The stock Raspberry Pi IMX708 driver does not recognize the camera.
Original driver message:
imx708 11-001a: chip id mismatch: 708!=707
I verified that the camera returns chip ID 0x0707 instead of 0x0708.
I modified imx708.c to accept 0x0707 and rebuilt the driver.
After that:
Camera is detected successfully
rpicam-still --list-cameras works
The camera is identified as imx708_wide
However image capture always fails
Output of:
Available cameras
0 : imx708_wide [4608x2592 10-bit RGGB]
Modes:
1536x864
2304x1296
4608x2592
dmesg output:
imx708 11-001a: camera module ID 0x0707
rp1-cfe 1f00128000.csi: Using sensor imx708_wide for capture
Capture test:
Result:
Camera frontend has timed out!
Additional observations:
This behavior was reproduced using all four different UC-A74 Rev.C modules from the same CamArray kit.
All modules report chip ID 0x0707.
All modules are detected after patching the ID check.
All modules fail with the same frontend timeout during streaming.
Questions:
Are UC-A74 Rev.C modules expected to return chip ID 0x0707?
Is there an official driver update or patch for these modules?
Is there any additional initialization sequence, firmware, overlay, or configuration needed when using UC-A74 Rev.C modules as standalone cameras on Raspberry Pi 5 (without the CamArray HAT)?
Attached are photos of one of the UC-A74 Rev.C camera modules from the CamArray IMX708 kit:
Front side (sensor side)
Back side (PCB side)
Additional information from my testing:
The CamArray kit works correctly on Raspberry Pi 5.
Four-in-One mode captures successfully.
Single-channel mode also captures successfully.
However, when the same UC-A74 Rev.C module is connected directly to the Raspberry Pi 5 CSI port (without the CamArray HAT), it reports chip ID 0x0707 and fails with:
I confirmed this by directly reading register 0x0016:
i2ctransfer -y 11 w2@0x1a 0x00 0x16 r2
0x07 0x07
The same behavior was observed on all four modules included in the kit.
Please let me know if you would like any additional photos or test results.
The UC-A74 Rev.C IMX708 camera modules included in the CamArray kit are designed to work with the CamArray HAT and cannot be connected directly to the Raspberry Pi CSI port.
These camera modules rely on the clock signal provided by the CamArray HAT to operate correctly. Without the HAT, the cameras do not receive the required clock signal, so they cannot initialize and stream normally.
Since all four cameras work correctly in both Four-in-One and single-channel modes through the CamArray HAT, this indicates that the camera modules themselves are functioning properly.
For this kit, please continue using the cameras through the CamArray HAT rather than connecting them directly to the Raspberry Pi.
