UCTRONICS
B0266
Raspberry PI 4B
https://www.arducam.com/docs/cameras-for-raspberry-pi/synchronized-stereo-camera-hat/camarry-1mp2-stereoscopic-camera-hat/
no
So after a while I was finally able to get the camera working on my RPi 4. It detects the video0 device, all is good. But then I try to simply capture the video with VLC (or any other software) and I see that the brightness is constantly jumping up several times then back to the original setting. Is there any way to control that?
Also, for some reason I’m unable to control frame rate using v4l2-ctl. The command v4l2-ctl -l
only lists exposure, gain and trigger_mode (what is it and what are the values?)
