Wide Angle Version of Autofocus Cameras with new sensors
Hey there,
just got the newsletter announcing the new ezBOX models! Sounds great!
The only thing that makes them unusable for me, just like the 16MP B0371, are the limited view angles.
Our specific need would be covered with FOV (horizontally) between 90-140°.
Just to let you know and maybe let others bump this thread for similar needs!
Hi @mmoollllee
Sounds good.
We’ve been reviewing your advice and considering adding a new one with a wider FOV to the ezBOX series. Please stay tuned to our newsletter :))
BUMPPP!! More wideangle cameras pls!
Just wondering if these ezBOX models have some kind of power / standby control? Is it possible to keep them powered via usb but enable some kind of standby? We only need one image every few minutes…
Hi @mmoollllee
Please get in touch with our Sales Team([email protected]). They will respond to you within three working days.
So I finally came up with a servo-controlled focus system meant to drive an M12 lens on the B0449 camera.
I’ve tested several M12 lenses that I previously used on the B0272. I’m replacing the B0272 mainly because its magnetic focus mechanism is too wobbly for setups with even minimal vibrations.
I know the sensor sizes differ, but optically the combination with LN056, LN069 and LN033 look good on the B0449 in terms of distortion.
The only issue is the color tint. Images appear purple when using these lenses on the B0449.
I’m wondering if this is something that can be corrected in the tuning file (rpi.awb), or if its a general mismatch in IR-cut characteristics?
Can Arducam help me figure out how to fix the color issue?
Or can you recommend other M12 lenses in the 100–140° FOV range that work well with the B0449 sensor?
Should I open a new thread for this, or is it simply something that goes beyond Arducam’s support?
Looking forward to a reply :slight_smile:
A pic of my servo-controlled focus. Wondering if that might be interesting for anyone?
Hi there,
Which Lens do you really want?
I can correct the color tint for you by generating a tuning file. Besides, is it possible to join our Discord server? We’re active there.
