Multi Camera Adapter from Arducam’s store on Amazon
12.3 megapixel Sony IMX477 from Amazon (x2) -
B0210 Arducam Multi Camera Adapter Module V2.2 -
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Linux raspberrypi 5.10.81-v7l+ #1490 SMP Mon Nov 22 14:06:57 GMT 2021 armv7l GNU/Linux
Multi-Camera Adapter Board - Arducam -
I cannot preview or capture images with either camera using Raspbian Bullseye. The switch to libcamera and Python 3 has broken sample code (e.g. https://github.com/ArduCAM/RaspberryPi/tree/master/Multi_Camera_Adapter/Multi_Adapter_Board_4Channel). Despite making changes to python code (originally written for Python 2) including updates to use libcamera I cannot switch cameras or capture images.
Note: I have been able to capture images with Raspbian Buster. So, hardware set up should be correct. I’d prefer to not run older version of the OS. I’d like to use
[ 0.000000] Linux version 5.10.81-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1490 SMP Mon Nov 22 14:06:57 GMT 2021
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037efffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 999168
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 802560 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 997440
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:65:36:66 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=88a3a606-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3547332K/3996672K available (10240K kernel code, 1366K rwdata, 3192K rodata, 2048K init, 882K bss, 121660K reserved, 327680K cma-reserved, 3210240K highmem)
[ 0.000000] ftrace: allocating 34348 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000009] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000029] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000091] bcm2835: system timer (irq = 26)
[ 0.000759] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000778] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000796] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000811] Switching to timer-based delay loop, resolution 18ns
[ 0.001089] Console: colour dummy device 80x30
[ 0.001157] printk: console [tty1] enabled
[ 0.001212] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001243] pid_max: default: 32768 minimum: 301
[ 0.001414] LSM: Security Framework initializing
[ 0.001608] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001635] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003165] cgroup: Disabling memory control group subsystem
[ 0.003413] CPU: Testing write buffer coherency: ok
[ 0.003901] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005133] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005342] rcu: Hierarchical SRCU implementation.
[ 0.006287] smp: Bringing up secondary CPUs …
[ 0.007551] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008962] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010321] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010479] smp: Brought up 1 node, 4 CPUs
[ 0.010500] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010516] CPU: All CPU(s) started in HYP mode.
[ 0.010530] CPU: Virtualization extensions available.
[ 0.011497] devtmpfs: initialized
[ 0.026355] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026584] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026616] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.035071] pinctrl core: initialized pinctrl subsystem
[ 0.036211] NET: Registered protocol family 16
[ 0.040583] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041430] audit: initializing netlink subsys (disabled)
[ 0.041706] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.042322] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.043117] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.043134] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.043581] Serial: AMBA PL011 UART driver
[ 0.091762] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.110915] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-11-16T17:39:36, variant start_x
[ 0.120926] raspberrypi-firmware soc:firmware: Firmware hash is 99c5aad7da0d1e3b2c28669a3941db77734b9f2d
[ 0.161621] Kprobes globally optimized
[ 0.167279] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.172958] vgaarb: loaded
[ 0.173457] SCSI subsystem initialized
[ 0.173705] usbcore: registered new interface driver usbfs
[ 0.173766] usbcore: registered new interface driver hub
[ 0.173839] usbcore: registered new device driver usb
[ 0.174296] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.176379] clocksource: Switched to clocksource arch_sys_counter
[ 1.137014] VFS: Disk quotas dquot_6.6.0
[ 1.137118] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.137288] FS-Cache: Loaded
[ 1.137514] CacheFiles: Loaded
[ 1.138729] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes, mapped to 0x(ptrval)
[ 1.138751] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.139266] Console: switching to colour frame buffer device 240x67
[ 1.150066] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
[ 1.160652] NET: Registered protocol family 2
[ 1.160908] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.162221] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.162266] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.162430] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.162504] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.162685] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.162725] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.163441] NET: Registered protocol family 1
[ 1.164211] RPC: Registered named UNIX socket transport module.
[ 1.164227] RPC: Registered udp transport module.
[ 1.164242] RPC: Registered tcp transport module.
[ 1.164256] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.164281] PCI: CLS 0 bytes, default 64
[ 1.167894] Initialise system trusted keyrings
[ 1.168166] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.176490] zbud: loaded
[ 1.178266] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.179049] NFS: Registering the id_resolver key type
[ 1.179120] Key type id_resolver registered
[ 1.179136] Key type id_legacy registered
[ 1.179279] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.179296] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.180358] Key type asymmetric registered
[ 1.180376] Asymmetric key parser ‘x509’ registered
[ 1.180570] bounce: pool size: 64 pages
[ 1.180618] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.180832] io scheduler mq-deadline registered
[ 1.180848] io scheduler kyber registered
[ 1.186022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.186054] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.186134] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.186222] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00ffffffff → 0x0400000000
[ 1.248481] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.248884] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.248906] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.248928] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.249022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.249270] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.252900] PCI: bus0: Fast back to back transfers disabled
[ 1.253159] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.253232] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.253496] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.257065] PCI: bus1: Fast back to back transfers disabled
[ 1.257190] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.257217] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.257261] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.257288] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.257696] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.257937] pcieport 0000:00:00.0: PME: Signaling with IRQ 82
[ 1.269086] iproc-rng200 fe104000.rng: hwrng registered
[ 1.269474] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[ 1.271089] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.283656] brd: module loaded
[ 1.296502] loop: module loaded
[ 1.298486] Loading iSCSI transport class v2.0-870.
