system
March 25, 2020, 8:22pm
1
I am trying to capture 12-bit data using the MT9F001 camera. Following advice in the issue here , I purchased:
I’m not able to find any config files support this configuration in 12-bit mode. I tried 8-bit mode in this directory: Config/USB3.0_UC-425_Rev.C/MT9F001_RAW_8b_1096x822_37fps.cfg
but my images look like this:
wong
March 27, 2020, 3:11am
2
Hi @z_fara ,
Can you attach a picture of your wiring?
system
March 31, 2020, 7:21pm
3
I was able to get a good photo using this config file but I’m not sure how to change the resolution or frame rate.
lvbin
May 11, 2020, 12:14am
4
Changing the resolution is not a easy thing. We should configure it following the sensor’s datasheet.
