Kickstarter
IMX519 AF Camera
Raspberry Pi 3 Model B Rev 1.2
Official arducam documentation for driver and utilities
I am using the recently released IMX519 AF camera on a pi 3B. My use case is headless as a camera for klipper (a pi controlled 3d printer firmware). I followed the instructions on the product page, and I have the driver installed, and the arducam fork of jpg-streamer installed. The basic setup is working, but mjpg-streamer hits a constant 100% cpu and over time leads the system to a thermal throttle. I am trying to troubleshoot this, and I am noticing some quirks from every other install out there. These are a few issues I see:
Every blog/tutorial refers to /dev/v4l-subdev1 as the subdevice to control focus, but I don’t have that on my system. What I have is /dev/v4l-subdev0, and while it exposes several camera parameters, it does not show any focus settings
I cannot get libcamera-vid to work at all to stream the video. Every attempt ends in ERROR: *** failed to allocate capture buffers ***, and I have tried a few combinations of the command.
pi@ender3:~ $ dmesg | grep -E 'vc4|bcm|imx'
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i,margin_left=32,margin_right=32,margin_top=32,margin_bottom=32 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=36a7c549-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.061645] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.154397] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 1.980227] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.990003] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 3.135366] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.138286] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.142636] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.145179] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.284418] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 8.176694] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.284747] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.295103] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 8.303791] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.336744] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.345347] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.346035] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.346595] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.347074] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.347108] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.347136] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.347158] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.347180] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.347477] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.376268] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.403864] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.441129] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.478121] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.480740] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.480795] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.480824] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.480847] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.480893] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.481319] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.512988] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.513067] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.521099] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.521160] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.531661] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.531723] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.534573] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.534634] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.537697] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 8.537765] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 9.135505] fb0: switching to vc4 from simple
[ 9.142059] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.148044] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.148376] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 9.467312] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.495082] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.495361] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input1
[ 9.610710] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.631660] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.631946] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input2
[ 10.460383] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 10.470034] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 10.470345] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input3
[ 10.588272] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 10.592013] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 10.592317] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input4
[ 10.599016] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 10.599601] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 10.600070] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.601685] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.602352] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.602838] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 10.607463] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 10.608102] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 10.723578] imx519 10-001a: Device found is imx519
[ 10.724136] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 20.951370] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
I have checked that the driver is loaded, and the camera is active. This is the state of my system
I have a feeling my setup is missing a driver or a configuration settings, but I am not sure what. This is on a 32bit bullseye system.
pi@ender3:~ $ libcamera-vid -t 0 --inline --listen -o tcp://0.0.0.0:8080 --codec h264 -n
[41:06:35.844498022] [24869] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[41:06:35.855826787] [24873] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx519'
[41:06:35.855967168] [24873] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[41:06:35.856085002] [24873] ERROR CameraSensor camera_sensor.cpp:551 'imx519 10-001a': Camera sensor does not support test pattern modes.
[41:06:35.926585486] [24873] WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[41:06:35.927895827] [24873] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[41:06:35.928675003] [24873] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media3 and ISP device /dev/media0
[41:06:35.930181388] [24869] INFO Camera camera.cpp:1028 configuring streams: (0) 640x480-YUV420
[41:06:35.931050905] [24873] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 1280x720-SRGGB10_1X10 - Selected unicam format: 1280x720-pRAA
[41:06:35.934109600] [24869] ERROR Allocator framebuffer_allocator.cpp:98 Stream is not part of /base/soc/i2c0mux/i2c@1/imx519@1a active configuration
I get the same errors if I try a subset of the command, for example: libcamera-vid -t 0 --inline --listen -o tcp://0.0.0.0:8080
I get the same error. I had tried a few variations of the command to see if I can find a winning combination, but every time it fails at the same spot.
pi@ender3:~ $ libcamera-vid -t 0 --inline --listen -o tcp://0.0.0.0:8080 -n
[66:28:47.054357496] [16159] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[66:28:47.059919312] [16163] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx519'
[66:28:47.060060562] [16163] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[66:28:47.060125978] [16163] ERROR CameraSensor camera_sensor.cpp:551 'imx519 10-001a': Camera sensor does not support test pattern modes.
[66:28:47.103260875] [16163] WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[66:28:47.104393374] [16163] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[66:28:47.105230821] [16163] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media3 and ISP device /dev/media0
[66:28:47.106623059] [16159] INFO Camera camera.cpp:1028 configuring streams: (0) 640x480-YUV420
[66:28:47.107709516] [16163] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 1280x720-SRGGB10_1X10 - Selected unicam format: 1280x720-pRAA
[66:28:47.110497221] [16159] ERROR Allocator framebuffer_allocator.cpp:98 Stream is not part of /base/soc/i2c0mux/i2c@1/imx519@1a active configuration
I’ve tried stracing the command, but I don’t see an obvious place where it fails.
I suspect my problem is partly because I have some misconfiguration somewhere. For instance, as I mentioned in the OP, I have a /dev/v4l-subdev0 and no /dev/v4l-subdev1, and my subdev does not expose the focus controls. This seems different to what everyone else reports. Is it perhaps related?
