Amazon
UB0241
It works fine with Windows, but I am using Ubuntu 20.04. I am making a custom application using OpenCV Python.I also tried using the “cheese” utility tool.
It works fine on my Windows machine and can record the video in 60FPS.
However, on my Linux machine I can only get 30 fps. -
# Python program to save a
# video using OpenCV
import cv2
import os
# Create an object to read
# from camera
video = cv2.VideoCapture(0, cv2.CAP_V4L2)
video.set(cv2.CAP_PROP_FRAME_WIDTH,640)
video.set(cv2.CAP_PROP_FRAME_HEIGHT,480)
video.set(cv2.CAP_PROP_FOURCC,60)
# We need to check if camera
# is opened previously or not
if (video.isOpened() == False):
print("Error reading video file")
# We need to set resolutions.
# so, convert them from float to integer.
frame_width = int(video.get(3))
frame_height = int(video.get(4))
size = (frame_width, frame_height)
print(size)
# Below VideoWriter object will create
# a frame of above defined The output
# is stored in 'filename.avi' file.
path="saved_videos"
vid_name="video.avi"
vid_counter=0
result = cv2.VideoWriter(os.path.join(path,vid_name),cv2.VideoWriter_fourcc('M','J','P','G'), 60, size)
while(True):
ret, frame = video.read()
if ret == True:
# Write the frame into the
# file 'filename.avi'
result.write(frame)
# Display the frame
# saved in the file
cv2.imshow('Frame', frame)
# Press S on keyboard
# to stop the process
if cv2.waitKey(1) & 0xFF == ord('s'):
break
# Break the loop
else:
break
# When everything done, release
# the video capture and video
# write objects
video.release()
result.release()
# Closes all the frames
cv2.destroyAllWindows()
print("The video was successfully saved")
get 60 fps at resolutions higher than 320x240 when using Ubuntu 20.04