[ 1.301786] libphy: Fixed MDIO Bus: probed
[ 1.303802] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.316461] libphy: bcmgenet MII bus: probed
[ 1.396581] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.397826] usbcore: registered new interface driver r8152
[ 1.397900] usbcore: registered new interface driver lan78xx
[ 1.397977] usbcore: registered new interface driver smsc95xx
[ 1.446991] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.447028] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.450334] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.451697] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.451717] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.451735] usb usb1: Product: xHCI Host Controller
[ 1.451753] usb usb1: Manufacturer: Linux 5.10.81-v7l+ xhci-hcd
[ 1.451769] usb usb1: SerialNumber: 0000:01:00.0
[ 1.452524] hub 1-0:1.0: USB hub found
[ 1.452638] hub 1-0:1.0: 1 port detected
[ 1.453319] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.453347] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.453373] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.453897] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.453916] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.453933] usb usb2: Product: xHCI Host Controller
[ 1.453949] usb usb2: Manufacturer: Linux 5.10.81-v7l+ xhci-hcd
[ 1.453965] usb usb2: SerialNumber: 0000:01:00.0
[ 1.454679] hub 2-0:1.0: USB hub found
[ 1.454751] hub 2-0:1.0: 4 ports detected
[ 1.456732] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.457150] dwc_otg: FIQ enabled
[ 1.457164] dwc_otg: NAK holdoff enabled
[ 1.457179] dwc_otg: FIQ split-transaction FSM enabled
[ 1.457196] Module dwc_common_port init
[ 1.457681] usbcore: registered new interface driver uas
[ 1.457801] usbcore: registered new interface driver usb-storage
[ 1.458016] mousedev: PS/2 mouse device common for all mice
[ 1.459974] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.464244] sdhci: Secure Digital Host Controller Interface driver
[ 1.464260] sdhci: Copyright(c) Pierre Ossman
[ 1.465076] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.465855] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.470672] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.471022] hid: raw HID events driver (C) Jiri Kosina
[ 1.471244] usbcore: registered new interface driver usbhid
[ 1.471258] usbhid: USB HID core driver
[ 1.477953] Initializing XFRM netlink socket
[ 1.477998] NET: Registered protocol family 17
[ 1.478121] Key type dns_resolver registered
[ 1.478570] Registering SWP/SWPB emulation handler
[ 1.478770] registered taskstats version 1
[ 1.478802] Loading compiled-in X.509 certificates
[ 1.479708] Key type ._fscrypt registered
[ 1.479726] Key type .fscrypt registered
[ 1.479741] Key type fscrypt-provisioning registered
[ 1.492028] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.492341] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.492428] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 38, base_baud = 0) is a PL011 rev2
[ 1.501295] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.502386] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.502405] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.531315] of_cfs_init
[ 1.531596] of_cfs_init: OK
[ 1.538847] mmc1: Controller never released inhibit bit(s).
[ 1.563960] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.565652] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.567360] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.570421] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.572136] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.579103] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.579801] Waiting for root device PARTUUID=88a3a606-02…
[ 1.641612] mmc1: new high speed SDIO card at address 0001
[ 1.736432] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.919028] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.919048] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.919066] usb 1-1: Product: USB2.0 Hub
[ 1.920979] hub 1-1:1.0: USB hub found
[ 1.921277] hub 1-1:1.0: 4 ports detected
[ 2.066928] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 2.098261] usb 2-2: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 2.098280] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2.098297] usb 2-2: Product: SSHD
[ 2.098316] usb 2-2: Manufacturer: SABRENT
[ 2.098333] usb 2-2: SerialNumber: AAAABBBBCCCC0003
[ 2.122630] scsi host0: uas
[ 2.124139] scsi 0:0:0:0: Direct-Access SABRENT SSHD 0 PQ: 0 ANSI: 6
[ 2.126270] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 2.126551] sd 0:0:0:0: [sda] Write Protect is off
[ 2.126572] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 2.126928] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.127761] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 2.130572] sda: sda1 sda2
[ 2.133802] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.168979] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.169060] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 2.169542] devtmpfs: mounted
[ 2.180011] Freeing unused kernel memory: 2048K
[ 2.196713] Run /sbin/init as init process
[ 2.196729] with arguments:
[ 2.196744] /sbin/init
[ 2.196759] splash
[ 2.196773] with environment:
[ 2.196787] HOME=/
[ 2.196802] TERM=linux
– snipped (message length was exceeded for the forum; I can provide full dmesg if necessary) –
[ 4.954259] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.963155] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.973000] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.977296] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.011330] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
[ 5.011355] fb0: switching to vc4drmfb from simple
[ 5.039755] Console: switching to colour dummy device 80x30
[ 5.072965] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.101759] mc: Linux media interface: v0.10
[ 5.158460] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.174625] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.202096] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.203663] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.203687] [vc_sm_connected_init]: start
[ 5.208685] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.244725] videodev: Linux video capture interface: v2.00
[ 5.251289] [vc_sm_connected_init]: installed successfully
