I’m using IMX519 with RPi4 and libcamera. I followed the instructions came with the camera for installation and have been lucky with libcamera-still so far. --autofocus works but for some reason --continue-autofocus will throw an unrecognised option error. I can’t see --continue-autofocus in the list of commands when I run -h either. I’ve installed both libcamera_dev and libcamera_apps as instructed on arducam’s website. Any idea what the issue might be?
Thank you!
Edit: It seems for some reason libcamera-dev and libcamera-apps weren’t installed. Now when I try to install them I get an error saying
Repository is broken: libcamera-dev:arm64 (= 0.0.10) has no Size information Repository is broken: libcamera-apps:arm64 (= 0.0.10) has no Size information
Thanks! Just for info, I’ve also tried to directly install the .deb for libcamera-dev and libcamera-apps from arducam’s GitHub (basically the same links the .sh uses) but that also didn’t work.
I was getting a segmentation fault with libcamera-still --afmode continuous so I’ve decided to remove and reinstall libcamera. When I try to install libcamera-apps after libcamera-dev with the below:
./install_pivariety_pkgs.sh -p libcamera-apps
It gives me the below error:
E: Unable to correct problems, you have held broken packages.
Unknown error, please send the error message to [email protected]
Thanks! I had failed to remove it all but now I did. After a clean reinstall, while I still don’t see the --continue-autofocus among libcamera-still’s options, libcamera-still --afmode continuous works!
The clean install also solved the seg fault I was getting with --afmode continuous before.
I change my pi cam to the arducam 16Mpx IMX519 Autofocus and i have install everything as it’s explain on the website and the camera start and was fine, next day its just giving a blurry image
I have a RPI4 with OS Raspbian GNU/Linux 11 (bullseye)
I already tried a clean install like mention in comments above but still the same.
I try to use the arducam controller manual focus and it doesnt do anything. I have also install the IMX519 slow speed driver.
I saw some videos showcasing autofocus with some objects, does it need a target to focus? I believe it should only focus when needed right?
python3 FocuserExample.py -d /dev/v4l-subdev1
Tried both commands below but says i dont have the --afmode parameter available. I tried --help on libcamera-still and its not there.
