- Where did you get the camera module(s)? ANODAS
- Model number of the product(s). Arducam 12MP IMX477 IR-Cut Filter, B0270
- What hardware/platform were you working on? Raspberry Pi 3A+ bullseye 11
- Instructions you have followed. (link/manual/etc.) 12MP IMX477 Motorized IR-CUT Camera Module - Arducam and Troubleshooting - Arducam Wiki
- Problems you were having. libcamera hello no cameras available when vcgencmd get_camera
supported=1 detected=1, libcamera interfaces=0 - The dmesg log from your hardware.
dmesg | grep -i video
[ 10.366157] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 10.577059] videodev: Linux video capture interface: v2.00
[ 10.759063] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 10.759527] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 10.759985] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 10.760278] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 10.764544] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 10.765533] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 10.766024] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 10.766353] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 10.803883] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 11.120886] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 11.131759] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 11.137226] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 11.145949] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 11.158608] bcm2835_v4l2-0: V4L2 device registered as video0 - stills mode > 1280x720
[ 11.163930] bcm2835_v4l2-0: Broadcom 2835 MMAL video capture loaded.
- Troubleshooting attempts you’ve made. Tried 2 different ribon cables, Checked the camera pins to ground, checked config file, for gpu memory.
- What help do you need? I would like to get a picture taken with it so i can make sure it works
