V3Link kit not detecting IMX219 cameras on Raspberry Pi 5 Bookworm Camera 1 port
Hi everyone, I’m really stuck trying to get the V3Link kit working on a Raspberry Pi 5 running Bookworm - no cameras are detected at all.
My setup:
  • V3Link ribbon connected to the Camera 1 port (not Camera 0)
  • Added dtoverlay=imx219 to /boot/firmware/config.txt
  • Running sudo rpicam-hello --list-cameras just reports no cameras available
What’s confusing me is that I have a separate RPi 5 with standalone CSI cameras and it works fine using GStreamer:
gst-launch-1.0 libcamerasrc camera-name="/base/axi/pcie@120000/rp1/i2c@80000/imx296@1a" ! videoconvert ! ximagesink
My end goal is to record from both cameras at the same time with GStreamer. Does anyone know what I’m missing here?
Thanks for the detailed post. A few things to clarify up front:
  1. Just so you know early on - this kit does not support running two IMX219 camera modules simultaneously, which is relevant since you mentioned recording both cameras at once.
  2. Could you share pictures of the hardware connection on both ends - the Raspberry Pi side and the camera side? A very common cause of ‘no cameras’ with this kit is the ribbon not being seated fully or inserted the wrong way.
  3. Could you also generate a bug report so we can see what the Pi actually detects? Run these after a reboot:
This outputs an arducam-bug-report.txt file in the current directory - you can send it over for analysis.
Thanks for the quick reply. To confirm: the ribbon is definitely on the Camera 1 port, and /boot/firmware/config.txt does contain dtoverlay=imx219. sudo rpicam-hello --list-cameras still shows nothing.
On my other RPi 5 the standalone CSI cameras come up fine with the GStreamer command I posted above, so I don’t think it’s a general camera stack problem on my side.
I’ll be honest - the fact that the kit can’t run two IMX219 modules at the same time wasn’t clear to me from the product description. Is there any workaround for that, or is it a hard limitation? I really need to capture both cameras simultaneously.
Unfortunately it’s a hard limitation of this kit - two IMX219 modules can’t run at the same time on it. If simultaneous capture is a firm requirement we may need to look at a different camera bundle, but let’s first figure out why nothing is detected at all, because even a single camera should show up in --list-cameras.
While you generate the bug report, can you also double-check the ribbon orientation on both ends? The contacts on the flex cable need to face the right direction depending on the connector - try reseating it firmly and confirm whether the HAT LEDs light up at all.
One more thing on your earlier question about focus settings - I’m not able to provide a solution for that specific requirement.
Okay, understood on the two-camera limitation.
I ran the bug report tool after a reboot and it generated arducam-bug-report.txt. I’ve sent that file over along with pictures of the test setup (both the Pi end and the camera end).
I also tried reseating the ribbon and checking orientation, but sudo rpicam-hello --list-cameras still reports no cameras available.
Thanks, I’ve received the bug report and the photos. Based on what I’m seeing, I still suspect a hardware connection issue - the camera is simply not being detected despite dtoverlay=imx219 being present.
A couple of follow-ups:
  • Can you confirm which way the metal contacts on the ribbon are facing at the Pi end vs the camera end? It’s easy to have one end flipped even when the cable feels seated.
  • What’s the LED status on the HAT when the Pi is powered on? That can tell us whether the link is even coming up.
Since the report and pictures aren’t conclusive yet, I’d like to set up a remote session to look at the Pi directly.
I swapped the V3Link HAT for another unit I had and there was no difference at all - same result, no cameras listed.
To make the LED status easier to check remotely, I’ve set up a separate camera pointed at the HAT LEDs so you can observe their behavior. Let me know what you need from me to get a remote session going.
That swap is a useful data point - it points away from a simple defective HAT and more toward the cable or the port connection.
I’ve sent you the remote support details through private message, along with a scheduling link. Please check your messages and pick a convenient time. Note that I’m on UTC+8, so we’ll need to coordinate a time that overlaps with your working hours.
I can’t install TeamViewer on this system, so I’ve sent you direct remote access details in a private message instead. My normal working hours are 09:00-17:00 EST.
Have you had a chance to try accessing the Pi yet? The kit is still showing no cameras and I’d like to know if you can see anything from the LED camera feed.
To summarize where we are right now:
  • sudo rpicam-hello --list-cameras returns no cameras even with dtoverlay=imx219 in /boot/firmware/config.txt on the Bookworm Pi 5.
  • The bug report has been collected and the HAT was swapped with another unit, with no change - so the strongest suspicion remains a hardware/connection issue (ribbon seating or orientation on either end).
  • The LED observation camera you set up will help confirm link status during the remote session.
  • On the simultaneous-capture goal: this kit does not support two IMX219 modules at the same time. If that’s a firm requirement, I’ve sent details privately about an alternative multi-camera kit.
I’ll use the direct remote access details you provided during your working hours and update you as soon as I’ve been able to check the LED status and the camera detection directly.
