UVC Camera B0261 shows grayscale on Linux after serial number change, missing burner files
Hi, I’m having a problem with my Arducam UVC camera (model B0261) and could really use some help.
I was trying to change the camera’s serial number and followed the guide here: Redirecting... using ParamTableSetBurnerAP.exe with the UVC_B0261_20220824.bin firmware. The camera worked fine before I ran that tool. Now, ever since I changed the serial number, it only outputs grayscale images — the color is completely gone.
My setup is a Linux host (Dell XPS13). Here’s the dmesg output I get when I plug the camera in:
[ 52.033950] usb 1-6.4: new high-speed USB device number 8 using xhci_hcd
[ 52.259729] usb 1-6.4: New USB device found, idVendor=0c45, idProduct=6362, bcdDevice= 0.00
[ 52.259736] usb 1-6.4: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 52.259739] usb 1-6.4: Product: USB 2.0 Camera
[ 52.259743] usb 1-6.4: Manufacturer: Sonix Technology Co., Ltd.
[ 52.261700] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (0c45:6362)
[ 52.261840] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
[ 52.262240] uvcvideo: Failed to query (GET_INFO) UVC control 3 on unit 1: -32 (exp. 1).
[ 52.262717] uvcvideo: Failed to query (GET_INFO) UVC control 4 on unit 1: -32 (exp. 1).
[ 52.263162] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 2: -32 (exp. 1).
[ 52.263591] uvcvideo: Failed to query (GET_INFO) UVC control 3 on unit 2: -32 (exp. 1).
[ 52.264056] uvcvideo: Failed to query (GET_INFO) UVC control 6 on unit 2: -32 (exp. 1).
[ 52.264506] uvcvideo: Failed to query (GET_INFO) UVC control 7 on unit 2: -32 (exp. 1).
[ 52.264951] uvcvideo: Failed to query (GET_INFO) UVC control 8 on unit 2: -32 (exp. 1).
[ 52.265371] uvcvideo: Failed to query (GET_INFO) UVC control 9 on unit 2: -32 (exp. 1).
[ 52.265777] uvcvideo: Failed to query (GET_INFO) UVC control 10 on unit 2: -32 (exp. 1).
[ 52.266242] uvcvideo: Failed to query (GET_INFO) UVC control 1 on unit 2: -32 (exp. 1).
[ 52.266716] uvcvideo: Failed to query (GET_INFO) UVC control 4 on unit 2: -32 (exp. 1).
[ 52.267161] uvcvideo: Failed to query (GET_INFO) UVC control 5 on unit 2: -32 (exp. 1).
[ 52.267567] uvcvideo: Failed to query (GET_INFO) UVC control 11 on unit 2: -32 (exp. 1).
[ 52.305615] input: USB 2.0 Camera: USB Camera as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6.4/1-6.4:1.0/input/input26
[ 52.874092] uvcvideo: Failed to query (GET_DEF) UVC control 2 on unit 2: -32 (exp. 2).
Any idea what went wrong or how I can fix it? I just want to get the color image back.
Hi, thanks for the detailed logs. This is most likely happening because a serial number / product name change requires a full firmware re-burn — if the parameter data doesn’t match, the device can come up in a bad state like the grayscale output you’re seeing.
Important note: every time you want to change the serialNumber or the product name, you need to re-burn the firmware (i.e. repeat the whole procedure again).
Here’s the procedure for the B0261:
  1. Open ParamTableSetBurnerAP.exe and click the button ‘从设备中读取’ (circled in red in the guide). You should see the camera info appear once you click it.
  2. Click ‘浏览’ and choose the file UVC_B0261_20220824.bin, then click the button ‘开始烧录’. Wait for a while until it finishes.
  3. After modifying the SerialNumber, you need to uninstall the device in the device manager and re-plug the camera.
  4. Re-plug the camera and you should see the SerialNumber modified.
The tool and firmware are attached to this post. Give it a try and let us know how it goes — feel free to ask if you get stuck on any step.
Thanks for the quick reply. I don’t see anything attached on my end though — there’s no ParamTableSetBurnerAP.exe and no UVC_B0261_20220824.bin anywhere in the message. Could you send those two files again? Without them I can’t re-run the burn procedure at all.
Sorry about that. I’ve put all the files into a single zip package and sent it to you through a private message. Please check your messages and reply here to confirm you received the file. Feel free to contact us if you run into any problems while following the steps.
Hmm, I’m still not seeing anything arrive on my side, and it seems like some of my replies aren’t reaching you either. I’m not sure why — maybe it’s something in the messaging system. Could you try sending it again?
I’m not sure why it’s bouncing back, but let me repost the full procedure here so you have it regardless, and I’ll send the zip package again via private message in case the earlier one didn’t come through.
  1. Open ParamTableSetBurnerAP.exe and click the button ‘从设备中读取’. You will see the camera info after you click the button.
  2. Click the button ‘浏览’, choose UVC_B0261_20220824.bin, then click the button ‘开始烧录’. Wait for a while.
  3. After modifying the SerialNumber, uninstall the device in the device manager and re-plug the camera.
To summarize where we’re at: the plan is to re-burn the firmware using ParamTableSetBurnerAP.exe + UVC_B0261_20220824.bin, then uninstall the device and re-plug so the new serial number takes effect. Just remember that every serial number / product name change requires a fresh firmware burn (repeat these steps each time).
Please confirm once you receive the zip from the private message, then run through these steps and let me know whether the color image comes back.
