Amazon -
SKU B0323 -
Jetson Nano 2GB -
installed driver automatically for my kernel version, in particular I ran
./install_full.sh -m arducam
and it installed properly:
Preparing to unpack arducam-nvidia-l4t-kernel-t210-4.9.253-tegra-32.6.1-20210915100958_arm64.deb …
Unpacking arducam-nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20210915100958) …
Setting up arducam-nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20210915100958) -
image is dark and greenish; can’t change any values in the module using v4l2-ctl (the changes are not given effect) -
[ 0.212135] DTS File Name: /var/jenkins_home/workspace/n_nano_kernel_l4t-32.6.1-arducam/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[ 0.408333] DTS File Name: /var/jenkins_home/workspace/n_nano_kernel_l4t-32.6.1-arducam/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[ 1.302899] arducam-csi2 6-000c: firmware version: 65537
[ 1.303255] arducam-csi2 6-000c: Sensor ID: 0x0298
[ 1.387081] arducam-csi2 6-000c: sensor arducam-csi2 6-000c registered
[ 1.553500] vi 54080000.vi: subdev arducam-csi2 6-000c bound
removed/reinstalled kernel driver; a regular Pi v2 camera works fine, and my Arducam IMX298 works fine on my Raspberry Pi 4 -
I would like to know whether the SKU B0323 camera works on the Jetson Nano or do I need to buy a different camera. It appears that the white balance and exposure are not set properly when using the camera on the Nano, and the v4l2-ctl commands to change the values do not work. For example, if I run:
v4l2-ctl -C exposure
I get:
exposure: 1600
but if I run:
v4l2-ctl -c exposure=3200
it does not change the exposure, which remains at 1600. The same is true for other parameters. So I can’t set it to autofocus or auto white balance, etc.
I’ve read a few cryptic comments about the Pivariety cameras, but I thought I would ask directly whether it is possible to use this camera (which is called Pivariety Motorized Focus Camera Module for Raspberry Pi) with the Jetson Nano 2GB.
Thanks for your thoughts.