I understand, and to be clear, I am not complaining about the lack of hardware accelerated mjpg encoding. I’d like to get a native x264 stream and ditch mjpeg - h264 is a much better format for streaming and all clients can natively process it.
I think an improvement would be to only capture and encode when there is a client to send to. I thought that was what the original mjpegstreamer did with an rpi camera. At least I do not see 100% CPU usage on my other systems running legacy mmal mjpegstreamer (only about 4% when streaming, less when not), only the rpi that is using libcamera seems to use 100%.
I have ended up using this to stream h264 and it only uses about 40% of CPU when there is a connection.
We tested and didn’t find this problem,
Maybe you can comment out gpu_mem in /boot/config.txt and increase dtoverlay=vc4-kms-v3d,cma-128 appropriately
E.g: dtoverlay=vc4-kms-v3d,cma-192
pi@ender3:~ $ libcamera-vid --autofocus -n -t 0 --width=1280 --height=1024 --framerate=10 --inline --listen -o tcp://0.0.0.0:8080
[0:02:20.863280258] [937] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[0:02:20.868737261] [941] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx519'
[0:02:20.868887987] [941] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:02:20.868983245] [941] ERROR CameraSensor camera_sensor.cpp:551 'imx519 10-001a': Camera sensor does not support test pattern modes.
[0:02:20.911293000] [941] WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[0:02:20.912207769] [941] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:02:20.912823327] [941] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media3 and ISP device /dev/media0
[0:02:20.913918561] [937] INFO Camera camera.cpp:1028 configuring streams: (0) 1280x1024-YUV420
[0:02:20.914452298] [941] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 1920x1080-SRGGB10_1X10 - Selected unicam format: 1920x1080-pRAA
[0:02:20.916657089] [937] ERROR Allocator framebuffer_allocator.cpp:98 Stream is not part of /base/soc/i2c0mux/i2c@1/imx519@1a active configuration
I have a longer length cable (75cms) because my mount on the 3d printer requires a longer cable. This cable has worked well for over 100 hours on the picam v2 and it works for capturing video with the arducam fork of mjpg-streamer. I don’t think the cable is the fault, I am bringing it up since it’s probably the only variable that might be different between my setup and your lab.
These are from my latest dmesg after a reboot with the new config.txt. After glancing through, I see some errors with the wifi chipset (which should be unrelated), and a couple of instances of
A quick google search tells me I need vc4-kms-v3d for a 32bit OS, I’ll make this change, reboot and test.
Full dmesg:
[ 6.905661] systemd-journald[132]: File /var/log/journal/333c0c782d4679d8674440ae61f83757/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 8.100883] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.103487] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.103526] [vc_sm_connected_init]: start
[ 8.108863] mc: Linux media interface: v0.10
[ 8.118962] [vc_sm_connected_init]: installed successfully
[ 8.158435] videodev: Linux video capture interface: v2.00
[ 8.203071] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.213898] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.281190] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.294637] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.295215] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.295676] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.296033] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.296073] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.296101] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.296124] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.296162] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.309648] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.360892] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.360929] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.361506] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.361938] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.362283] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.362319] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.362348] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.362371] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.362394] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.362633] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.392103] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.392417] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.403980] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 8.406254] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.406314] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.413144] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.413206] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.416159] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.416221] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.419525] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 8.419595] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 8.698200] i2c i2c-11: Added multiplexed i2c bus 0
[ 8.698794] i2c 10-001a: Fixing up cyclic dependency with 3f801000.csi
[ 8.699225] i2c i2c-11: Added multiplexed i2c bus 10
[ 9.034493] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.253803] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.282365] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 9.381831] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 9.388441] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.389207] usbcore: registered new interface driver brcmfmac
[ 9.405324] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.bin failed with error -2
[ 9.545864] smsc95xx 1-1.1:1.0 enxb827eb1463c0: renamed from eth0
[ 9.579259] checking generic (3eaf0000 10a800) vs hw (0 ffffffff)
[ 9.579298] fb0: switching to vc4 from simple
[ 9.580057] Console: switching to colour dummy device 80x30
[ 9.589696] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.602249] random: crng init done
[ 9.602273] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.631834] Registered IR keymap rc-cec
[ 9.632095] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.632409] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 9.675934] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.676132] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.688197] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 10.535800] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 10.544302] Registered IR keymap rc-cec
[ 10.544600] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 10.544901] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input1
[ 10.551046] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 10.551670] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 10.552128] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.552592] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.553063] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 10.553444] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 10.621414] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 10.622079] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 10.670157] imx519 10-001a: Device found is imx519
[ 10.670755] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 11.326908] 8021q: 802.1Q VLAN Support v1.8
[ 11.588855] Adding 262140k swap on /var/swap. Priority:-2 extents:1 across:262140k SSFS
[ 12.065033] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 13.014231] smsc95xx 1-1.1:1.0 enxb827eb1463c0: hardware isn't capable of remote wakeup
[ 13.029768] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 13.162983] smsc95xx 1-1.1:1.0 enxb827eb1463c0: Link is Down
[ 13.169502] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 14.291184] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.239050] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 19.076364] uart-pl011 3f201000.serial: no DMA platform data
[ 20.952599] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
