Where to find B0249 driver for Jetson AGX Xavier / Auvidea X221D on Jetpack 32.6.1?
Hi, I’m trying to get a B0249 camera working on a Jetson AGX Xavier and I can’t find the driver for this combination anywhere. Does anyone know where the required driver lives for this setup? Here’s a photo of the module I have: https://cdn.arducam.com/forum/a55d08e6ff361f2a6aa8868cf499d60c/MicrosoftTeams-image%20(1).png
Welcome. Can you share a few things so we can point you at the right driver?
  • Is this a stock Jetpack install, or have you already flashed some driver package?
  • Which carrier board is the module mounted on (the official Jetson AGX Xavier devkit board, or something else)?
  • Output of uname -a and cat /etc/nv_tegra_release
  • lsmod | grep -i cam and dmesg | grep -i -E 'imx|cam|vi' right after boot
Stock install, nothing flashed yet. Here’s what I get:
uname -a → Linux xavier 4.9.253-tegra #1 SMP PREEMPT aarch64 GNU/Linux
/etc/nv_tegra_release → # R32 (release), REVISION: 6.1, GCID: 29990486, BOARD: t186ref, EABI: aarch64
dmesg shows nothing camera-related at all, no sensor probing messages anywhere. lsmod has nothing for the camera either. I honestly have no idea which driver I’m even supposed to install here, that’s kind of why I’m asking.
Thanks. Zero camera-related messages in dmesg is pretty normal when no driver/device tree is present at all — the sensor just never gets probed.
One thing matters a lot here: what carrier board is the module sitting on? The driver package you need depends entirely on that.
It’s on an Auvidea X221D carrier board, not the NVIDIA devkit one. I need that particular board for the ports/form factor in our product, so swapping to the official devkit board isn’t really an option for us.
Got it. Before I go further — are you running the stock Jetpack 32.6.1 kernel, or did you flash an Auvidea-modified BSP/kernel for the X221D? Some vendors ship their own kernel tree for these boards, and that changes what we’d be looking at.
I checked. Auvidea gives you their own BSP/kernel sources for the board, but there’s nothing in there about this camera. So I’m on the stock Jetpack 32.6.1 kernel, just running it on their board.
OK, this is the answer, then. The Auvidea X221D is a third-party carrier board, and our camera drivers/device tree overlays are built and validated for the official Jetson carrier board only. We don’t currently provide a driver for third-party boards, which is why you can’t find one for this combination. The CSI lane mapping, power sequencing and I2C addressing on the X221D are defined by Auvidea’s own board design, not ours, so our stock driver wouldn’t come up correctly on it anyway.
Understood. So is there any way at all to make this work — port the device tree myself, adapt Auvidea’s BSP, anything? Or am I basically stuck using the official board?
Being straight with you: for a supported setup, the camera needs to run on the official carrier board. If it has to be the X221D, that’s outside what we can support from the driver side — you’d be doing custom device tree work on top of Auvidea’s BSP, and we can’t provide or guarantee a driver for that. If you want to explore it further for your product, [email protected] is the right channel to discuss the specific requirement.
Fair enough, thanks for being clear instead of sending me in circles. I’ll reach out to sales and see what they say. Appreciate the quick replies.
Summary for anyone else finding this thread: B0249 + Jetson AGX Xavier + Jetpack 32.6.1 on an Auvidea X221D carrier board is not a supported configuration. Arducam supplies the driver for the official Jetson carrier board only — no driver is provided for third-party boards, which is why nothing appears in dmesg/lsmod on that setup. If your design requires a third-party board, contact [email protected] for further help. If you can use the official carrier board, the standard driver installation applies.
