dmesg:
[ 0.000000] Linux version 6.1.12-v7l+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1631 SMP Mon Feb 20 17:33:29 GMT 2023
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s36884 r8192 d24556 u69632
[ 0.000000] pcpu-alloc: s36884 r8192 d24556 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 489792
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:[email protected] smsc95xx.macaddr=E4:5F:01:C3:B0:50 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=d7216489-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000015a00000-0x0000000019a00000] (64MB)
[ 0.000000] Memory: 1534608K/1966080K available (10240K kernel code, 1501K rwdata, 3128K rodata, 2048K init, 636K bss, 103792K reserved, 327680K cma-reserved, 1179648K highmem)
[ 0.000000] ftrace: allocating 37060 entries in 109 pages
[ 0.000000] ftrace: allocated 109 pages with 5 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000017] Switching to timer-based delay loop, resolution 18ns
[ 0.000326] Console: colour dummy device 80x30
[ 0.000388] printk: console [tty1] enabled
[ 0.000441] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000464] pid_max: default: 32768 minimum: 301
[ 0.000580] LSM: Security Framework initializing
[ 0.000749] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000771] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001971] cgroup: Disabling memory control group subsystem
[ 0.002159] CPU: Testing write buffer coherency: ok
[ 0.002210] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.002543] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003412] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.003426] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003540] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003664] Setting up static identity map for 0x200000 - 0x20003c
[ 0.003811] rcu: Hierarchical SRCU implementation.
[ 0.003822] rcu: Max phase no-delay instances is 1000.
[ 0.004525] smp: Bringing up secondary CPUs …
[ 0.005393] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.006357] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.007312] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.007422] smp: Brought up 1 node, 4 CPUs
[ 0.007440] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.007454] CPU: All CPU(s) started in HYP mode.
[ 0.007463] CPU: Virtualization extensions available.
[ 0.008049] devtmpfs: initialized
[ 0.020097] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.020265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020290] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.029145] pinctrl core: initialized pinctrl subsystem
[ 0.030187] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.033046] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.033642] audit: initializing netlink subsys (disabled)
[ 0.033828] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.034329] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.035053] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.035069] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035423] Serial: AMBA PL011 UART driver
[ 0.045249] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.070025] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-02-22T10:46:02, variant start
[ 0.080040] raspberrypi-firmware soc:firmware: Firmware hash is 74a4b109e7f5be465332a1f102649d34f8498d05
[ 0.122886] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.127164] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.130676] SCSI subsystem initialized
[ 0.130865] usbcore: registered new interface driver usbfs
[ 0.130914] usbcore: registered new interface driver hub
[ 0.130964] usbcore: registered new device driver usb
[ 0.131218] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.131365] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.131607] pps_core: LinuxPPS API ver. 1 registered
[ 0.131618] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.131640] PTP clock support registered
[ 0.132530] vgaarb: loaded
[ 1.405191] clocksource: Switched to clocksource arch_sys_counter
[ 1.435484] VFS: Disk quotas dquot_6.6.0
[ 1.435568] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.435689] FS-Cache: Loaded
[ 1.435873] CacheFiles: Loaded
[ 1.443036] NET: Registered PF_INET protocol family
[ 1.443289] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.445104] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 1.445174] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.445258] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.445318] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 1.445450] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.445579] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.445615] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.445793] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.446272] RPC: Registered named UNIX socket transport module.
[ 1.446284] RPC: Registered udp transport module.
[ 1.446294] RPC: Registered tcp transport module.
