https://www.amazon.com/Arducam-Autofocus-Quad-Camera-Synchronized-Compatible/dp/B09TSGMCM9 -
Arducam 16MP Autofocus Quad-Camera Kit for Raspberry Pi, 16MP IMX519 Autofocus Synchronized Raspberry Pi Camera, Compatible with Nvidia Jetson Nano/Xavier NX, SKU : B0388
Raspberry Pi 4 Computer Model B 8GB Single Board Computer
picamera2_examples/HatSwitchCameraTakePicture.py at main · ArduCAM/picamera2_examples · GitHub -
The image capture was stuck in the loop while switch to each camera to take pictures individually in max resolution mode -
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“Debian – User Support”
BUG_REPORT_URL=“https://bugs.debian.org/”
reboot the Raspberry Pi and camera, and then it is back to normal.
The image capture will stuck sometime after running the script. -
Could you help to check our image capture function to see if there is anything that needs to be changed to make the script run stable?
Our script was very similar to the example script in picamera2_examples/HatSwitchCameraTakePicture.py at main · ArduCAM/picamera2_examples · GitHub
Thanks for your help!
