Hi everyone, I’m trying to get an Arducam IMX477 PTZ camera working on a Jetson Orin Nano but every time I try to open the camera I get “unable to open camera”. Nothing else, just that error. Has anyone seen this before?
Thanks for reaching out. To narrow things down a bit - how are you opening the camera? OpenCV, a GStreamer pipeline, or nvarguscamerasrc? Also, could you paste the full terminal output when you run it, not just that single error line? The surrounding output usually tells us where it’s actually failing.
Honestly I haven’t gotten far enough to write any real code yet. I’m just trying to open the camera and it fails right away. The only thing the terminal shows is “unable to open camera”. Is there a specific example I should be running for this camera on the Orin Nano?
Got it. For the IMX477 PTZ on Jetson, the best starting point is the official Arducam quick-start guide - it covers the setup for the Pan-Tilt-Zoom camera on Jetson platforms step by step. Can you confirm whether you’ve already gone through that documentation? After you try again, please copy the complete terminal log here so we can see exactly what’s happening before the error.
I’ll go back through the quick-start guide again - I think I may have skipped some of the setup steps. Just to be clear, do you need the whole terminal output or only the error line?
The whole terminal output is helpful - from the command you run all the way to the error. The “unable to open camera” message on its own doesn’t tell us whether this is a driver/device tree issue, a permissions problem, or something else failing in the pipeline. The full log will point us in the right direction.
To summarize where we are: the root cause isn’t pinned down yet. Please follow the official Arducam IMX477 PTZ Camera quick-start guide at Quick Start - Arducam Wiki and then post the full terminal error log here. Once we can see the exact output, we should be able to figure out why the camera won’t open.