[ 1.446303] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.446318] PCI: CLS 0 bytes, default 64
[ 1.448142] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.488995] Initialise system trusted keyrings
[ 1.489304] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.496237] zbud: loaded
[ 1.498394] NFS: Registering the id_resolver key type
[ 1.498435] Key type id_resolver registered
[ 1.498445] Key type id_legacy registered
[ 1.498544] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.498556] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.499592] Key type asymmetric registered
[ 1.499606] Asymmetric key parser ‘x509’ registered
[ 1.499839] bounce: pool size: 64 pages
[ 1.499965] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.500132] io scheduler mq-deadline registered
[ 1.500145] io scheduler kyber registered
[ 1.501603] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 42)
[ 1.507503] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.507537] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.507595] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.507650] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x007fffffff → 0x0400000000
[ 1.508483] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.508499] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.508516] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.508570] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.508708] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.511731] PCI: bus0: Fast back to back transfers disabled
[ 1.511749] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.511927] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.512074] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.512151] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.577261] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.577408] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.577519] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.577882] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.578363] PCI: bus1: Fast back to back transfers disabled
[ 1.578377] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.578411] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.578432] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.578505] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.578522] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.578794] pcieport 0000:00:00.0: enabling device (0000 → 0002)
[ 1.578965] pcieport 0000:00:00.0: PME: Signaling with IRQ 46
[ 1.580002] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 1.580020] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.580498] Console: switching to colour frame buffer device 240x67
[ 1.589337] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 1.595177] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.597476] iproc-rng200 fe104000.rng: hwrng registered
[ 1.597729] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.598721] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.608509] brd: module loaded
[ 1.615352] loop: module loaded
[ 1.615931] Loading iSCSI transport class v2.0-870.
[ 1.619908] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.715251] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.716177] usbcore: registered new interface driver r8152
[ 1.716235] usbcore: registered new interface driver lan78xx
[ 1.716304] usbcore: registered new interface driver smsc95xx
[ 1.762289] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.762320] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.766287] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.767173] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.767196] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.767215] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.767473] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.767491] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.767505] usb usb1: Product: xHCI Host Controller
[ 1.767517] usb usb1: Manufacturer: Linux 6.1.12-v7l+ xhci-hcd
[ 1.767529] usb usb1: SerialNumber: 0000:01:00.0
[ 1.768069] hub 1-0:1.0: USB hub found
[ 1.768117] hub 1-0:1.0: 1 port detected
[ 1.768797] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.768815] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.768829] usb usb2: Product: xHCI Host Controller
[ 1.768840] usb usb2: Manufacturer: Linux 6.1.12-v7l+ xhci-hcd
[ 1.768851] usb usb2: SerialNumber: 0000:01:00.0
[ 1.769346] hub 2-0:1.0: USB hub found
[ 1.769396] hub 2-0:1.0: 4 ports detected
[ 1.770653] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.770871] dwc_otg: FIQ enabled
[ 1.770881] dwc_otg: NAK holdoff enabled
[ 1.770890] dwc_otg: FIQ split-transaction FSM enabled
[ 1.770902] Module dwc_common_port init
[ 1.771253] usbcore: registered new interface driver uas
[ 1.771347] usbcore: registered new interface driver usb-storage
[ 1.771515] mousedev: PS/2 mouse device common for all mice
[ 1.775551] sdhci: Secure Digital Host Controller Interface driver
[ 1.775565] sdhci: Copyright(c) Pierre Ossman
[ 1.775999] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.778835] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.779049] hid: raw HID events driver (C) Jiri Kosina
[ 1.779179] usbcore: registered new interface driver usbhid
[ 1.779190] usbhid: USB HID core driver
[ 1.783825] Initializing XFRM netlink socket
[ 1.783869] NET: Registered PF_PACKET protocol family
[ 1.783946] Key type dns_resolver registered
[ 1.784531] Registering SWP/SWPB emulation handler
[ 1.785267] registered taskstats version 1
[ 1.785304] Loading compiled-in X.509 certificates
[ 1.786090] Key type .fscrypt registered
[ 1.786103] Key type fscrypt-provisioning registered
[ 1.798267] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.798737] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.798843] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 51, base_baud = 0) is a PL011 rev2
[ 1.810289] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default
[ 1.810807] printk: console [ttyS0] disabled
[ 1.810904] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 52, base_baud = 62500000) is a 16550
[ 1.811189] printk: console [ttyS0] enabled
[ 1.812305] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.812607] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.813512] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.813530] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.841135] of_cfs_init
[ 1.841343] of_cfs_init: OK
[ 1.884476] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.884742] Waiting for root device PARTUUID=d7216489-02…
[ 1.922503] mmc1: new high speed SDIO card at address 0001
[ 1.983790] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[ 1.984530] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[ 1.987154] mmcblk0: p1 p2
[ 1.987607] mmcblk0: mmc0:5048 SD32G 29.7 GiB (quirks 0x00004000)
[ 2.003338] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.003404] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.003917] devtmpfs: mounted
[ 2.011905] Freeing unused kernel image (initmem) memory: 2048K
[ 2.035449] Run /sbin/init as init process
[ 2.035462] with arguments:
[ 2.035471] /sbin/init
[ 2.035481] splash
[ 2.035491] with environment:
[ 2.035500] HOME=/
[ 2.035510] TERM=linux
[ 2.055231] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.247816] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.247844] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.247860] usb 1-1: Product: USB2.0 Hub
[ 2.249702] hub 1-1:1.0: USB hub found
[ 2.249989] hub 1-1:1.0: 4 ports detected
[ 2.338168] systemd[1]: System time before build time, advancing clock.