[ 5.257954] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.259961] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.276182] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.288271] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.302857] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.341726] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.344311] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.345446] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.347038] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.347069] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.347095] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.347119] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.347142] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.348822] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.355124] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.356871] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.426478] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.426528] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.431354] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.431405] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.456481] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.456546] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.462610] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.462659] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.471281] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.496623] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.553876] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.587669] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.594055] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.595423] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.601543] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.610781] Registered IR keymap rc-cec
[ 5.611352] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.611584] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input4
[ 5.612558] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 5.705973] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.707885] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.743169] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.795852] Registered IR keymap rc-cec
[ 5.796066] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.796345] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input5
[ 5.804074] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 5.809948] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.845982] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 5.879066] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.892592] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 5.905309] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.949101] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.951172] Registered IR keymap rc-cec
[ 5.951366] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.951598] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input6
[ 5.952579] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 5.965962] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.967003] usbcore: registered new interface driver brcmfmac
[ 6.065517] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.071608] Registered IR keymap rc-cec
[ 6.071800] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.072019] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input7
[ 6.073008] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 6.220685] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.221242] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.231267] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 7.040414] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.043178] Registered IR keymap rc-cec
[ 7.043377] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.043731] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input8
[ 7.062447] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.085948] Registered IR keymap rc-cec
[ 7.086147] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.086724] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input9
[ 7.105781] random: crng init done
[ 7.105801] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.137423] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.137858] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.138241] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.138585] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.138949] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.139245] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.139578] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.173935] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 7.317014] Console: switching to colour frame buffer device 240x67
[ 7.343938] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 8.003128] 8021q: 802.1Q VLAN Support v1.8
[ 8.048933] uart-pl011 fe201000.serial: no DMA platform data
[ 8.073567] imx477 10-001a: Device found is imx477
[ 8.074221] imx477 10-001a: Consider updating driver imx477 to match on endpoints
[ 8.316560] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.591594] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.003792] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.005397] bcmgenet fd580000.ethernet eth0: Link is Down
[ 12.709677] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 12.710284] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 12.710803] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 12.717499] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 12.718011] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 12.718318] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 14.879996] Bluetooth: Core ver 2.22
[ 14.880051] NET: Registered protocol family 31
[ 14.880057] Bluetooth: HCI device and connection manager initialized
[ 14.880072] Bluetooth: HCI socket layer initialized
[ 14.880080] Bluetooth: L2CAP socket layer initialized
[ 14.880096] Bluetooth: SCO socket layer initialized
[ 14.891732] Bluetooth: HCI UART driver ver 2.3
[ 14.891742] Bluetooth: HCI UART protocol H4 registered
[ 14.891811] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.892466] Bluetooth: HCI UART protocol Broadcom registered
[ 15.041078] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.081950] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.081958] Bluetooth: BNEP filters: protocol multicast
[ 15.081972] Bluetooth: BNEP socket layer initialized
[ 15.108657] NET: Registered protocol family 38
[ 15.133190] cryptd: max_cpu_qlen set to 1000
[ 15.265603] Bluetooth: RFCOMM TTY layer initialized
[ 15.265628] Bluetooth: RFCOMM socket layer initialized
[ 15.265647] Bluetooth: RFCOMM ver 1.11
[ 17.762877] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 31.836445] imx477_vddl: disabling
[ 31.836471] imx477_vdig: disabling
[ 31.836496] vcc-sd: disabling
[ 31.836516] imx477_vana: disabling
[ 543.240051] v3d fec00000.v3d: MMU error from client CLE (4) at 0xd81000, pte invalid
I have tried updating various /boot/config.txt parameters. Current settings I have:
start_x=1
gpu_mem=128
dtparam=sd_poll_once
dtoverlay=imx477
dtparam=i2c_vc=on
dtparam=sd_poll_once is because I am running from USB SSD (not microSD card)
I have enabled camera and i2c using raspi-config
I’ve confirmed camera is detected:
vcgencmd get_camera
supported=1 detected=0
(from research on the web moving to libcamera detected=0 is expected; I could be wrong)
I’ve checked the adapter and cameras are detected on i2c bus:
i2cdetect -y 1
00: – – – – – – – –
10: – – – – – – – – – – 1a – – – – –
60: – – – – 64 – – – – – – – – – – –
70: 70 – – – – – – –
I updated firmware with rpi-update
- What help do you need?
I would like help determining the correct boot config parameters necessary to detect and set up adapter and cameras so I can take still pictures with both cameras. It would be helpful to have instructions and sample code that works with Raspbian Bullseye and an Raspi Model 4B.
