Amazon
IMX 298 https://www.arducam.com/product/16mp-imx298-color-mipi-camera-module-raspberry-pi/
Raspberry Pi 3B
https://www.arducam.com/docs/cameras-for-raspberry-pi/mipi-camera-modules/camera-userland-driver-sdk-and-examples/ https://github.com/ArduCAM/MIPI_Camera (attempted using capture.c, capture_raw.c, capture.py, capture_raw.py
Never captured full res, smaller res always worked
IMX 298’s full resolution is listed as either 4672×3496 or 4656x3496. However, when attempting to capture at 4656x3496 in python, an error occurs (presumably due to set_resolution):
This is relevant code from test.py
I have also attempted to use capture_raw.c and capture_raw.py.
this is the code I changed in capture_raw.c:
width = 4672;
height = 3496;
LOG(“Setting the resolution…”);
res = arducam_set_resolution(camera_instance, &width, &height);
and with capture_raw.py, this is the only code I changed below:
fmt = camera.set_resolution(4672, 3496)
I have attempted using both 4656x3496 and 4572x3496, and the same thing occurs. All resolutions above a certain threshold (around 3000x3000) result in the same error. All resolutions below that threshold capture properly, including 2336x1748, 1920x1080, 1160x800, etc.
Try many different resolutions and both c and python. All resolutions below a threshold of ~3000 x 3000 capture properly
Help me capture images at full res (either 4672 x 3496 or 4656 x 3496) on python