[ 2.518923] NET: Registered PF_INET6 protocol family
[ 2.520220] Segment Routing with IPv6
[ 2.520256] In-situ OAM (IOAM) with IPv6
[ 2.591318] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.592076] systemd[1]: Detected architecture arm.
[ 2.593404] systemd[1]: Set hostname to .
[ 2.605191] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 2.751400] usb 1-1.3: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.10
[ 2.751429] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.751445] usb 1-1.3: Product: mini keyboard
[ 2.751458] usb 1-1.3: Manufacturer:
[ 2.762130] input: mini keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:1997:2433.0001/input/input0
[ 2.825890] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ mini keyboard] on usb-0000:01:00.0-1.3/input0
[ 2.832617] input: mini keyboard Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:1997:2433.0002/input/input1
[ 2.833003] input: mini keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:1997:2433.0002/input/input2
[ 2.895557] input: mini keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:1997:2433.0002/input/input3
[ 2.895879] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ mini keyboard] on usb-0000:01:00.0-1.3/input1
[ 2.995188] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 3.156155] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c246, bcdDevice=70.03
[ 3.156184] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.156201] usb 1-1.4: Product: G300s Optical Gaming Mouse
[ 3.156214] usb 1-1.4: Manufacturer: Logitech
[ 3.168859] input: Logitech G300s Optical Gaming Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C246.0003/input/input4
[ 3.169244] hid-generic 0003:046D:C246.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech G300s Optical Gaming Mouse] on usb-0000:01:00.0-1.4/input0
[ 3.177905] input: Logitech G300s Optical Gaming Mouse Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C246.0004/input/input5
[ 3.245696] input: Logitech G300s Optical Gaming Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C246.0004/input/input6
[ 3.246336] hid-generic 0003:046D:C246.0004: input,hiddev96,hidraw3: USB HID v1.10 Keyboard [Logitech G300s Optical Gaming Mouse] on usb-0000:01:00.0-1.4/input1
[ 3.859977] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 4.043312] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.150458] systemd[1]: Created slice system-getty.slice.
[ 4.151726] systemd[1]: Created slice system-modprobe.slice.
[ 4.152639] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.153498] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.154196] systemd[1]: Created slice User and Session Slice.
[ 4.154647] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.155691] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.156444] systemd[1]: Reached target Slices.
[ 4.156662] systemd[1]: Reached target Swap.
[ 4.157579] systemd[1]: Listening on Syslog Socket.
[ 4.158200] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.158586] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.159514] systemd[1]: Listening on Journal Audit Socket.
[ 4.160215] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.160988] systemd[1]: Listening on Journal Socket.
[ 4.162664] systemd[1]: Listening on udev Control Socket.
[ 4.163355] systemd[1]: Listening on udev Kernel Socket.
[ 4.164171] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.168562] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.173738] systemd[1]: Mounting RPC Pipe File System…
[ 4.179962] systemd[1]: Mounting Kernel Debug File System…
[ 4.186572] systemd[1]: Mounting Kernel Trace File System…
[ 4.187332] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.195050] systemd[1]: Starting Restore / save the current clock…
[ 4.201373] systemd[1]: Starting Set the console keyboard layout…
[ 4.207966] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 4.214311] systemd[1]: Starting Load Kernel Module configfs…
[ 4.221332] systemd[1]: Starting Load Kernel Module drm…
[ 4.228406] systemd[1]: Starting Load Kernel Module fuse…
[ 4.245336] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.251056] systemd[1]: Starting File System Check on Root Device…
[ 4.261854] systemd[1]: Starting Journal Service…
[ 4.296165] systemd[1]: Starting Load Kernel Modules…
[ 4.299973] fuse: init (API version 7.37)
[ 4.304379] systemd[1]: Starting Coldplug All udev Devices…
[ 4.323224] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.323927] systemd[1]: Mounted RPC Pipe File System.
