Hello Team,
We are unable to pass our Arducam pi camera ( Full HD global shutter camera for Raspberry PI 2.3MP) input to one of Opev CV based module using Cv2.Videocapture function.
We tried to follow the possible solution provided on below thread but no luck. We tried installing the .whl files with correct driver but we are still getting following error
“ERROR: libcamera-1.0.1-cp37-cp37m-linux_armv7l.whl is not a supported wheel on this platform.”
Following are my system config
python -V → Python 3.9.2
Also the config file (/boot/config.txt
) looks like below
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=85
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=off
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=arducam
dtoverlay=pi3-miniuart-bt
enable_uart=1
