Unable to install Arducam IMX477 drivers on Jetson Xavier NX
Hi all, I’m stuck trying to get the Arducam IMX477 drivers installed on my Jetson Xavier NX. I’m following the official Native Camera Quick Start Guide (Quick-Start-Guide - Arducam Wiki) and running:
./install_full.sh -m imx477
The script starts but then dumps a bunch of errors. Screenshot of what I get:
The weird part is I’ve installed these same drivers several times on a Jetson Nano with no problems. I figured the NX would be basically the same process. Am I missing something obvious?
Thanks for the screenshot. The Nano and NX share a lot, but the driver script is sensitive to the Jetpack/L4T version, and that’s where I suspect the issue is. Can you run the following on the NX and paste the output?
cat /etc/nv_tegra_release
Also, which Jetpack version did you flash? The errors in your screenshot look like the script is hitting an unexpected release version.
Here’s the output:
R35 (release), REVISION: 4.1
I flashed the board a while back using the latest available in NVIDIA SDK Manager, so I assumed it was fine. Is that R35.4.1? I’m not 100% sure how that maps to a Jetpack number.
That confirms it. R35.4.1 maps to Jetpack 5.1.2, which is newer than what the IMX477 install script supports. That’s why ./install_full.sh -m imx477 fails — the script checks the L4T release and your version is too high for it. Arducam maintains a supported Jetpack version list for this driver on their docs; compare your version against that list. If Jetpack 5.1.2 isn’t on it, you’ll need to flash a supported version onto the NX before running the install script.
Got it, that makes sense — the Nano I used before was definitely on an older Jetpack. So there’s no quick workaround, I’d need to re-flash? And how do I tell which Jetpack version corresponds to which L4T release so I can pick the right one from the supported list?
Right, re-flashing to a supported version is the reliable fix here — there isn’t a workaround that makes the script accept an unsupported release. For the mapping: Jetpack 4.x runs on L4T R32.x, and Jetpack 5.x runs on R35.x. Your R35.4.1 = Jetpack 5.1.2. Check the supported list and pick a version that’s listed, flash it, then verify with the same cat /etc/nv_tegra_release command before running ./install_full.sh -m imx477.
Okay, that’s clear. I’ll flash an older supported Jetpack version and give it another try. Thanks for the help — I’ll report back once it’s done.
Sounds good. To summarize for anyone else hitting this: the IMX477 driver install script fails when the Jetpack version is too new/unsupported. Check the version with cat /etc/nv_tegra_release, compare it against Arducam’s supported Jetpack list, and use a supported version before running ./install_full.sh -m imx477. Matching the Jetpack version to the supported list is required — if you still see errors after that, post the full log and we can dig further.
