Amazon
B0251,B0263
Jetson Nano
https://www.arducam.com/docs/camera-for-jetson-nano/multiple-cameras-on-the-jetson-nano/camarray-arducam-1mp2-stereo-camera-mip/#11-check-the-driver
yes
I would like to use both the HQ IMX477 camera and the 1mp*2 stereo camera at the same time on the jetson nano. The problem occurs when installing the drivers as they overwrite each other. Is there a way both can be used?
Tried both drivers to see if I could get both cameras to work on the same driver
Hi @ACStgwin
This is possible, but the device tree needs to be modified,
Please tell me your L4T version (using cat /etc/nv_tegra_release command)
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
Hi @ACStgwin
I configured the CAM0 interface as Jetvariety and the CAM1 interface as IMX477. You need to do the following steps to replace the device tree:
- Copy tegra210-p3448-0000-p3449-0000-b00-arducam-imx477.dtb to the /boot/arducam directory
- Edit the /boot/extlinux/extlinux.conf file and modify FDT /boot/arducam/tegra210-p3448-0000-p3449-0000-b00.dtb to FDT /boot/arducam/tegra210-p3448-0000-p3449-0000 -b00-arducam-imx477.dtb
- Reboot jetson nano
Awesome! Thank you!
Are the instructions on how to do this ourselves available anywhere?
Hi @ACStgwin
At present, we can provide the relevant source code. If you want to modify the device tree yourself, you need some knowledge about the device tree. We are currently not sure whether users should modify the device tree by themselves, which will cause some problems.
Hi @wong
Could you provide the source code for generating the device tree? I think this device tree won’t work on newer versions of L4T.
Best
Hi @wong;
I’m with @wironomy on this one: Could you provide the source code for generating the device tree? I have a new setup where the Jetvariety cam cannot react CAM0 so they IMX477 is now in CAM0 and the Jetvariety is in CAM1. I would also like to upgrade L4T
Hi @acstgwin
You can send the relevant version information to [email protected], and I can send you a kernel patch.