[ 4.324509] systemd[1]: Mounted Kernel Debug File System.
[ 4.335451] systemd[1]: Mounted Kernel Trace File System.
[ 4.337065] systemd[1]: Finished Restore / save the current clock.
[ 4.339237] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.340726] systemd[1]: [email protected]: Succeeded.
[ 4.341805] systemd[1]: Finished Load Kernel Module configfs.
[ 4.343432] systemd[1]: [email protected]: Succeeded.
[ 4.344513] systemd[1]: Finished Load Kernel Module fuse.
[ 4.356879] systemd[1]: Mounting FUSE Control File System…
[ 4.365692] systemd[1]: Mounting Kernel Configuration File System…
[ 4.383857] systemd[1]: Started File System Check Daemon to report status.
[ 4.397522] i2c_dev: i2c /dev entries driver
[ 4.411202] systemd[1]: Mounted FUSE Control File System.
[ 4.413448] systemd[1]: Finished Load Kernel Modules.
[ 4.414342] systemd[1]: Mounted Kernel Configuration File System.
[ 4.440771] systemd[1]: Starting Apply Kernel Variables…
[ 4.488647] systemd[1]: [email protected]: Succeeded.
[ 4.489763] systemd[1]: Finished Load Kernel Module drm.
[ 4.504902] systemd[1]: Finished Apply Kernel Variables.
[ 4.506714] systemd[1]: Finished File System Check on Root Device.
[ 4.511693] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.635107] systemd[1]: Started Journal Service.
[ 4.672524] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.818534] systemd-journald[151]: Received client request to flush runtime journal.
[ 4.830123] systemd-journald[151]: File /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.941171] mc: Linux media interface: v0.10
[ 6.058161] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.107404] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.109446] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.109478] [vc_sm_connected_init]: start
[ 6.116129] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.123503] [vc_sm_connected_init]: installed successfully
[ 6.193146] videodev: Linux video capture interface: v2.00
[ 6.361592] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.404023] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.479668] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.505474] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.505843] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.515274] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.522576] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.522616] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.522641] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.522659] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.522676] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.542232] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.558636] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.565046] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.565732] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.567203] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.567654] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.567694] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.567716] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.567749] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.567778] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.568101] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.631465] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.631508] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.639419] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.639460] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.705536] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.751762] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.751829] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.775917] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.775969] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.780883] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.780924] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 7.040532] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.106451] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 7.159447] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.296473] Console: switching to colour dummy device 80x30
[ 7.343937] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.377792] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 7.475764] Registered IR keymap rc-cec
[ 7.484593] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 7.491999] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.492419] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input7
[ 7.497085] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.505861] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.506604] usbcore: registered new interface driver brcmfmac
[ 7.559357] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.584333] i2c i2c-22: Added multiplexed i2c bus 0
[ 7.591294] Registered IR keymap rc-cec
[ 7.607211] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.608012] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input8
[ 7.608856] i2c 10-0060: Fixing up cyclic dependency with fe801000.csi
[ 7.609587] i2c i2c-22: Added multiplexed i2c bus 10
[ 7.614111] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.615092] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.618205] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.620084] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.621425] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.621781] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.622274] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.627165] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 7.703267] Console: switching to colour frame buffer device 240x67
[ 7.703313] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.774967] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.794501] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 8.398209] 8021q: 802.1Q VLAN Support v1.8
[ 8.494794] uart-pl011 fe201000.serial: no DMA platform data
[ 8.601113] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.602219] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.738538] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 10.285458] ov9281 10-0060: Detected OV009281 sensor
[ 10.285483] ov9281 10-0060: Consider updating driver ov9281 to match on endpoints
