Hi, I’m having trouble with the serial number modification module for my Arducam IMX179 Camera Module: A (SKU B0288). It’s listed in the product table as supported, but the standard module doesn’t seem to do anything. I’ve got several of these cameras hooked up to one Ubuntu system and I can’t tell them apart. Is there some other parameter in the camera info I can use to distinguish them, or a working module to change the serial number?
Thanks for the details. The standard module doesn’t always work with every IMX179 unit, so let’s try an alternate tool — I’ve sent you the link via private message. Please follow the steps in the Serial Number Tool Guide here: Redirecting... to change the device name or serial number of the cameras. On Ubuntu you can check the current USB camera info with:
v4l2-ctl -d /dev/video1 --all
Run that before and after so we can see what changes.
I tried the alternate module you sent and it still doesn’t work. Same behavior — the serial number just stays as it is.
Can you run the v4l2 command I posted above and paste the output? I want to see the driver info and the current serial field for one of the IMX179 units.
Here’s what I get on one of the cameras:
Driver Info:
Driver name : uvcvideo
Card type : Arducam IMX179 Camera Module: A
Bus info : usb-0000:00:14.0-1
Driver version : 5.15.143
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : Arducam IMX179 Camera Module: A
Serial : 01.00.00
Media version : 5.15.143
Hardware revision: 0x00000412 (1042)
Interface Info:
Type : V4L Video
Entity Info:
Name : Arducam IMX179 Camera Module: A
Function : V4L2 I/O
Flags : default
Pad 0x01000007 : 0: Sink
Link 0x02000013: from remote pad 0x100000a of entity 'Extension 4' (Video Pixel Formatter): Data, Enabled, Immutable
Thanks, that helps. From your output I can see it’s enumerating as ‘Arducam IMX179 Camera Module: A’ on usb-0000:00:14.0-1, serial 01.00.00, hardware revision 0x00000412 (1042), driver version 5.15.143. The serial shows as 01.00.00, which is the default. Can you send me the exact product link for this module? I need to confirm which IMX179 variant you actually have before we pick the right tool.
Sure, this is the module I’m using: Buy ArduCam B0446 8MP IMX179 USB Camera Module with Wide Angle 115°(H) M12 Lens for Windows, Linux, Android, and Mac OS in India | Fab.to.Lab — Arducam B0446 8MP IMX179 USB Camera Module, wide angle 115° M12 lens.
Got it. There are two hardware versions of this module out there, and the old one doesn’t support serial number/name modification at all. Could you post a couple of pictures of the camera module itself so I can confirm whether you have the new or old hardware version?
I’ll upload some photos of the module I’m using now so you can check which hardware version it is.
Thanks, from the photos that looks like the newer hardware, so the standard tool definitely shouldn’t have worked for it. I’ve sent you the correct tool for this module via private message — it’s attached there, and I’ve also included a download link in case the attachment doesn’t come through. Please try it and let me know if the serial number changes.
That one worked. I was able to change the serial number on the IMX179 with the tool you sent. Now I need to do the same on another camera — an Arducam B0477 20 MP USB 3.0 Camera. Do you have a module for that model?
Good to hear it’s working now. For the B0477 you need a different tool — I’ve sent it to you via private message. Run it the same way and check with v4l2-ctl afterwards. To summarize: your IMX179 needed the newer-hardware tool (not the standard module), and the B0477 uses its own separate tool, which I’ve just sent.
