251898252] [2389]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:22:39.253097981] [2387]  INFO Camera camera.cpp:1033 configuring streams: (0) 4096x3074-YUV420
[0:22:39.253750568] [2389]  INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
[0:22:40.752251574] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:40.752365055] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:40.752407795] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:40.752441147] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:42.078932958] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:42.079037253] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:42.079071901] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:42.079104956] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:43.407012322] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:43.407128340] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:43.407159784] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:43.407189358] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:44.777592661] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:44.777693160] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:44.777727030] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:44.777760029] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:46.102312752] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:46.102417955] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:46.102451436] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:46.102483547] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:47.429263930] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:47.429374855] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:47.429408429] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:47.429440947] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:48.754431547] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:48.754598342] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:48.754670545] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:48.754741896] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:50.142791575] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:50.142893000] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:50.142927352] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:50.142959759] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:51.471890869] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:51.472031312] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:51.472068904] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:51.472101404] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:52.799206620] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:52.799319489] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:52.799354304] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:52.799387729] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
[0:22:54.127163489] [2389]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[18:cap]: Dequeue timer of 1000000.00us has expired!
[0:22:54.127321895] [2389] ERROR RPI pipeline_base.cpp:1356 Camera frontend has timed out!
[0:22:54.127375172] [2389] ERROR RPI pipeline_base.cpp:1357 Please check that your camera sensor connector is attached securely.
[0:22:54.127424709] [2389] ERROR RPI pipeline_base.cpp:1358 Alternatively, try another cable and/or sensor.
libcamera-apps build: 6437a8e7ddbc-intree-dirty 19-07-2023 (10:00:45)
libcamera build: v0.0.0+4367-ad9428b4
Hi again, finally I’ve made it working with this legacy 32-bit version, native driver and newest libcam apps from arducam scripts. But I’m having this error (even though the cameras are working):
root@raspberrypi:/home/rpi# libcamera-still -t 0
[0:06:21.673625665] [1319]  INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[0:06:21.701921059] [1321]  WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam_64mp'
[0:06:21.702087203] [1321]  WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:06:21.802910163] [1321]  INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media1 and ISP device /dev/media2
[0:06:21.803149676] [1321]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:06:21.804757373] [1319]  INFO Camera camera.cpp:1033 configuring streams: (0) 4096x3074-YUV420
[0:06:21.805622628] [1321]  INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected unicam format: 4624x3472-pRAA
[0:06:23.033000898] [1321]  INFO V4L2 v4l2_videodevice.cpp:1820 /dev/video0[18:cap]: Zero sequence expected for first frame (got 2)
[0:06:23.033160338] [1321]  INFO V4L2 v4l2_videodevice.cpp:1820 /dev/video1[19:cap]: Zero sequence expected for first frame (got 2)
[0:06:23.033416554] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:23.233235554] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:23.433165873] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:23.633100568] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:23.833049467] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:24.033016105] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:24.232919653] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:24.432858172] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:24.632794733] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:24.832738536] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:25.032886295] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:25.232607344] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:25.432637078] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:25.632484066] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:25.832447717] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:26.032421015] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:26.232328853] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:26.432357605] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:26.632245868] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:26.832215240] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:27.032108429] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:27.231991877] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:27.432146045] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:27.631969495] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:27.831838852] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:28.031796724] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:28.231714209] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:28.431878350] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:28.631683525] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:28.831649010] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:29.031625402] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:29.231412763] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:29.431361950] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:29.631288681] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:29.831274965] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:30.031166382] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:30.231109186] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:30.431050933] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:30.630980761] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:30.830968976] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:31.030847157] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:31.230831316] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:31.430941786] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:31.630668867] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:31.830652551] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:32.030540386] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:32.230493182] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:32.430451628] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:32.630392950] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:32.830335143] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:33.030347926] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:33.230153586] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:33.430155186] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:33.630081222] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:33.830133975] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:34.030126564] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:34.229910104] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:34.429859660] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:34.629705708] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:34.829642605] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:35.029743904] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:35.229604303] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:35.429597555] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:35.629580481] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:35.829409763] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:36.029282025] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:06:36.229319004] [1325] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
Please try the command below to close this error log:
“export LIBCAMERA_NOTPARSE_EMBEDDED_DATA=1”
