I have a pair of synchronized stereo hats for Jetson Nano. I’ve followed the instructions, installed the camera driver and everything seems to be okay until I try to run the example code.
ls -la /dev/video0
/dev/video0
v4l2-ctl --info
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, arducam-csi2 7-000c
Bus info : platform:54080000.vi:0
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
python arducam_displayer.py -d 0
Firmware Version: 1
Sensor ID: 0x0219
Serial Number: 0xAD65BF31
select timeout
VIDIOC_DQBUF: Resource temporarily unavailable
File “arducam_displayer.py”, line 100, in <module>
display(cap, arducam_utils)
File “arducam_displayer.py”, line 26, in display
frame = frame.reshape(int(h), int(w))
AttributeError: ‘NoneType’ object has no attribute ‘reshape’
I’m not sure what is wrong at this stage. Any help is much appreciated. Thanks.
