Where to find driver source code for ArduCam 64MP camera on Raspberry Pi?
Hi, I’m working with the ArduCam 64MP Ultra High-Res Camera for Raspberry Pi (https://www.arducam.com/64mp-ultra-high-res-camera-raspberry-pi/) and I’m trying to find the driver source code for it. Is the source available anywhere? I’d like to look at it before I build anything around it.
Hi, thanks for reaching out. Before I point you in the right direction, can you tell me a bit more about what you’re trying to do? The 64MP camera ships with our own driver stack, and where you get the source depends on the host platform. What board are you planning to run it on?
The plan is to run it on a board with an ARM64 processor. Not a Raspberry Pi - a different ARM64 board. So I guess my real question is whether the drivers are available for ARM64 platforms in general, and whether I can get the source to adapt them if needed.
Got it, that helps clarify things. Quick question so I don’t give you the wrong answer - when you say ARM64 board, are you talking about an NVIDIA Jetson by any chance? A lot of people go that route for the ARM64 + camera combo, and the answer is different depending on the platform.
Yeah, essentially that class of board - Jetson-style ARM64 platform. I was hoping to reuse the 64MP camera on it rather than the Pi. Is there a driver I can point to on that platform?
Thanks for confirming. I checked on this for you, and the honest answer is that the 64MP camera has not been adapted for the Jetson platform. The driver work for that sensor on Jetson simply hasn’t been done, so there isn’t a source tree or binary I can hand you that will make it work there. It’s not a matter of a config flag or a quick rebuild - the platform adaptation itself is missing.
Okay, that’s disappointing but good to know. So to be clear - there’s no supported path to get the 64MP running on a Jetson right now? Even if I wanted to write the adaptation myself, there’s nothing from your side to start from?
Correct. At present the 64MP camera has not been adapted on the Jetson platform, so it can’t be used with Jetson - there’s no driver source or binary provided for that combination. If your project requires a Jetson host, you’d want to look at a camera module that already has Jetson support rather than trying to port the 64MP. If you let me know what your resolution and interface requirements are, I can help you figure out which of our modules would actually fit that board. Sorry I don’t have a better answer on this one.
