Which Bullseye for 64MP Pi Hawk-eye drivers on Pi 4B: 32-bit or 64-bit?
Hi all, hope this is the right place for a pre-install question. I’ve got a B0399 64MP Pi Hawk-eye Camera Module (Raspberry Pi camera series) that I haven’t even powered up yet, because the manual is a bit ambiguous.
It lists the drivers and says you need a 2022 Pi OS, and that you should NOT run a software update. But it never actually says whether that means the 32-bit or the 64-bit Bullseye OS.
Before I flash anything I wanted to ask: for the drivers, should I use 32-bit or 64-bit Bullseye? And is there a specific reason they tell you not to do a software update? I’d rather understand it than just blindly follow it.
Hi, welcome. You’re fine asking here before installing.
A couple of things that will help me get you a solid answer:
  1. Which board(s) are you planning to run this on?
  2. Where exactly in the manual does it mention the driver install and the 2022 Pi OS requirement? A quote or photo of that page helps.
  3. Can you paste the wording around the “do not update” instruction?
The 32-bit vs 64-bit question specifically depends on the platform, so let me know and I’ll check with our engineering team before you flash anything.
Sure. Target platforms are a Raspberry Pi Zero 2 W and a Raspberry Pi 4B 8GB. The Pi 4B is the one I’m most unsure about since it’s 8GB and I’d normally reach for the 64-bit image, but I don’t want to install the wrong thing and have the camera drivers fall over.
The manual section basically says something like drivers are needed for the camera and that you need the 2022 Pi OS release, and then there’s a note not to perform a software update. It doesn’t say 32-bit or 64-bit anywhere that I can find.
On the update question — is it that a newer kernel or firmware breaks the driver, or is it just that the packaged driver needs to stay matched to that OS release? Trying to work out how careful I need to be.
Also, just so you know where I’m at: I’m cautious by nature, so I haven’t made any attempts yet. No flashing, no driver install, nothing. I’m holding off entirely until I know which OS to use, so there aren’t any logs or error messages to share I’m afraid.
That’s a sensible approach, no problem at all — better to ask first than to reflash twice.
I’ve raised this with our engineering team to get a definitive answer on the OS architecture for the B0399 module, and I’ll also confirm what the software update note is really about. Bear with me while I get that confirmation rather than guessing.
In the meantime, if you can grab the exact wording of that manual section (even just typed out), it’ll help me match it up against what engineering tells me.
Thanks, appreciate you checking rather than just picking one.
The closest I can get to the wording is: “drivers required”, “2022 Pi OS”, “do not perform software update”. It’s terse, which is why I ended up here. No mention of bitness at all.
So to be clear, my open questions are: (a) 32-bit or 64-bit Bullseye for the drivers, and (b) why no software update.
Heard back from our engineer — here’s the answer.
(a) The 64MP Pi Hawk-eye Camera Module works on BOTH the 32-bit and 64-bit Bullseye OS. It isn’t restricted to one architecture, so you can go with either one. On the Pi 4B 8GB the 64-bit image is perfectly fine, and 32-bit will work as well if you prefer that for compatibility with something else.
(b) The note about not doing a software update is covered by the messages/notes printed in the manual — please read those carefully and follow them as written. That’s the bit that matters, rather than the OS bitness.
So: install whichever Bullseye flavour you like, and pay attention to the specific notes/messages in the manual when you set the drivers up. Since you haven’t started yet, that’s the point to follow them from the very first boot, not after. If anything behaves oddly once you do install, post back here with the steps you took and we’ll take it from there.
