Upgrading B0266 to B0267
I’m currently using the B0266 stereo camera kit (UC-512 Rev.D2) which came with two customized OV9821 cameras (UC-788 Rev.B). I now want to add two more cameras to mhe setup, for a total of 4 cameras, essentially the same as the B0267 kit.
Is it possible to purchase the additional two modified cameras separately to be used with my current HAT+x2 cameras in a quad configuration instead of purchasing the entire B0267 bundle?
Thanks,
Thanks for reaching out.
Unfortunately, it is not possible to upgrade the B0266 stereo camera kit to a four-camera configuration simply by adding two more camera modules.
The CamArray HAT included with the B0266 is programmed with firmware specifically designed for dual-camera operation , so it cannot be used directly as a four-camera HAT.
Additionally, the customized camera modules designed to work with our CamArray HATs are not sold separately .
If you need to operate four cameras simultaneously, we recommend purchasing the complete B0267 Quad-Camera Kit , which includes the appropriate CamArray HAT and four compatible camera modules.
