Which pin controls manual IR/color switching on Arducam IMX290 for Raspberry Pi 4?
Hi all, I’ve got the Arducam 2MP Ultra Low Light STARVIS IMX290 Motorized IR-CUT Camera for Raspberry Pi (https://www.arducam.com/product/presale-arducam-2mp-ultra-low-light-starvis-imx290-motorzied-ir-cut-camera-for-raspberry-pi/) hooked up to a Raspberry Pi 4. I need to switch the lens mode between IR and color manually using a low/high trigger from the Pi, but I’m not sure which pin to drive. Does anyone know which pin should be set High or Low? Also, do I need to remove the round rubber shield/sensor cover on the IR/3V3 pin pair before this will work?
Welcome! Can you tell me the exact pin labels you see on the board and which way you’re reading them? A photo of the pin area would help too. On these motorized IR-CUT units the switching is usually handled through a trigger pin pair, but I want to make sure we’re looking at the same silkscreen before giving you high/low directions.
Sure. The camera is the Arducam 2MP Ultra Low Light STARVIS IMX290 Motorized IR-CUT Camera for Raspberry Pi. Reading the pins from right to left, the layout is: 3V3+, SIOD, SIOC, XVS, DGND, TRIGGER, IR, 3V3+. Here’s a photo of the board: https://cdn.arducam.com/forum/636ba472373eba32e8459f7dc28a8c3e/Emb9apmbG5H0ut4L.png. I haven’t run any code or captured logs yet since I’m still checking the wiring before connecting anything.
Thanks, that’s helpful. Just to make sure I’m not missing anything - have you attempted any code or seen any error logs from a test run, or is this still at the wiring/planning stage?
No code or logs yet. I was just reviewing the pin layout from right to left before wiring it up.
Got it. Looking at the pin labels you posted, the relevant pair for manual control is TRIGGER/IR - that’s what the low/high trigger uses to flip between IR and color mode. The IR/3V3 pair can have a protective rubber shield/sensor cover on it, and depending on your board that cover may need to be removed before you can drive the switching manually. I’d start with the official quick start guide for the IR-Sensitive Camera with IRCUT: Quick start - Arducam Wiki. It covers the trigger wiring and manual mode switching for this camera. Follow that and check whether your board still has the shield over IR/3V3. If the behavior doesn’t match or you’re still stuck after going through it, post back and we’ll keep digging.
