PiHut, UK - Model number of the product(s)?
B0067 Mini 2MP Plus - OV2640 - What hardware/platform were you working on?
Arduino Nano RP2040 Connect, PC, Thonny - Instructions you have followed. (link/manual/etc.)
ArduCAM_Mini_2MP_Plus_VideoStreaming - Problems you were having?
Converting the code to store the image locally in a readable format - The dmesg log from your hardware?
No error messages - Troubleshooting attempts you’ve made?
See attached code - What help do you need?
Hi, so I’ve adapted the Arducam.py library file to hook up to the Nano and get the video streaming example to work: great, no hardware issues. I’ve then copied the code in this example to write the buffer to the device locally as I want to send the image in a POST request (as the Nano has wifi). I’m able to write the files as bytes or encoded (to add to a JSON payload) however what gets finally output can’t be read by a jpeg reader and the .txt version looks very different in anatomy to other encoded jpeg’s. I think I’m very close - I need help with constructing the file with whatever headers etc are needed? If anybody has a simple version of writing an image in circuitpython locally that’d be mighty useful. thanks?
Code used (note that a boot.py file is also used to remount the flash on the board to be writable)
import time
import busio
import board
from digitalio import DigitalInOut
from Arducam import * # requires Arducam files to be in same dir as 'code': Arducam.py, ov2640_reg.py (& ov5642_reg.py)
import circuitpython_base64 as b64 # requires package install of: circuitpython-base64
# Set up Cam board
mycam = ArducamClass(OV2640)
mycam.Camera_Detection()
mycam.Spi_Test()
mycam.Camera_Init()
time.sleep(1)
mycam.OV2640_set_JPEG_size(OV2640_160x120)
mycam.set_format(JPEG)
# Create files to write into
with open('/test.jpg', 'wb'):
pass
with open('/test.txt', 'wt'):
pass
# Save a jpg to file ready to go in a JSON payload
def get_still(mycam):
mycam.flush_fifo()
mycam.clear_fifo_flag()
mycam.start_capture()
once_number = 128
buffer=bytearray(once_number)
count = 0
finished = 0
length = mycam.read_fifo_length()
mycam.SPI_CS_LOW()
mycam.set_fifo_burst()
while finished == 0:
mycam.spi.readinto(buffer, start=0, end=once_number)
print(str(count) + ' of ' + str(length))
buffer_txt = b64.encodebytes(buffer)
print(buffer_txt[:20])
with open('/test.jpg', 'ab') as fj:
fj.write(buffer)
with open('/test.txt', 'at') as ft:
ft.write(buffer_txt)
count += once_number
if count + once_number > length:
count = length - count
mycam.spi.readinto(buffer, start=0, end=count)
fj.write(buffer)
mycam.SPI_CS_HIGH()
finished = 1
def main():
get_still(mycam)
print('Finished!')
if __name__ == '__main__':
main()
