I have an IMX219 module and the associated UVC USB2.0 board. The module works great when plugged in directly, but when plugged in with the sensor cable I do not get data back from the module. I’ve tried with macOS and with Android, and see the same results.
Why does this not work with the UVC board but does with the standard IMX219 breakout board? Is it because of signal integrity issues?
if it’s because of integrity, can I cut and splice the extension cable to reduce its length and overcome signal issues? I only need the cable to be 5-10cm long.
This should work, can you take a hardware connection diagram
Not allowed to do so.We have not tried it and do not guarantee its feasibility.
P.S.: Apologies for spreading this out across three posts, because I’m a new user the forum software will not let me upload multiple images to a single post.
These documents are publicly available, so don’t worry.
The file is only available for imx219.
The reason we don’t disclose the firmware directly is not because we want to keep the files confidential, upgrading the firmware is not the best way to solve the problem. When we determine that a user needs to upgrade, we will recommend that they do so.
