B0265R Kit
Raspberry PI 4B
your instruction and support, along with sony and raspberry docs
never worked well
I bought a B0265R Kit, and after a long pain and waste of time I managed (with your help) to get a few good images, but the system needs to be constantly hand tuned because of the bad AWB.
Using the default raspistill the colors and AWB are good, but it does’t support the complete dual frame (Mode1 8112x3040) images from the Camarray Hat UC-512.
It it possible to use the standard libcamera library and function to process the image instead of your library? Or can you integrate those algorithm inside your MIPI_Camera driver?
It should be open source and used or integrated in third party sw:
https://libcamera.org/entries/2020-05-05.html
Thanks
